Slide In Camper Tie Down Options
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ilmjetfuel, Apr 9, 2018.
  1. Apr 9, 2018 at 2:19 PM
    Ilmjetfuel
    Ilmjetfuel [OP] Well-Known Member
    Wilmington NC
    16 DCSB SR5
    Anyone have info on using Brophy tie downs for securing a slide in camper on a gen 3 taco? They appear to need at least a 2 inch over hang to work but the camper manufacturer swears they will work.
    https://www.crbrophy.com/tdhd.html
  2. Apr 9, 2018 at 2:52 PM
    CMillTacoma
    CMillTacoma Well-Known Member
    Craig
    Colorado
    2022 TRD OR SB
    285/70/17 Toyo ATIII with FSW 17" 4Runner pro wheels|Bilstein 6112/51100|Pop N Lock|Lomax cover|Kicker Speaker Upgrade|
  3. Apr 9, 2018 at 2:56 PM
    taoist
    taoist taoist
    Pete
    The Baraboo Range
    18 Sport ACLB
    Ilmjetfuel[OP] likes this.
  4. Apr 9, 2018 at 3:07 PM
    CMillTacoma
    Craig
    Colorado
    2022 TRD OR SB
    Here's a pic.
  5. Apr 9, 2018 at 3:09 PM
    Ilmjetfuel
    Wilmington NC
    16 DCSB SR5
    I was trying to avoid the frame mount idea thinking they would be shin busters. Any idea how much they protrude outside the bed walls? I do like the fast guns though, that may be the clincher to go with frame mounts.
  6. Apr 9, 2018 at 3:10 PM
    taoist
    taoist taoist
    Pete
    The Baraboo Range
    18 Sport ACLB
    They do not protrude when the camper is off.
  7. Apr 9, 2018 at 3:10 PM
    CMillTacoma
    Craig
    Colorado
    2022 TRD OR SB
    They slide out like an insert hitch when you're not using them so shouldn't hit them. When they're in I never hit them but they don't stick out that far.
  8. Apr 9, 2018 at 3:13 PM
    Ilmjetfuel
    Wilmington NC
    16 DCSB SR5
    So if they are retracted I could still run the truck through the car wash tunnel?
  9. Apr 9, 2018 at 3:15 PM
    CMillTacoma
    Craig
    Colorado
    2022 TRD OR SB
    The insert piece is well inside the outside line of the truck by 3-5 inches. Watch a video of how they work and you'll see what I mean.
  10. Apr 9, 2018 at 3:20 PM
    CMillTacoma
    Craig
    Colorado
    2022 TRD OR SB
  11. Apr 9, 2018 at 3:31 PM
    Ilmjetfuel
    Wilmington NC
    16 DCSB SR5
    BADAZZ! I'm sold on that setup for sure. that beats having to rig brophy's to be removable. What did you use for load management. I went with the firestone bags but I am hesitant on the compressor system I ordered. I was going to go with the ARB sytem but I ended up buying this...
    https://www.airliftcompany.com/shop/25572/
  12. Apr 9, 2018 at 3:37 PM
    CMillTacoma
    Craig
    Colorado
    2022 TRD OR SB
    I used Ride Rites and just ran the air lines so they came out together by the rear license plate, then I just used a bike pump to pump them up. Simple and cheap but it worked and I never had an issue in 12 years and two Tundras. I also put the TRD sway bar on and that made a big difference as well but that camper was 1300 pds unloaded.
  13. Apr 9, 2018 at 4:00 PM
    Ilmjetfuel
    Wilmington NC
    16 DCSB SR5
    Ha! I just cancelled the compressor all together after realizing that I have several options already for portable air. Ill use that dough for the Torklift system. Thank You!
  14. Apr 9, 2018 at 5:46 PM
    CMillTacoma
    Craig
    Colorado
    2022 TRD OR SB
    NP you'll be happy with this setup, really easy setup once you have everything adjusted after the 1st time.
