Skid plate recomendations
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WesLikesTacos, Jan 20, 2022.
  1. Jan 20, 2022 at 1:21 PM
    WesLikesTacos
    WesLikesTacos [OP] Well-Known Member
    21 Cement OR DCLB 4x4
    I'm trying to figure out a skid plate upgrade from the ol stock off road tin ones that came on my truck. RCI has really got my attention. That said, has anyone thought to mix steel and aluminum when outfitting skids? Wondering if it's worth the weight to cost ratio to do it that way. I'm also wide open to suggestions on the skid plates. I don't do a ton of wheeling, but enough to warrant this upgrade. Thanks in advance
  2. Jan 20, 2022 at 1:25 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Aluminum is lighter and their Trans skid works with the TRD aluminum front skid. Steel will take a hell of a lot more abuse.
  3. Jan 20, 2022 at 1:29 PM
    anthemAnathema
    anthemAnathema Well-Known Member
    2013 4.0 6MT Access Cab TRD Offroad
    Elka 2.5 w/ DSC RCI Skids AP Expedition Leafs Leer 180
    I went all steel because it's cheaper and steel slides on rocks better. I could definitely feel the weight after installation on my 2013 4.0L 6MT though.
    Looking at my skid plates, which have taken a good bit of abuse, 75% of damage is to the tcase skid, so that may be the best one to stick with steel for.
    Tacolife5 likes this.
  4. Jan 20, 2022 at 1:30 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Get one that's in stock. Seriously
    Skydvrr, vivid02 and 71tattooguy like this.
  5. Jan 20, 2022 at 1:31 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Aluminum is more grabby, steel will slide on rocks aluminum will want to hold onto them.
    Steel is also a lot easier to beat back into submission and weld back up.
    Steel is heavier and will rust though.
    I have all steel but considering replacing my trans and transfer with aluminum as they don't see near the same amount of abuse.
    71tattooguy likes this.
  6. Jan 20, 2022 at 1:31 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Rci Steel Bamf Caliraised
  7. Jan 20, 2022 at 1:35 PM
    dirtydog57
    dirtydog57 Well-Known Member
    Colorado
    2019 SR
    I think the RCI looks better than the TRD and it’s made 30min from where I live. I went with aluminum because I think it looks better and it’ll be tough enough for 99% of what I do.
  8. Jan 20, 2022 at 1:42 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Aluminum, and made locally by Element here in Canada.
    OG_Tacoma and eurowner like this.
  9. Jan 20, 2022 at 2:27 PM
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    I did an aluminum front Skid and steel transmission and transfer case skid. Thought was that "usually" behind the front tires takes a bigger beating when you come off a rock or ledge.
