Slip indicator light and check engine light on!!! Need help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 67firebird, Nov 23, 2016.
  1. Nov 23, 2016 at 9:08 PM
    67firebird
    67firebird [OP] New Member
    Cody
    2010 TRD TACO
    Soo today I got my oil changed on my 2010 Tacoma as well as brakes and air filter and tires rotated when I got it back I went to the store and the slip indicator light and check engine light came on doesn't run weird or anything just didn't know if I should be worried going to thanksgiving tomorrow? Any help is apriciated!!!
  2. Nov 23, 2016 at 9:15 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I was reading a thread the other day where this happened to a guy (CEL and trac light at the same time) and it turned out it was his gas cap....check and make sure it's tight.
    Aside from that, get the code pulled so you at least have an idea what you're dealing with. Any auto parts store should be able to pull the code for you for free with their scanner, I know Pep Boys and Auto Zone will do it. Once you have the code, google it and post it up here so we can try to narrow it down.
  3. Nov 24, 2016 at 3:46 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    My sons car was getting the slip indicator light. it turned out that brake dust had accumulated on the sensors and was preventing them from working properly. Changing new brakes may have stirred up dust that needs to be cleaned.
  4. Nov 24, 2016 at 3:51 AM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Whoever performed the brake replacement could have moved or damaged a brake sensor. As stated above get the active code and post it in this thread so help and advise can be provided to all of us.
  5. Nov 24, 2016 at 6:04 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    What is a brake sensor?
    I have never heard them.
  6. Nov 24, 2016 at 6:06 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    OP go to auto parts store get the code read and post it back here.
  7. Nov 24, 2016 at 6:14 AM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    You sure you just didn't bump the button that turns off traction control? I know I've bumped that button on and freaked out for a second when the lights on the dash lit up.
  8. Nov 24, 2016 at 7:26 AM
    yazmatic
    yazmatic Well-Known Member
    Paul
    2012 DCSB TRD SPORT
    Bilstein 5100's Eibach 620 springs SCS Stealth 6 Matte Bronze BF Goodrich All Terrain TA KO2 265/70/17 SOS Front Bumper Full Hoops Safari AirFlow Snorkel
    Maybe he is referring to the ABS wire?
  9. Nov 24, 2016 at 7:30 AM
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    I had my "check engine" and "TRAC off" lights come on the day after I bought my truck. Turned out my ECM was bad and they had to replace it.
    I'm sure that isn't your issue... just thought I'd share.
    Patch Barracks likes this.
  10. Nov 24, 2016 at 7:33 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Good thought but that wouldn't explain the CEL
    Nickel[QUOTED] likes this.
  11. Nov 24, 2016 at 10:43 AM
    67firebird
    Cody
    2010 TRD TACO
    Po101 was the code thrown.... I cleaned several sensors then unhooked the battery and they both went away not really sure what was the problem didn't do any serious cleaning or anything???
  12. Nov 24, 2016 at 12:10 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    I'm getting a punctuation code from the ops' posts. Op, did you go back to the shop that did the work to ask them and give them a chance to check the truck out? Further, you didn't post what you had done to the brakes, but oil changes, air filters and tire rotations are very simple things. We have a pretty close community here, and if you lack the knowledge to do these things, I'm sure you'd be able to find local members willing to help. Welcome to TW.
  13. Nov 25, 2016 at 5:21 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Maybe? I don't know. I do know there isn't a brake sensor. :)
    yazmatic[QUOTED] likes this.
  14. Nov 25, 2016 at 5:27 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    DTC No.
    P0101
    DTC Detection Conditions:
    • High voltage:
    Conditions (a), (b) and (c) continue for more than 10 seconds (2 trip detection logic)
    (a) Engine speed less than 2,000 rpm
    (b) Engine coolant temperature 70°C (158°F) or higher
    (c) Voltage output of Mass Air Flow (MAF) meter more than 2.2 V (varies with Throttle Position [TP] sensor voltage)
    • Low voltage: onditions (a) and (b) continue for more than 10 seconds (2 trip detection logic)
    (a) Engine speed more than 300 rpm
    (b) Voltage output of MAF meter less than 0.83 V (varies with
    TP sensor voltage)
    Problem Area:
    MAF meter
  15. Dec 5, 2019 at 7:42 PM
    Venkman
    Venkman New Member
    South Dakota
    2010 Taco
    bilstein 5100 shocks, camburg upper control arms, and icon vehicle dynamics coil overs (3.5 inch suspension lift)
    I just had this happen to me today on my 2010 DC Tacoma Base that I purchased a few weeks ago. I just wanted to say thank you to you guys for posting this information as it definitely saved me a trip to the dealer at the least. After reading through everyone's comments, I disconnected the battery for 20 minutes and the codes have not returned in a little over a day so far. I did have the rear leaf springs and suspension inspected at the dealer for a recall on the leaf springs and I'm thinking something got bumped or a sensor was irritated enough to set off the lights. Again, brand new member and first time Tacoma owner, very grateful for everyone!
    Thank you from South Dakota!
  16. May 8, 2023 at 10:08 AM
    Claytor
    Claytor Well-Known Member
    Jebediah
    TX
    2010 4x4 Tiny Tank
    Regeard 4.56 on 35s w/Fox-remote resis. Icon delta UCAs. Relentless Armor-RCI skids-Wilco Tiregate.
    Just thought I would add. Same issue happened to me. Check engine light and slip indicator light came on. Also when I checked with a scan tool those 5 standard emission codes were being thrown.
    P043E, P043F, P2401, P2402, and P2419
    Disconnected my battery for about 30 min, snugged down the gas cap and cleaned the battery terminals.
    Reconnected the battery and all codes and lights have disappeared
    TomTwo likes this.
