Simple Scangauge II Mounting Mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Detective_Dan, Jan 19, 2011.
  1. Jul 17, 2011 at 7:55 PM
    #81
    Oysterhead
    Oysterhead Well-Known Member
    Nashville
    '10 TRD OR
    Kings are king
  2. Oct 4, 2011 at 8:35 PM
    #82
    bridaw
    bridaw The light was yellow, Sir.
    Brian
    SoCal, East San Diego County
    10 DC 6-speed TRD OR 4x4 tow debadged
    tailgate hose clamp/washer mod ,disable seatbelt warning ,dealer tinted windows ,running boards ,DiamondBack SE bed cover ,OEM rubber bed mat ,TRD Japan shift knob ,bed rail corner reinforcement with angle brackets+square nuts ,Armor Tech Offroad mount for 60" highlift jack ,Scangauge II ,OEM roof rack ,BajaRack basket ,WeatherTech dark tint window deflectors ,removed mud flaps ,debadged ,stubby antenna ,D-rings - 4 in bed floor + 8 on the side rails ,cut four D-ring slots in bedmat ,secured ActionPacker 48 gal cargo box to bed ,center console lock ,relocated 7 pin harness ,Redline Tuning QuickLIFT Elite hood supports ,Pop & Lock PL5300 tailgate lock ,RAM A-pillar mounts for GPS and Drift HD170 camera ,RAM mounts on bajarack for Drift HD170 exterior shots ,relocated rear differential breather ,headrest iPad mount ,ImMrYo rear view mirror lift ,Panavise Indash mount ,265/75/16 BFG All-Terrain T/A KO on TKO black rims ,installed front and rear WeatherTechTacoma DigitalFit FloorLiners ,replaced interior/external lights with Jumpers LEDs +switchback mod +under hood light ,installed rcbs204 Illuminated 4x4 Switch ,installed left and right Relentless Off-road Fabrication hood hinge light mounts ,installed KB Voodoo's Powder Coated Tailgate Cap System ,installed front and rear Wet Okole seat covers ,made and installed mount for Trail Toys NSA Switch Panel ,did ND4's Fog Light Anytime Mod
    I purchased my Scangauge II along with the blendmount. I found this thread after I realized the mount would not fit my mirror due to the bulge of the hands-free microphone. I keep my mirror as high as I can so it just doesn't leave room for the scangauge.
    You folks with the idea of using clips -pure genius! I'm tall so clipping my scangauge straight to the headliner wasn't the best angle so I came up with a hybrid approach.
    Since I already own the thing I bent the blendmount into a "z" and attached a single tape measure clip using a small screw and nut. I attached the single clip at an angle so the gauge faces me. I wrapped a bit of "rescue tape" around the part of the mount that comes in contact with the headliner. This covers the screw head to protect the headliner but the added friction keeps it solid. I ran the cord up the pillar and headliner and bent it away from the windshield so it doesn't come in contact.
    It has been hanging this way for about a year but the other day I decided to snap a few pics for this thread. I tried to take the first picture at about eye level but since it is in front of my face the angle might look a bit screwy. The angle really is perfect for my eyeballs and it is easy to see right by the mirror. It overlaps slightly but doesn't block my view behind the truck. The second shot shows the gauge/mount are not coming into contact with my mirror.
    The pictures suck since they are downsized cell phone shots but you get the idea.
  3. Oct 22, 2011 at 2:21 PM
    #83
    Whitster
    Whitster Well-Known Member
    Whit
    Golden, CO
    '09 AC w/SR5 & TRD, 6' bed
    Just got my Scangauge II in the mail today. While looking for a place to mount it I noticed the headliner fabric, itself, plays well with Velcro hook fastener. I stuck a 4" length of Sticky Back Velcro hook material to the top of the ScanGauge II, and tried it, it grabs like crazy and doesn't unravel the fabric upon removal...kewell.
    I removed the handle on the "A" piller and the cover revealing all kinds of room underneath and below. Ran a fish wire down to pick up the small connector (had to remove the coin pocket to aid fishing). Then ran the fish wire horizontally above the headliner to the ScanGauge II positioned between the mirror and overhead console. The cable has about 6" to 8" left over which I tucked up above the headliner.
    This works well and is easily relocated to any viewing angle desired. Also easy to remove and move to another vehicle if another cable is available.
    PS - That's a Valentine V-1 radar detector lurking over on the upper-left corner of the windshield behind the sun tint band.
    Whit
  4. Oct 23, 2011 at 11:58 AM
    #84
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I tried that and it would only stick for a day or two. I ended up putting one clip in the center and two velcro hook sections on either side to hold the angle, and that worked for me. Also I just used one clip that i had and I didn't want to go find another one.
  5. Oct 23, 2011 at 2:12 PM
    #85
    Whitster
    Whit
    Golden, CO
    OK, I can see how that might happen. After your post I checked with other Velcro I had...there seems to be two different kinds of Velcro out there. One has real fine teeth and one with coarser teeth (hooks).
    I used the fine teeth, lucked out. Mine might fall off too, but so far it's still hanging in there.
    P.S. Been almost 5 months now and the fine-meshed Velcro is still hanging in there, hasn't fallen yet.
    Whit
  6. Mar 12, 2012 at 1:32 PM
    #86
    HolyReptar
    HolyReptar Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    OP you just made me decide to buy the scan gauge
  7. Mar 12, 2012 at 3:39 PM
    #87
    Fire Taco Fighter
    Fire Taco Fighter Well-Known Member
    trd
    That is awesome!! WELL DONE..
  8. Mar 12, 2012 at 4:12 PM
    #88
    SVHANC
    SVHANC Kermit
    Sam
    Knoxville, TN
    '10 4x4 5sp 4cyl Access Cab
    Weathertech Floor Liners, Scangauge 2, Tailgate Hose Clamp, Rear Seat Headrests Removed
    I just stuck the velcro to the top of the scangage, roughed up the headliner a little and stuck it directly to the ceiling. It has been there 2 years without a wiggle.
    Sooner or later I might have to relocate, but for the time being I saved 2 dollars...
  9. Mar 13, 2012 at 10:06 AM
    #89
    Detective_Dan
    Detective_Dan [OP] "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    Thanks man
    Whatever works man!
    Glad i could help hahaa
  10. Apr 11, 2012 at 5:21 PM
    #90
    gsxrdoug
    gsxrdoug 2009 X-Runner
    Douglas
    Hawaii
    2009 X-Runner
    Stock
    I'm so glad I found this. I hate looking at my uneven gauge on top of the mirror with white 3m tap holding it, now I can have a very clean look. Thanks for the ideas.
  11. Apr 12, 2012 at 12:06 AM
    #91
    Marnes2986
    Marnes2986 Well-Known Member
    Mark
    Anaheim-Corona, Ca
    A little off-topic, but before i buy one I want to confirm that the SCII will be able to read Trans Temp on my 05 taco.
    Ive read conflicting threads, but on the SC website under X-Gauge commands there is a command for 05+ trans temp? :confused: please help
  12. Apr 12, 2012 at 2:42 PM
    #92
    Detective_Dan
    Colorado Springs
    Mine dos not read grand temp bit I know you can update the SGII through their website so they might have gotten a map for trams temp. Contact them to be sure
  13. Oct 25, 2012 at 8:47 PM
    #93
    JRFugitt
    JRFugitt Well-Known Member
    Justin
    Texas
    '13 PreRunner V6
    One of the best ideas i've seen yet on this forum, and there have been some good ones!
  14. Oct 26, 2012 at 12:09 AM
    #94
    Detective_Dan
    Colorado Springs
    thanks justin
  15. Oct 26, 2012 at 12:11 AM
    #95
    Detective_Dan
    Colorado Springs
    almost 2 years later and the original double sided tape is still holding strong!
  16. Nov 3, 2012 at 11:54 AM
    #96
    brian2010
    brian2010 Active Member
    Brian
    VA
    2010 TRD Sport 4X4 Double Cab Long Bed
    Scanguage.....i'm working on more lol
    Took me 30 minutes with the dremel to cut out the space for it, but the compartment still closes fine. I posted in my own thread, but came across this and thought it more appropriate to repost here.
  17. Jan 19, 2014 at 12:47 PM
    #97
    Captain Nemo
    Captain Nemo Well-Known Member
    20K Under the Los Angeles Sea
    '10 Access Cab TRD Off-Road
    ARB bumper w/ TJM winch, All Pro rear bumper, BudBuilt skid plates, DeMello Hybrid sliders, IPAA spotlights, Icon Stage 2 Suspension Lift Kit, 285/85/16 BF Goodrich AT, FJ TRD Trail rims, Optima dual battery w/ Wrangler solenoid, Wet Okole seat covers, BakFlip CS-F1 tonneau
    Excellent mod! I did the same thing as OP, except with epoxy instead of velcro. It seems snug and tight.
  18. Jan 19, 2014 at 4:11 PM
    #98
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    I did the same thing yesterday. Took less then 10 mins to do. BTW thanks to the OP for the original idea :thumbsup:
  19. Jan 19, 2014 at 7:03 PM
    #99
    Detective_Dan
    Colorado Springs
    Glad it worked out for you nick!
  20. Jan 30, 2014 at 9:24 AM
    #100
    BIDZ
    BIDZ Member
    Andy
    KY
    12' TRD Sport DCLB MGM
    Weathertechs, 13" AntennaX, Auto Vent Shades, 886 Reverse Light Mod, LED Bed Lights, Fatmat rear wall and doors, Painted Calipers Red, 20% tint all around, Blacked-out front emblem, Bilstein 5100s +885 + Deaver AAL, Goodyear Duratracs 265/65-17 on Fuel Vapors....
