Sluggish after installing Borla S-Type exhaust
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Beshaw1221, Mar 23, 2021.
  1. Mar 23, 2021 at 5:29 PM
    Beshaw1221
    Beshaw1221 [OP] Well-Known Member
    Bruce
    2019 Tacoma TRDOR DCLB cement
    So let me start at the beginning. I have a 2019 trd off-road dblcab long-bed. I started my first mod with an airaid CAI. That was a mistake and $500 down the drain. Killed the already bad low end torque. Back to stock. Next I wanted a little sound so I threw on an MBRP catback. Sounded great but because it’s 3” I again killed the low end. Back to stock. $200 down the drain. Next, and I probably should have done this first was update my TSB to 04B33. Then I added the OV tune. Only the stock thx 87 octane. I wouldn’t have been able to do the TSB or OV without the guidance of my taco sensai @tonered. I think at this point the truck felt much better but I had the bug so I kept going. Next I put the TRD intake flow accelerator on my stock box with an AFE drop in and a
    HPS-57-1600-BLK intake tube.
    The truck still felt pretty good but I still wanted some growl. I opted for the Borla s type catback so I threw that on. Now my truck feels sluggish again like before the update and tune. It shouldn’t considering the Borla is 2.5” but it does. I think that Tacoma’s just run better on the stock exhaust. Or perhaps I’m just going crazy. Any thoughts would be great
    rubiconjp, Junkhead and tonered like this.
  2. Mar 23, 2021 at 7:19 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :cheers:
    Crazy isn't a bad place to be. :D
    Rainoffire, DAS Taco and Shellshock like this.
  3. Mar 23, 2021 at 7:23 PM
    Beshaw1221
    Bruce
    So in your experience from what I said, do you think the Borla could affect all that I did. I mean with the TSB update and OV tune.
  4. Mar 23, 2021 at 7:25 PM
    Beshaw1221
    Bruce
    It’s almost like I lost the tune
  5. Mar 23, 2021 at 7:27 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I honestly don't know. What I do know is that a Borla sounded great on our Saab. And, the butt dyno can lie. A smooth, tuned sound can feel slow. Get out there and do some 0-60s? The Torque app will time you. I'm a bit lazy at the moment, but I have a few vids of 0-60s on my Taco before OVT. I've been meaning to do an after test, but never got around to it.
    Junkhead likes this.
  6. Mar 23, 2021 at 7:29 PM
    Beshaw1221
    Bruce
    Sounds good. Thanks again for your valued input
  7. Mar 23, 2021 at 7:47 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
  8. Mar 23, 2021 at 7:48 PM
    Beshaw1221
    Bruce
    The tune should adapt though right?
  9. Mar 23, 2021 at 7:51 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. There are no real specifics for intakes / exhausts outside of dyno time. It will take time to adjust.
  10. Mar 23, 2021 at 7:53 PM
    Beshaw1221
    Bruce
    Ok. Thanks again.
  11. Mar 23, 2021 at 7:57 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No problem!
    :cheers:
  12. Mar 23, 2021 at 8:31 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I installed Borla s type about a year ago and no complaints whatsoever, love the sound and definitely no power loss.
    DAS Taco likes this.
  13. Mar 23, 2021 at 8:35 PM
    Beshaw1221
    Bruce
    Yea I do love the sound. You said it’s been a year but did you find it really hard to connect at the y pipe. I could barely get it on.
    Junkhead[QUOTED] likes this.
  14. Mar 23, 2021 at 8:40 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I had a local shop install it for 60$. They did have a hard time with one piece as it was a bit out of round, they had to hammer this “cone” looking tool to make it round, don’t think it was the y pipe though.
  15. Mar 23, 2021 at 8:41 PM
    Beshaw1221
    Bruce
    Mine was the same. A few pieces out of round. I got it on though. Thanks for your response
  16. Mar 23, 2021 at 9:02 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    On the plus side it only cost you about $1300 to learn what it took Toyota millions to find out
    JNG likes this.
  17. Mar 23, 2021 at 9:03 PM
    Beshaw1221
    Bruce
    So true
  18. Apr 2, 2021 at 6:05 PM
    Beshaw1221
    Bruce
    Just writing an update after trying two aftermarket exhausts. Mind you I have the TSB update and OV tune. First was the MBRP 3” catback. Super easy install, great sound but killed the low end. I expected some since I went up in diameter. Just recently uninstalled the Borla S type. Not so easy to install. The sound was minimal and the performance. Well let’s just say the truck was sluggish and actually felt like it lost power. Bottom line. The stock exhaust is tuned perfectly for the truck. I am back to stock and have two catbacks sitting in the garage, each with less than a month of use. Total of $1000 down the tubes.
  19. Apr 2, 2021 at 6:21 PM
    cspcrx
    cspcrx Well-Known Member
    21 TRD Sport 4x4 Cement
    So amazing how sensitive this motor is to back pressure based on what I am reading. The 2.4L Honda engines love 3in exhausts and see power across the entire curve from them. I’ve seen smaller motors like 1.5L and 1.6L not like anything over 2.25in and 2L not like anything over 2.5in. This a 3.5L I would think it would do fine with 3in. Very interesting!
  20. Apr 2, 2021 at 6:25 PM
    Beshaw1221
    Bruce
    There was a definite increase in torque on the high side with the cheaper 3 inch MBRP but the Borla which is the same as stock diameter was just not impressive at all. No low or high gains. Just a tinny bit of sound. These engines are definitely sensitive to scavenging and back pressure
