Silverado rims?
Discussion in 'Wheels & Tires' started by TRDGoatFarmer, Apr 24, 2010.
  1. Apr 24, 2010 at 5:30 AM
    TRDGoatFarmer
    TRDGoatFarmer [OP] Well-Known Member
    Ohio
    2005 Toyota Tacoma SR5 V6 4x4 ( all stock)
    Moto metals, Toyo Open countrys, K and N CAI
    Hey guys,
    I tried searching this, but nothing came up.
    I heard a rummor that Chevy Silverado 1500 6 lug rims bolt right up with a 2005 toyota tacoma 6 lug pattern??
    I found some silverado rims that I reaaaallly like.. and im about to buy them. I just wanna make sure they will fit before i go out and blow 500.00!! ha.
    thanks!!
  2. Apr 24, 2010 at 5:34 AM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    Couldn't tell you if they fit but it might be awkward with the bowtie in the center
  3. Apr 24, 2010 at 5:37 AM
    TRDGoatFarmer
    Ohio
    There not factory silverado rims, there aftermarket.. ha
  4. Apr 24, 2010 at 6:06 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    IIRC, the other way from toyo to chevy would work for sure...hub size for chevy is smaller than toyo's. if the aftermarket wheel was designed to fit more then just chevy's, then you may be ok. best way to be certain is a test fit
  5. Apr 24, 2010 at 6:13 AM
    2kool4school
    2kool4school Well-Known Member
    Beau
    Honolulu, HI
    '12 JKU Sport
    if that is true then they are not "silverado" rims, they just fit on a silverado
    bolt pattern 6 on 5.5 has always been Chevy, Toyota, Nissan but yes the hub is what your going to have to worry bout clearing in the front
  6. Apr 24, 2010 at 7:21 AM
    TRDGoatFarmer
    Ohio
    Okay. thanks yall!
    But, ya see i come from mostly atv and dirtbike back grounds ( motor, and mechanics wise) and doesnt the wheel sit on the hub? so how would it have to worry about clearing it..?
  7. Apr 24, 2010 at 7:33 AM
    2kool4school
    Beau
    Honolulu, HI
    '12 JKU Sport
    different brands/models the hubs are different sizes, if the hub on the tacoma is larger then the one on the chevy then more than likely it wont clear it. i guess you can say that it sits on the hub, more fits around it
  8. Apr 24, 2010 at 7:36 AM
    The_Hodge
    SC
    ^^ yup yup...different vehicle manufacturers use different hub sizes for different vehicles. the bolt pattern may be the same, but it doesnt mean the hub is.
  9. Apr 24, 2010 at 8:52 AM
    TRDGoatFarmer
    Ohio
    Well, i guess there is only one way to find out if they fit.. try em on! ha
  10. Apr 24, 2010 at 9:20 AM
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    pinto
    33" mudders
    you can always use spacers
  11. Apr 24, 2010 at 11:19 AM
    2kool4school
    Beau
    Honolulu, HI
    '12 JKU Sport
    no you cant, unless you want them to fail really quick
