Simple DIY Bed Platform
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MrCrobb, May 22, 2015.
  1. May 22, 2015 at 7:33 PM
    MrCrobb
    MrCrobb [OP] Well-Known Member
    Connor
    San Diego/San Jose
    06 TRD Sport
    Snug Top Camper Shell, Black Anzo headlights, OME 884 + Dakars
    I made a bed platform the other week for a camping trip I went on. I thought I'd make a quick DIY thread on it, in case anyone's interested in building one. Overall, it cost me about $200 to build (not including the jigsaw, which I already had). The most expensive part was the (optional) mattress pad, which cost about $110 at Cotsco.
    Parts:
    x2 3/4" Plywood (8ft x 4ft)
    3M 90 Adhesive Spray
    Roll of Carpet
    3" Full Size Mattress Pad
    Tools:
    Jigsaw
    Measuring Tape
    First thing I did was have my plywood pieces cut into 3 planks that measured 20" x 56.5". * If you have a 6ft bed, you'll probably want to have the 3 planks cut to 24" X 56.5". If you don't have a large table saw, I'd recommend having someone at home depot (or wherever you buy your plywood) cut the pieces for you. Usually the service is free. I found that 56.5" wide fits the truck best, allowing a little bit of play between the wood and the sides of the truck bed. This way, the pieces are easy to move in and out of the truck.
    The next thing I did was measure the the angles of the the truck bed near the tailgate. This is where the lip of the bed tapers off. Now you'll need to make a few precise cuts with the jigsaw. Be sure to get good measurements and draw out the cuts on the plywood before you go hacking away at it. I had to trim the edge off the third piece, making it 18.5" long (instead of 20"). You should only have to do this if you have a short bed. If you plan ahead, you could cut this off when you first cut the three pieces of plywood, making one plank measure 56.5" x 18.5".
    Now that you have the 3 planks sized correctly, you can cover them in carpet. I cut the carpet so it had enough length to wrap around the edges of the plywood. This gives it a cleaner look, imo. I then covered the tops of the planks and the bottom of the carpet with 3M 90 and pressed them together. Now the pieces should all fit nicely into the back of the truck!
    The tailgate should be able to close flush with the platform, as long as you measured everything correctly. Now you can put the mattress pad on top, to make a nice sleeping platform. If you have a short bed, you'll have to cut the mattress pad to fit.
    The one problem with this design is that when you put pressure on the edge of the plank closest to the tailgate, it causes the plank to push upwards, since theres no lip on this part of the truck bed to support it. To counteract this, I added a little piece of wood on the edge to clip the other plank. This was sort of a last minute fix... There are definitely better ways to fix this problem. But here's a pic of how I did it.
    I've seen plenty of other more elaborate designs for bed platforms, but this simple design also gets the job done. The 3/4" plywood is pretty sturdy. My girlfriend and I slept on it for a couple nights with no problems. Combined we probably weigh a little less than 300lbs, and we also had the weight of the mattress pad on there. Splitting it into three planks also makes it easy to stack them on top of each other, or lay them flat along the bottom of the truck bed if you need the extra space. Sleeping in the back would definitely be comfier with a 6' bed, but I can fit in the short bed if I lay somewhat diagonally, and I'm 6ft. It was tight with two people.... But we made it work! The mattress pad makes it surprisingly comfortable.
    Hope this helps!
  2. May 22, 2015 at 7:54 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Did you use any 2x6s or no?
  3. May 22, 2015 at 7:59 PM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    Nice write-up.
    I personally prefer having headroom and since the distance between the wheel wells is an inch wider than a standard twin size bed I am anti-bed platform:rofl:
    ..but srsly nicely done man you'll get lots of great camping use outa that thing.
    MrCrobb[OP] likes this.
  4. May 22, 2015 at 8:04 PM
    MrCrobb
    Connor
    San Diego/San Jose
    06 TRD Sport
    No I didn't use any 2x6s. If it looks like it needs reinforcement over time, maybe I'll add something. But it seems sturdy enough as is.
    And thanks Wheelinthesky. The platform gives me a little extra space diagonally, since I can lay on top of the wheel well. If i had a long bed, I wouldn't need as much space.... but oh well haha. Its also cool to be able to store stuff under the bed. there's about 9" of clearance underneath
  5. May 22, 2015 at 8:07 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Cool idea. Think I'd want more structure to the plywood. Over time I would think it would start to bow/sag a bit.
    But now you can slide your camping gear under the platform and still have a place to sleep.
  6. May 22, 2015 at 8:10 PM
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    Looks good and easy to construct.
  7. May 22, 2015 at 8:38 PM
    Sje1124
    Sean
    Louisiana
    Just a few
    That's awesome man. It looks good and I really appreciate you making this.
  8. May 22, 2015 at 9:31 PM
    MrCrobb
    Connor
    San Diego/San Jose
    06 TRD Sport
    Ya no problem!
  9. May 23, 2015 at 1:50 AM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Looks good OP!Nice write up!
  10. May 23, 2015 at 11:38 AM
    MrCrobb
    Connor
    San Diego/San Jose
    06 TRD Sport
    Those bins are pretty sweet DoorDing. I like your build. I was thinking about adding a fold out extension at the foot, like you did
