Siphon pump used for PS drain and fill
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FR2797, Nov 18, 2023.
  1. Nov 18, 2023 at 2:39 PM
    FR2797
    FR2797 [OP] New Member
    I purchased a new siphon pump to drain my PS reservoir and after I suctioned the reservoir to near empty I noticed a little bit of white smoke coming out. It was very faint, but I believe the suction pressure may have been too much. It hasn't happened since and my levels are normal. I've driven her around 40 miles now and checked again and nothing has changed? Should I be concerned?
  2. Nov 18, 2023 at 4:24 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Hope you didn’t intrude air in the system
  3. Nov 18, 2023 at 5:02 PM
    FR2797
    I hope not. I inserted the suction hose end into the reservoir, no air pushes out from that end. The air comes out through the other end of the pump. What should I look out for in case that might've happened?
  4. Nov 18, 2023 at 5:27 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It's fine. Don't worry about it.
    Seriously, You didn't hurt anything.
    Next time, just jack the truck up and turn the steering wheel left and right a few times to "prime" rack and pump.
    But you are fine, Don't worry about it.
    bulalo and FR2797[OP] like this.
