Simple Green in Pressure Washer???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JayTaco, May 7, 2015.
  1. May 7, 2015 at 5:04 PM
    JayTaco
    JayTaco [OP] Well-Known Member
    Evening folks,
    Trucks are covered in pollen and spring grime (sap etc...) Has anyone applied simple green on the low pressure setting and then rinsed off using a pressure washer? I guess I am looking for a quick way to get the bulk of the grime off before hitting it with a sponge. Worried about using the sponge and rubbing the grime into the paint creating swirls etc... Flame me if you will but want to avoid a nasty mistake on the soft paint.
    One is silver streak and the other silver sky.
    Thanks in advance for any help...
    Jay
  2. May 7, 2015 at 5:05 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Just use a spray bottle and spray SG on (diluted) and let it sit 5 minutes. Then rinse. Reapply SG as necessary.
  3. May 7, 2015 at 5:09 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Do it in the shade on cool body work. Then wax the living shit out of it.
  4. May 7, 2015 at 5:25 PM
    GSHEP4
    GSHEP4 Well-Known Member
    Lehighton, PA
    2014 spruce mica sport
    s/c,fluid film, bug shield, window vents, under hood lights, bed lights, tailgate reinforcement, and more.
    Spray it on my motorcycle in the fall to remove bug grime. Always worked well. It will remove all your wax though. Do as Steves says.
  5. May 7, 2015 at 7:48 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Do what Steve said and make sure you dilute the SG.You'll need to do a polish and wax especially if you don't dilute the SG enough because the surface area may dull or fade.
  6. May 7, 2015 at 7:52 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    I use hot water and a terrycloth hand towel. IMO Simple Green is pretty strong stuff. It kicks ass on everything else in my kitchen. Even cleaned my oven. I personally wouldn't use it on my truck.
  7. May 7, 2015 at 7:55 PM
    T4RFTMFW
    I've used it on vehicles for years and never had an issue. From my truck to a 2012 Peterbilt.
  8. May 7, 2015 at 8:04 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    I guess-I have seen it being sold at the auto stores. But I am just going off my own experience with the stuff.
  9. May 7, 2015 at 8:26 PM
    W Bishop
    W Bishop Stupid should be painful!
    Stone
    South Fulton Tn
    2013 Tacoma 4X4 Reg Cab
    ToyTec coil over kit, Sliver Coils, Bilstein 5100 front & rear, Light Racing SPC UCA. Painted to match Coils, OEM Tacoma 4 leaf pack, Undercover, AFE Pro Dry air filter, Painted grill surround, FJ Cruiser Trail 17" wheels, Rubber bed mat, fog lights and sliders.
    Started using SG on the windshield to get the bug juice off. Works great. Have used it on the front bumper if I am going to detail the entire truck. Don't think I would use it on my entire truck but to each their own.
  10. May 7, 2015 at 8:37 PM
    T4RFTMFW
    I've used it on dashboards, grills, painted surfaces, glass for over 10 years and no problems on anything. More than 15 vehicles. :notsure:
  11. May 8, 2015 at 4:14 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Same concept as using a foam gun. I dont think theres a need to give your truck a simple green bath though. Just use soap. It'll help rinse off the loose stuff, which is enough. Then wash as you normally would.
