Sleeping in Access Cab?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jaymoussy, Mar 31, 2025.
  1. Mar 31, 2025 at 6:02 AM
    jaymoussy
    jaymoussy [OP] Well-Known Member
    Eastern MA, US
    '12 AC Base 2.7l 4a
    Is there any way to make arrangement to sleep in an access cab cabin?
    Traveling solo, I wish I could do that, when, say, it is too late to set up a tent, bedding.
  2. Mar 31, 2025 at 6:07 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I don’t know. Do you fit? It’s simple geometry.
  3. Mar 31, 2025 at 6:17 AM
    545 Well-Known Member
    2015 Access Cab
    Could yank the passenger seat and get some room to kinda lay straight
    I’d just sleep in the seat myself
    TXpro4X4 likes this.
  4. Mar 31, 2025 at 6:20 AM
    kidsmoke
    kidsmoke Well-Known Member
    Flyover Country
    '13 BR AC SR5 4x4 AT
    What's happening in the back? Topper and a sleeping deck makes all things possible.
    I'd think reclining in the passenger seat is the only real option, unless you're 4 1/2 ft tall...
    Gen3TacomaOBX and lowmower like this.
  5. Mar 31, 2025 at 6:39 AM
    tacobp
    tacobp Well-Known Member
    Bob
    North Carolina
    09 Tacoma, 2.7 automatic
    Installed a Pop n Lock,,That's it !..Bone stock
    I guess if you are four feet tall it will work !
    2015WhiteOR likes this.
  6. Mar 31, 2025 at 10:18 AM
    TacoTuesday1
    FL
    You could lay flat on the seat. It will not be comfortable. Or remove the right seat and put a bed which will also not have enough length like a double cab.
    or put a top and sleep in the back. Or a tent in the bed or on the ground.
    a Softopper offers pros and cons compared to a shell but it can also be quick and still sleepable.
    whether ST or shell sometimes you can find a good deal locally used.
    kidsmoke and lowmower like this.
  7. Mar 31, 2025 at 10:55 AM
    kidsmoke
    Flyover Country
    I've gone the softopper and deck route, and it's great. Added a mosquito net and the dog and I hop back there for 40 winks at rest areas on cross country hauls.
    hinmo24t likes this.
  8. Mar 31, 2025 at 11:09 AM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    Yes there is. I've seen it done in Scotland, but have not tried myself.
    Open front pax side door and then close it on the strapping of a hammock, close to upper curve near windshield.
    Open rear drvr side door (the "1/2 door") and then close it on the other end of strapping on same hammock, also upper rear-most portion.
    Knots in strapping keep them from pulling through door seals.
    Adjust the front seats to allow the greatest clearance. (drvr fwd to steering wheel, pax reclined to the rear. maybe?)
    Adjust the knots in the strapping to keep hammock off of center console. (shorten them most likely)
    It works.
    usmc2msu and SilverBulletII like this.
  9. Mar 31, 2025 at 11:10 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    If you had a tonneau cover, sleeping bag and sleeping pad you could simply slide in under the cover and be inconspicuous, dry and comfortable. Cab, not very comfortable and makes for a lousy next day with no sleep.
    riverrat958 likes this.
  10. Mar 31, 2025 at 11:25 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    You can't even sleep comfortably in a double cab unless you are super short like someone else said.
  11. Mar 31, 2025 at 11:42 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Unless you’re the size of a 3 year old, ya can’t do it. Get yourself a shell and you are good to go.
    Gen3TacomaOBX likes this.
  12. Mar 31, 2025 at 11:53 AM
    Ooze
    Ooze Member
    2018 Tacoma Sport
    Comfortably sleeping in the bed depends on the bed length and ones height.
  13. Mar 31, 2025 at 11:58 AM
    Sprig
    Ken
    Even if a short bed sleep on an angle and your good unless your 7’ tall. And if that’s the case he wouldn’t be asking about sleeping in an acc cab.
  14. Mar 31, 2025 at 12:05 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I'd sleep on the ground under the truck before I slept in the cab. It might be hard but at least it's straight and flat
    hinmo24t, skee and steveo27 like this.
  15. Mar 31, 2025 at 12:56 PM
    Pigpen
    Dan
    Northwest Montana
    Access cabs are all 6 foot beds.
    OP, I can't imagine relying on sleeping in the cab. I'm 5'7", maybe you're significantly shorter. For me, if the options are setting up a tent or sleeping in the cab, it'll never be too late to set up the tent.
    As others have mentioned, a topper and bed platform are ideal. Hotels too. I've been using them more as I age.
    davidstacoma and Sprig like this.
  16. Mar 31, 2025 at 1:00 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    IMG_3982.jpgMakes me want to take a nap.
  17. Mar 31, 2025 at 2:35 PM
    menoarenoniceguy
    menoarenoniceguy Member
    SoCal
    If you're tired enough...
    Steves104x4 and hinmo24t like this.
  18. Mar 31, 2025 at 3:38 PM
    SomeGuy_GRM
    SomeGuy_GRM Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    Nope. Op is more than the roughly 360 cu in interior.
  19. Mar 31, 2025 at 7:15 PM
    Homeline
    Homeline Well-Known Member
    2013 Access Cab 5-Lugger
    2" Leveling Kit, TRD skid plate, 16" Jeep wheels, Katzkin leather seats w/heaters, jump seat delete
    Think outside the box.....4" lift, ground mat and sleeping bag!
    Steves104x4 and kidsmoke like this.
  20. Mar 31, 2025 at 8:31 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    lol.
    I’ve sleep in the front seat of my access cab twice in my life and wouldn’t recommend it unless you’re really drunk.
    Recline the seat and hope for the best.
    Don’t expect your whole body to not hurt for the whole next week though.
    hinmo24t, kidsmoke and TXpro4X4 like this.
