Single Pole Double Throw (SPDT) OEM Style Switches?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by steveo27, Jan 3, 2017.
  1. Jan 3, 2017 at 9:27 PM
    steveo27
    steveo27 [OP] Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Long story short - I wanna redo my LED light bar wiring. It currently has a SPST (single pole single throw) switch and I wanna change it to a SPDT switch.
    Im looking for a SPDT switch thatll fit the OEM slots below the HVAC panel. Ive seen ones that fit to the left of the steering wheel, but never under the HVAC panel. Im looking for something OEM looking.
    Air On Board seems to only sell SPST switches.
    Im also kicking around the idea of modifying the OEM blanking panel by adding a SPDT switch into it.
    Has anyone else out there in Tacomaland found a SPDT switch that fits below the HVAC panel?
  2. Jan 3, 2017 at 9:35 PM
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Are you looking for an on-off-on configuration that can power two lights from one switch?
  3. Jan 3, 2017 at 9:47 PM
    steveo27
    Pittsburgh
    Kinda.
    I need an on/off/on that can pull 12v+ from 2 different sources.
    The 12v+ source to the light bar switch is currently supplied by 12v+ switched high beam trigger. The light bar can only be used when the high beams are on.
    Ive decided I want to change this and add the option of being able to control the light bar independent of the high beams if need be. Im going to run 12v+ constant (straight from the battery) to the other side of the SPDT switch.
  4. Jan 3, 2017 at 10:16 PM
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Not aware of any SPDT switches for the lower blanks that have an OEM look. You could use a SPST switch and 2 relays though. That would open up a ton of switch options.
  5. Jan 4, 2017 at 3:35 PM
    steveo27
    Pittsburgh
    I didnt think there were any.
    How would the 2 relay SPST switch work?
  6. Jan 4, 2017 at 4:18 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    DPDT will work also just use one side.
  7. Jan 4, 2017 at 4:24 PM
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Will come on with high beams and also with a dash switch. Would need a latching style switch not a momentary.
  8. Jan 4, 2017 at 9:47 PM
    steveo27
    Pittsburgh
    Thanks for the diagram, but Id still need a switch between the relay and the high beam trigger so the light bar doesnt always come every time the high beams are on.
  9. Jan 4, 2017 at 10:16 PM
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Ah ok I thought you wanted the light bar to always come on with high beams and just add switch trigger in addition to that.
  10. Jan 5, 2017 at 5:23 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    SPDT center off.
  11. Jan 5, 2017 at 9:29 PM
    steveo27
    Pittsburgh
    Thats what the original post says....
    No prob. I appreciate the help:thumbsup:
