Skid plate: steel vs aluminum
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Thunder Fist, Apr 4, 2017.
  1. Apr 4, 2017 at 7:10 PM
    Thunder Fist
    Thunder Fist [OP] Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Hey guys, I'm looking at the RCI front skid plate to replace the factory one. I know the aluminum is lighter, but is the lighter weight enough reason to spend the extra money?
    What are the advantages of one over another?
    Thanks.
  2. Apr 4, 2017 at 7:13 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    If you are crawling over a lot of rocks, I'd go steel. It slides better. Aluminum will gouge and grab the rocks. I have 3/16" steel skids on my taco, and 1/4" aluminum on the 4 runner. The aluminum ones has been dragged over dirt ruts and held up the truck just fine, but we only do light trails with the 4Runner. The aluminum is also great when you have to pull them off for whatever reason.
  3. Apr 4, 2017 at 7:14 PM
    Tatts521
    Tatts521 Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    Go steel. Much stronger but thats my opinion. I have the rci steel ifs.
  4. Apr 4, 2017 at 7:19 PM
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    Did you do bare steel or powder coat?
  5. Apr 4, 2017 at 7:30 PM
    Tatts521
    I painted it. Easier to touch up. So bare steel
  6. Apr 4, 2017 at 7:32 PM
    Tatts521
    Plus i have to weld about 6in more so my mobtown trans skid will bolt on to the ifs.
  7. Apr 4, 2017 at 7:33 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Personally anything that is going to smash things gets rattle canned. I've been over coating my skids with dupicolor bed coat, it looks nice and is easy to touch up. It has Kevlar, so it's bro rated.
    Custom Mid Plate
  8. Apr 4, 2017 at 7:39 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I would never run aluminum skids if your wheeling in the rocks. Dirt roads you should be fine but hitting rocks is a no go for aluminum skids.
  9. Apr 4, 2017 at 7:39 PM
    Wdwrkr
    Wdwrkr Well-Known Member
    Pete
    Nantucket MA
    2016 TRD Off-road DCSB
    None :-((. Yet :-))
    Steel. The weight is a small price to pay for the added protection. Mine (mobtown) are powder coated. I figure the bottom will need to be touched up, but I don't spend a lot of time laying on my back admiring the skid plates. I went powder to ensure the top face was sealed, figuring that if it bugs me it'll be a lot easier to touch up scratches on the visible face then it will be to deal with the a completely rusted upper face
    BradleyS, bobrown14 and bullaculla like this.
  10. Apr 4, 2017 at 7:46 PM
    tcjacado
    tcjacado Well-Known Member
    Steele, Steele and more Steele. I just bent my back bolt on the drivers side 30 degrees and gouged the hell out of it a few weeks ago. Trd, 1/4 IN Thick aluminum skid. It worked but wish I had gone steele.
  11. Apr 4, 2017 at 7:49 PM
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    Aluminum won't rust though. That's a big advantage.
  12. Apr 4, 2017 at 7:52 PM
    bullaculla
    Da big big island!
    3/16" steel plate will last longer than your frame.
  13. Apr 4, 2017 at 7:53 PM
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    Again though, won't it rust?
  14. Apr 4, 2017 at 7:54 PM
    Penten
    Penten Well-Known Member
    Peter
    Iowa
    Aluminum corrodes. Same thing different chemical reactions happening I believe
    t0nyvalenzuela and drewhaus like this.
  15. Apr 4, 2017 at 7:55 PM
    bullaculla
    Da big big island!
    Yes, if you are worried about rust, have it powdercoated. Most good powdercoat shops will do a zinc rich base coat, then a color top coat. Then you can just rattle can any gouges. That's how mine are.
  16. Apr 4, 2017 at 7:56 PM
    bullaculla
    Da big big island!
    Yes, raw aluminum will oxidize. And if you use stainless hardware, you get galvanic corrosion where the stainless contacts the aluminum.
    I just painted the 4Runner skids because of this.
  17. Apr 4, 2017 at 8:39 PM
    JTM1
    JTM1 Well-Known Member
    Justin
    West Houston
    99 PreRunner, 08 TRD OR DC, 16 TRD OR DC, 18 F150 FX4 5.0L
    99-Fabtech Lift, Fox coil overs, OME Dakar leaf pack, LCE Header and Pro Flow Exhaust, TRD Supercharger, 275/70-17 BFG AT KO 08-Bilstein 5100s, OME 885 Coils, Wheeler's 2"AAL, All-Pro Skid Plates, Shrockworks Sliders, 265/75-16 BFG AT KO2 16-Daystar Strut Spacer, SSO Slimline Hybrid Winch Bumper, All-Pro Skid Plates, Shrockworks Sliders
    An Aluminum skid will hold up to quite a bit of abuse, but it's service life in the rocks will be much shorter than a steel skid. If your primary goal is Forest Service roads with the occasional trip excursion, you'll be fine with aluminum. I was surprised by how many KOH cars run Aluminum backed HDPE skid plates.
    GPsevinSixx likes this.
  18. Apr 5, 2017 at 7:37 AM
    Dissent86
    Dissent86 Well-Known Member
    Ben
    2016 trd offroad Tacoma.
    As many have said it depends on your intended use, if your building a rock crawler go steel, if building a daily driver/expedition rig go aluminum! The only down side to aluminum is it will gouge and grab on the rocks.
    NightHawkTaco420 and EXTaco like this.
  19. Apr 5, 2017 at 8:31 AM
    ctfriel
    ctfriel @Overland_NC
    Winston-Salem, North Carolina
    2017 TRD OR AT (@overland_nc)
    Basic overland stuff...
    I'm happy with my aluminum RCI skids. Yeah they'll eventually fail but so will steel if you're beating on it hard enough.
    I've done enough rock crawling/bouncing to know that's not in the cards for this truck. In any event it handles rocks just fine.
  20. Apr 5, 2017 at 8:36 AM
    gunn_runner
    gunn_runner www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    The aluminum Pelfreybilt skid is 1/4" thick and beefy as hell. Sure, it's not steel and will dent if you drop the weight of the front end down on a big rock, but for light wheeling and even some hits it will do just fine.1.jpg 3.jpg 4.jpg 12.jpg 15.jpg 16.jpg
