Sliding glass window replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Norcalkid, Jun 26, 2010.
  1. Jun 26, 2010 at 7:57 PM
    Norcalkid
    Norcalkid [OP] Well-Known Member
    Jeff
    Willows ca
    99 prerunner sr5
    Icon coilovers, rear icon gas shocks with resevuar. 100 serries American eagle wheels wrapped in 33 in bfg ta's
    Hey long story short, Threw a piece of firewood in my bed it bounced up and busted out my right side slider window. Anyone ever replaced one before? If so what was the price and work involved? Sorry I've never done any kind of glass work before. It's a 99 taco prerunner sr5 king cab
  2. Jun 26, 2010 at 8:01 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    You will need a whole new back window and a window install company to install it. It's practically impossible for a DIYer to install glass without the proper equipment.
  3. Jun 27, 2010 at 2:03 AM
    MarineTacoDriver
    MarineTacoDriver Well-Known Member
    Brian
    Cherry Point
    09 SR5 4x4
    ARB front bumper, Warn M8000, ATO front/transmission/transfer case skids, Icon ext travel coilovers, Total Chaos UCA's, OME Dakar leaf springs, Bilstein/RCD 5100 3-4" lift shock, extended stainless brake lines, DrewFab shackle flip, rear ARB Airlocker, ARB air compressor
    $320 from safelite
    Edit: That price was for my second gen, not sure why this wasn't posted in the first gen section, price may be different
  4. Jun 27, 2010 at 6:39 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    Glass is usually covered by insurance for free
  5. Sep 19, 2010 at 5:15 PM
    Biscay89
    Biscay89 Member
    '01 Double Cab Sr5 v6 4x4
    Volunteer emergency vehicle
    I had a similar issue. Of the three panes that make up the rear window I just broke the center sliding glass one.
    The dealer said it would cost $375+ to fix.
    I ordered the part for around $170 and hope to do it myself.
    Curious if anyone else has tried and succeeded.
  6. Sep 19, 2010 at 5:29 PM
    Biscay89
    Biscay89 Member
    Thanks Oswego!
    Joining the forum already seems to be paying off.
    I am curious about the standard pricing. I was under the impression that the part I ordered was JUST the center sliding pane and not the whole rear window.
    Since i plan to do it myself any pointers/instructions/suggestions/how-not-to-make-a-small-problem-into-a-larger-more-expensive-problem tips would be appreciated.
    So far, I haven't seen posts for someone else who completed this project.
    Thanks again.
  7. Sep 20, 2010 at 6:59 AM
    samhain
    samhain Well-Known Member
    Brandon
    Hilton Head, SC
    05 Tacoma SR5
    Anyone have any experience with the electric windows? They seem like a nice upgrade. I hate reaching back to open mine.
  8. Sep 20, 2010 at 10:38 AM
    Biscay89
    Biscay89 Member
    Oswego,
    The dealer called me today to say they misquoted the part price. Turns out it the window would cost $500 so I think I'll go the route you suggest.
    Thanks again for your input.
  9. Sep 20, 2010 at 10:48 AM
    tonto340
    tonto340 Well-Known Member
    Gambrills, MD
    I put a back window in a 1st generation. Get a helper and 10-12 feet of 1/4" rope.
    Instructions
    Things You'll Need:
    • <LI itxtvisited="1">Flathead screwdriver <LI itxtvisited="1">Assistant <LI itxtvisited="1">15-feet of 1/4-inch rope
    • Slider rear window
    1. <LI id=jsArticleStep1 itxtvisited="1" sizcache="13" sizset="56">1
      Open the cab doors and use the flathead screwdriver to work the rubber seal around the back window out from the inside of the vehicle towards the outside. The flathead screwdriver can push the rubber lip out, then can be drug around the mounting lip to remove the rubber. Make sure the assistant is holding the glass from the outside while you are pushing out the seal. Then remove the back glass.
      <LI id=jsArticleStep2 itxtvisited="1">2
      Place the rope in the rubber seal around the slider window, leaving at least 12-inches of rope hanging outside of the rubber seal. Make sure the rope goes around the entire perimeter of the glass and stays in the channel.
      <LI id=jsArticleStep3 itxtvisited="1">3
      Place the window in the window channel on the cab of the truck with the excess rope on the inside of the vehicle. Have your assistant hold the glass in place while you move to the inside of the vehicle.
      <LI id=jsArticleStep4 itxtvisited="1">4
      Start to pull one end of the rope, parallel to the ground, while the assistant pushes the glass in towards the interior. This is going to pull the rubber seal out and around the factory lip, mounting the glass in place.
    2. 5
      Continue to pull the rope around the glass while the assistant follows you, pushing in the window. Once you've gone around the entire window, you may have to use the flathead screwdriver to pull some of the rubber seal towards the inside of the cab, just to clean it up a bit.
    Read more: How to Replace a Rear Window With a Slider | eHow.com http://www.ehow.com/how_5712977_replace-rear-window-slider.html#ixzz105pyZvwq
  10. Sep 20, 2010 at 10:51 AM
    TanSR5x4
    TanSR5x4 Hold my beer and watch this
    William
    Houston TX
    00 Tacoma SR5 4x4
    Deckplate mod, black KC slimlight fogs, hurculined bed, NRA sticker mod, painted rear chrome bumper black, black fender flares and front grill surround, HIDs, All-pro rear leafs and UCAs, Eibach coilovers, billys all around, flat black pro comps, 31x10.5x15 BFG KM2s
    damn those are expensive! a long time ago my friend locked his keys in his truck and he was talkin about breakin the small side window and my friend convince him the cheapest way to go would be to break the windshield lmao i didnt stick around to see it all play out but how crazy is that right?
    lol good luck with your repair tho
  11. Sep 20, 2010 at 11:13 AM
    korny351
    korny351 Well-Known Member
    Stockton, CA
    07 DCLB SR5 4X4
  12. Sep 20, 2010 at 11:20 AM
    Biscay89
    Biscay89 Member
    I thought the same thing. I'm surprised he didn't laugh when he said how much it would cost.
    I'm good with a 1st Gen version. My truck is a 2001 and still has a tape deck so to me, the electric version seems like it's ....from the Future.
    Oddly, I think that CRL location is the farthest away you can be and still be in the same state. Do they have one in Kentucky? I'll look around.
    Thanks
  13. Sep 20, 2010 at 12:01 PM
    Biscay89
    Biscay89 Member
    Oswego,
    CRL said they won't sell direct but put me in touch with one of their vendors.
    (L.K. Technologies)
    They are sending the same item for $329 cheaper than the dealer.
    I owe you a beer.
    Thanks.
  14. Sep 26, 2010 at 8:54 PM
    ryanr256
    ryanr256 Member
    Bob
    Cincinnati, OH
    09 base
    Escort 9500ix,Weathertech air deflectors on windows
    I was recruited to help with the install. By the time I got there the OEM window was already out.
    The new one went in surprisingly easy. So easy in fact we both looked at each other and said, "We did it wrong." Then Marty said, "I knew I should have videoed it. There isn't a good video of how to install the window."
    I suggested popping the window out just so we could reinstall it and video it. But we decided it probably wouldn't be so easy the second time so the window stayed put.
    -Bob
  15. Sep 27, 2010 at 12:28 PM
    Biscay89
    Biscay89 Member
    In response to all the great feedback I have received from this forum, I think it is only fair that I share how my broken rear sliding glass window situation was resolved.
    1) I received the replacement window from CL technologies the day after I ordered it. (Total cost with shipping was $171.48.) Oswego’s link & input saved me roughly $321 and their service was incredible.
    2) REMOVAL OF OLD WINDOW: I set aside Saturday afternoon to remove the old window and insert the new one. It was incredibly easy.
    a. From the inside of the vehicle, I lowered the rear seats (I have a double cab) and popped off the plastic covering just below the window frame.
    (Not entirely necessary but I wanted to see what I was doing.)
    b. I started on the right side at the bottom of the old window frame. Using a flathead screwdriver, I gently touched the metal of my truck frame below the gasket and worked the tip up until I could feel the upper metal edge under the gasket. With gentle pressure I lifted the screwdriver up, exposing the top of the metal windowframe. I used a second flathead screwdriver to hold the gasket up and used the first one again and inch further down the frame to do the same thing.
    c. Once about two inches of metal were exposed the gasket seemed to unseat itself. While just holding the gasket up, I set off a chain reaction that slowly moved around the window frame.
    I watched the rubber lip curl over the metal as it moved up the side and across the top of the window. The same thing happened to the left of my starting point and the gasket uncurled across the bass of the window frame. It looked smooth, harmless and less likely to damage the gasket so I just let it go.
    d. In just a moment the whole window popped free and while holding the open center pane, I set it down in the bed of my truck.
    e. Step one complete.
    3) INSTALLING THE NEW WINDOW
    a. This took about 10 minutes.
    b. The large channel in the gasket (where the metal of the truck frame goes) is pretty obvious. Into this channel you place a strand of 1/4” rope/cord. I had a 50’ roll but only needed about 14 feet. It should fit snuggly and deeply into the channel. I started inserting the rope at the bottom and worked my way around the window so that the beginning and end of the rope met at the bottom of the window frame.
    NOTE: I was careful to insert it such that “extra” cord didn’t bind and it laid neatly flat in the channel all the way around.
    c. I then sprayed some WD-40 onto the rope all the way around the gasket to facilitate removal and I can tell this helped.
    d. My helper sat in the bed of the truck and held the window in place by lining up the gasket channel (with rope inside) with the top of the metal windowframe.
    (In hindsight, I should have spent more time making sure the window was centered left/right but we eyeballed it and lucked out.)
    e. While he held the window in place, I gently pulled the rope which lifted the lip of the gasket as it came out from the channel.
    (He applied gentle pressure to the spot where I was working and that seemed to help.)
    f. As I pulled the rope, the gasket lifted and settled on the inside edge of the metal frame. As I pulled, I could hear my helper say he thought it wasn’t working.
    i. From my perspective it looked like it was working perfectly.
    ii. From the truck bed it looked odd until about half the rope was removed. The window appears to be sticking out too far then suddenly “drops in” or seats itself close to the frame.
    g. I continued to pull the rope until the gasket was completely in place and the window was seated properly.
    h. Then I stood there dumbfounded.
    In short, this was incredibly easy and the afternoon I had dedicated to this project was not necessary. The total job took about 15 minutes. We actually joked that we should remove the window and video tape it to post on YouTube. (I couldn’t find any videos that detailed this process) Knowing my luck though, I would remove the window again, rip the gasket or do something stupid that would make me open a new thread about ripped gaskets, removing scratches, or removing flathead screwdrivers from my forehead. Put simply, I decided to be happy with my progress and call it complete.
    So that’s it.
    Thanks again to Oswego for the part link and guidance, Tonto340 for the directions and thanks to Bob for the 3 hours you set aside but 8 minutes of help you needed.
    Biscay89
    Bonus question. If breaking the rear window costs a minimum of $171.48 then is it the cheapest window to bust in this scenario? Should I have taken out the windshield? Passenger window? For the purpose of this MYTHBUSTERS-like moment, let’s say you want to steer clear of insurance and pay out-of-pocket. Your keys are locked in your car, you have a rock and somewhere to be in 20 minutes. Which window do you take out to incur the least amount of repair cost?
  16. Sep 27, 2010 at 6:24 PM
    ryanr256
    ryanr256 Member
    Bob
    Cincinnati, OH
    09 base
    Not a problem. You know I'll do almost anything for free pizza. :)
    -Bob
  17. Oct 8, 2012 at 9:29 AM
    lbhartle
    lbhartle New Member
    biscay do you have a link for the company you purchased the window from? I am in a similar situation.
  18. Oct 8, 2012 at 9:43 AM
    amadougrand
    amadougrand Well-Known Member
    Southwestern Idaho
    Tacoma TRD Off-Road
    Long story short a friend busted my rear slider in my 09' DCSB. Since the frame was wrecked as well needed a complete window. The dealer quoted some ridiculous 1000+ price so I allowed him to put in an after market for 400. The end result is noticeably louder and I have regretted letting him do it ever since.
  19. Dec 10, 2013 at 5:36 PM
    siouxsie998
    siouxsie998 New Member
    Sioux
    San Bernardino mnt.s
    tacoma prerunner x-tended cab
    Were you able to just replace a single window. So far every one wants to replace the whole window. From $227 to > $500. Does any one know some one who will do just the left pane of glass. Dark tint. Thnx Sioux998
  20. Dec 10, 2013 at 5:37 PM
    siouxsie998
    Sioux
    :eek:
