Size of bolts that attach the skid plate?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tcollins83, Apr 16, 2015.
  1. Apr 16, 2015 at 5:53 PM
    Tcollins83
    Tcollins83 [OP] Well-Known Member
    Trevor
    Ocala,fl
    '13 TRD Off-road dbl cab
    Window tint, k&n filter, painted grill.
    Anyone know what size bolts attach the skid plate? After my lift the installer threw mine away and I'm going to attempt to reinstall the stock skid plate post Rcd lift. I just need four bolts.
  2. Apr 17, 2015 at 3:00 AM
    imom
    imom Well-Known Member
    CAL
    2014 Regular Cab
    How many of these bolts are required? 4, 6, or 8? I just got some of the splash shield myself, but needed the bolts. I had the person I bought from and he told me the M8x1.25 as well...but I didn't ask how many bolts are needed.
  3. Apr 17, 2015 at 4:00 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Just buy 8.
  4. Apr 17, 2015 at 6:38 AM
    TakoJim
    TakoJim Well-Known Member
    Chula Vista, Cali
    2015 PreRunner Limited
    TRD STICKER ON BEDSIDE
    or count the holes at the skid plate.
  5. Apr 17, 2015 at 10:09 AM
    Tacotrd311
    Tacotrd311 Well-Known Member
    It only takes 4 bolts. However the two bolts in the front are longer then the two bolts in the rear that hold up the skid plate.
  6. Apr 17, 2015 at 6:25 PM
    imom
    CAL
    2014 Regular Cab
    Funny how the toyota catalog shows same part number for all the splash guard bolts? Figure it would be different part number for longer and shorter bolts.
  7. Apr 17, 2015 at 6:37 PM
    Tacotrd311
    Yea, I agree. I took mine off two days ago and the bolts are different lengths. Don't know why the part # would be the same unless maybe it comes as a kit of all 4 bolts?
  8. Apr 17, 2015 at 6:41 PM
    imom
    CAL
    2014 Regular Cab
    When you say 4 bolts...do you have two splash shields...there's the upper and lower or do you only have just the upper shield? The upper is for the engine and the lower is for the oil pan and tranny. So do I really only need 4 bolts, 6 bolts ( 2 bolts for each piece and 2 bolts connects the two pieces together), or 8 bolts so it's 4 bolts per splash shield?
    Unfortunately the the bolts come as singles and EPC shows it as same part number hence my confusion and confusion on how many bolts I need.
  9. Apr 17, 2015 at 7:14 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    The front guard needs four bolts. I can't remember how many for the oil pan guard.
  10. Apr 17, 2015 at 11:01 PM
    imom
    CAL
    2014 Regular Cab
    Thanks...okay I'll buy 8 then... just wasn't sure if 4 was enough. Thanks for the help everyone and especially to OP for posting question!
  11. Apr 18, 2015 at 3:11 PM
    Tacotrd311
    I have both guards, the big one that covers the engine and the smaller splash guard that sits inside the bigger one. Mine only uses 2 bolts in the front and 2 in the back. The smaller guard rest on hooks and then gets bolted to the truck with the bigger one covering it, using the same bolts.
  12. Apr 21, 2015 at 3:16 PM
    imom
    CAL
    2014 Regular Cab
    Thank you for the clarification... interesting how only 4 bolts will be enough to hold it and even with the hooks. Figured 6 or 8 to ensure it's all bolted down...but hey 4 it is...thanks again.
