Slight Vibration and Float Feeling in Steering Wheel
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xp0nex, May 29, 2023.
  1. May 29, 2023 at 4:17 PM
    xp0nex
    xp0nex [OP] Taco Noob
    2022 MGM TRD Off-Road DCSB 4x4
    I recently put some new wheels/tires on my OR and rarely ever drive because I WFH. I finally had a chance to take the truck on the highway and I noticed two things:
    1. I get a slight vibration in the steering wheel from 60-65mph. When below 60 or above 70 the vibrations go away
    2. Steering feels kind of “floaty” at above 60mph. Like it doesn’t feel “planted” like how it does if I am just street driving at 30-40mph
    Just hit 1600 miles on the truck and 200 of those are with the new wheels/tires. I know that the vibration is most likely related to tire balancing but I don’t know about the “floaty” feel that I get. I didn’t have any of these issues when I had my OE wheels/tires.
    Wheels: 17” SCS Ray10 -10 offset
    Tires: MT Baja Boss (265-70-17) bought and mounted at DiscountTire
    Suspension: No lift, stock OR suspension
    Does anyone know if that “floaty” feel is normal with negative offset wheels? Or a general idea of what I should look at?
    Should I bother with trying to get the wheels/tires re-balanced again or is it going to make very little difference?
    Kngu171 likes this.
  2. May 29, 2023 at 4:23 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    I don’t know about others experience but I once installed spidertrax 1.25 inch spacer on my stock off road with 265/75/16 tires. It’s similar if you have a negative 12 offset wheels . I hated how it drives. It’s just what you said . Seems to float oh freeway speed. Took it off and sold the spacer after a few days. The only difference is I didn’t feel any vibrations on the steering wheel at 60mph . My guess is it’s just the nature of the negative offset wheels. Another thing is it rides like crap. I can feel every bumps on the road. Rides like the tires are overinflated.
    xp0nex[QUOTED][OP] likes this.
  3. May 29, 2023 at 4:30 PM
    Clearwater Bill
    Billy
    Largo Florida
    I assume it's never been aligned, so you have no numbers to post. IIRC I read here that alignment was warranty covered for 1 year. Might be worth checking that out. Floaty feel *can* come from a couple of alignment quirks.
    But if you did not have these sensations prior to the wheel / tire package, that's 98.732% your issue. A re-balance should stop the shake unless there is a faulty tire.
    Then you might need an alignment whiz to dial out your float issue.
  4. May 29, 2023 at 4:35 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    For the floaty feeling...
    If you haven't had an alignment; get one. The factory alignment is not the best and everything has had a chance to settle in by 1,600 miles.
    Negative offset adds positive scrub...
    Positive scrub makes the tires toe out more when driven...
    You added about 1-3/8" of positive scrub...
    You'll want at least +0.05 toe-in
    Did you get E-rated or SL tires?
    What pressure?
    Did Discount mount them as assymetrical tires? They are marked "OUTSIDE"...
  5. May 29, 2023 at 6:16 PM
    xp0nex
    Nope, hasn't been realigned at all. I'll have to make some time to get it realigned and along with getting the tires re-balanced.
    I got the XL-rated and they did mount it with "OUTSIDE" being on the outside.
  6. May 29, 2023 at 6:21 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Along with the toe, to compensate for the scrub radius change you change ask for more camber, say 0.8*+ along with 2.0*left and 2.5* right caster and you should be good to go. Scrub radius change would for sure be my first suspect plus the increase in positive camber will help prolong your front end suspension from the offset increase of the wheels
    splitbolt[QUOTED] likes this.
  7. May 29, 2023 at 7:28 PM
    splitbolt
    NW Arkansas
    What pressure?
    Should be about 31 psi for 116XLs
    Chew likes this.
  8. May 29, 2023 at 7:30 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I also say alignment.
    A road force balance might also help with the vibrations.
    Try finding an off-road shop that does alignments. I got my first few alignments done at a normal wheel and tire place, then found an off-road shop that specializes in Toyotas ironically. They were able to get it aligned so it rode smoother than before.
  9. May 29, 2023 at 7:37 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Those MTs are pretty aggressive right? The treadblocks are designed to hug mud not pavement. That "could" be part of the floaty problem. But definitely get the balance rechecked
    cryptolime and Road_Warrior like this.
  10. May 29, 2023 at 7:54 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    mud tires tend to float a bit. a little vibration/float is normal with off road tires on pavement.
  11. Jun 22, 2023 at 9:08 AM
    xp0nex
    Finally having some time to bring the truck to get an alignment done tomorrow. What kind of numbers should I be looking for? I saw some numbers being thrown around in earlier posts and I know ever truck is different.
    Camber: Need slight positive camber?
    Toe: +0.05 toe-in on both sides?
    Caster: 2.0 - 2.5 on both sides?
    Again, I am on factory suspension with no lift and all I have are SCS Ray10 -10 offset and wrapped in 265/70/17.
  12. Jun 22, 2023 at 10:10 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    my front tires are wearing pretty badly on the outside edges. Got 26500 miles on them and the nylon threads are starting to show in between the tread blocks on the outside edge. my steering wheel is offcenter by about 2-3 cm but I thought that was an adjustment for the road crown. dealership said the alignment was okay at my first service when I noticed my steering wheel like that. kind of disappointed in the OEM tire treadlife. i got the Firestone Destination LE2s.
  13. Jun 22, 2023 at 10:20 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Have you checked your wheel bearings? My 2002 had a issue like that at speed and it was due to the wheel bearing on one side.
  14. Jun 22, 2023 at 12:31 PM
    xp0nex
    This all started after I put on the new wheels and tires. I am going to see what the alignment numbers are, get a re-balance, and then hopefully all is good.
    I was just curious what kind of camber, toe, and castor numbers I should be shooting for or should I just let the alignment guy do his thing.
  15. Jun 23, 2023 at 7:58 AM
    OnHartung'sRoad
    Sorry, can’t answer the alignment question. I just know that my new wheel bearing job went bad within 1000 miles and I had a serious tracking and float feeling when I was driving home from a long trip. Service center found that the wheel bearing on one side was shot and replaced them for free.
