Silicone or butyl tape for weather-proofing bed?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by matttrent, May 31, 2020.
  1. May 31, 2020 at 2:33 PM
    matttrent
    matttrent [OP] Active Member
    Trent
    Oakland, CA
    2019 Tacoma OR Access
    I'm prepping my truck to put a shell on the back. After searching around here, I feel I have a handle on tailgate seal, sealing the bed cubbies, and plugging the front corners.
    But I was curious what folks used for sealing underneath the bed rail covers and under the header rail. The 2 two options I've seen discussed for those places are marine silicone and butyl tape.
    If you've sealed yours, which did you choose and why?
    Did you use aluminum tape as well?
  2. Jun 2, 2020 at 6:55 AM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Butyl all the way!
    matttrent[OP] and shakerhood like this.
  3. Jun 2, 2020 at 7:08 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I did the same before I installed my Softopper. I cleaned and touched up the paint. There were some wear spot and I only had a tonneau on there.
    I then laid down some thick foil tape and silicone on top of that. About the only thing that I would do different is go heavier than the beads that I used.
    matttrent[QUOTED][OP] likes this.
  4. Jun 2, 2020 at 10:00 AM
    Lunabird
    Lunabird Well-Known Member
    Butyl! it never shrinks and is water tight
  5. Jun 2, 2020 at 12:16 PM
    joesrcool
    joesrcool Well-Known Member
    Joe
    2019 Tacoma TRD Off Road
    I did both. Butyl for the bigger gaps and silicone for the small stuff. Pull off your plastic bed caps and bed rails, run some silicone under those and re-install.
    matttrent[OP] and tonered like this.
  6. Jun 2, 2020 at 12:23 PM
    matttrent
    Trent
    Oakland, CA
    Thanks for the post showing.
    tonered[QUOTED] likes this.
  7. Jun 2, 2020 at 12:23 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome! :hattip:
  8. Jun 2, 2020 at 12:27 PM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    Can you share what you did for the tailgate seal? The things I have tried have worked but only temporarily. Any adhesive backed foam or silicone seal/gasket hasn't stayed stuck
  9. Jun 2, 2020 at 12:29 PM
    matttrent
    Trent
    Oakland, CA
    Also, I got ahold of a buddy that lives on a sailboat. He said that after the first few years of messing with silicone, he's transitioned to butyl tape for everything above the waterline. He strongly recommended Bed-It brand as better than any other butyl tape he's encountered. So I think I'll use that for all the places I was still considering silicone.
    https://shop.marinehowto.com/products/bed-it-tape
    He's currently sailing from Mexico to Hawaii, so his endorsement that the stuff holds up to real ocean travel is good enough for me. Hope it's helpful for other folks.
    RoughRder and tonered like this.
  10. Jun 2, 2020 at 12:30 PM
    matttrent
    Trent
    Oakland, CA
    An adhesive backed foam is what I just got for that in the mail. Will report back with how it holds up, but don't have any better suggestions.
    riz_atx[QUOTED] likes this.
  11. Jun 2, 2020 at 12:46 PM
    DAS Taco
    DAS
    2017 TRD Offroad
    Remains flexible for decades too without separating or drying...
  12. Jun 16, 2020 at 2:56 AM
    RoughRder
    RoughRder What fresh hell is this?
    Garrett
    Hampton Roads, VA
    2011 DCSB TX TRD
    5100s and OME 885 coils front, 5100s and AAL for the TSB leaf pack (overload left in) rear. Jeraco camper shell.
    I went with 2 parallel strips of butyl around the perimeter of mine. It still leaks in the corners which is driving me nuts. Buuuut I left the bed rail caps on and I see so many others took them off.
    Is there a concern with the bed rails crushing without the caps, due to the weight? Would taking the caps off help with my leaking? Thanks!
