Side marker issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EBORSETI22, Aug 10, 2017.
  1. Aug 10, 2017 at 2:01 PM
    EBORSETI22
    EBORSETI22 [OP] Well-Known Member
    Evan
    New England
    '11 TRD Offroad
    TRD Exhaust Bed Mat Tinted Windows Tonneau Cover Cubby Bed Lights Reverse Lights Anytime Fog Mod Full OME Lift - 887s, LR UCAs, Dakars with D29XXL AAL MB TKO 17" Wheels 255/80r17 ST Maxx CMC Volant CAI with Scoop NFab Running Boards "Raptor" Grille Lights Ditch Lights 30" LED Hidden Light Bar On Board Air
    Ok TacomaWorld - haven't been able to figure this one out...
    My side marker light on my driver side is out. Tried the bulb, works fine in passenger side spot. Tried swapping the socket that it sits in to the passenger side and that worked fine.
    Swapped the passenger side over to the driver side and that one doesn't work!
    Next step swap out the harness that the socket sits in - ok swap it with some doorman harnesses that wire right in. Harness and socket fit nicely, however the side marker STILL doesn't work.
    Am I missing something here? Is there a fuse that could be blown somewhere that I just cannot find??
    All other lights work fine, no other wiring or electrical issues that I am aware of!
    Thanks for your help!
  2. Aug 10, 2017 at 2:03 PM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    Does the connector look burned or melted at all? I had that issue on my 08
  3. Aug 10, 2017 at 2:03 PM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    Check the tension connector where it houses the bulb. It may be loose. Check the harness connector to see if theres any debris or dirt stuck in there.
  4. Aug 10, 2017 at 2:05 PM
    EBORSETI22
    Evan
    New England
    '11 TRD Offroad
    Not burnt out, not dirty or anything
  5. Aug 10, 2017 at 2:13 PM
    outxider
    Sang
    East Bay, CA
    06 DCSB 4x4
    Have you tried using a multimeter to see if that side gets power?
  6. Aug 10, 2017 at 2:15 PM
    EBORSETI22
    Evan
    New England
    '11 TRD Offroad
    Not yet. Not sure I have one anywhere. Been trying to find mine with no luck.
    Am sort of convinced that's the case, how else would both sockets and bulbs work in the passenger side, right?
    Best bet is using the multi meter I would assume, unless there is a fuse...but not sure how there would only be one light on it...
  7. Aug 10, 2017 at 3:03 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    You need a meter and trace it back.
  8. Aug 10, 2017 at 3:04 PM
    Muddinfun
    Muddinfun Well-Known Member
  9. Aug 10, 2017 at 4:06 PM
    EBORSETI22
    Evan
    New England
    '11 TRD Offroad
    Just checked fuses again and they are all good. Multimeter no where to be found. Will try and troubleshoot tomorrow at work, pretty sure I have a meter there
  10. Aug 10, 2017 at 4:06 PM
    EBORSETI22
    Evan
    New England
    '11 TRD Offroad
    Suppose there is no power - where does that send me?
  11. Aug 10, 2017 at 4:10 PM
    moondeath
    Pa, Gardners
    Test from each connector one at a time back to the fuse box. If you have no power at the last connector but you do at the fuse box, then there is a break in the line between those 2 points.
  12. Aug 10, 2017 at 4:34 PM
    Muddinfun
    You really need to start with determining if you lost power or lost ground. The easiest way would be with a test light. If you just lost ground, that's a simple matter of connecting the white/black wire to ground under a bolt somewhere. If you lost power, and you can't find the break without splitting open a bunch of wiring harnesses, I would just run a new wire from the right side to the left. You can see in the schematic I provided, both light power wires end up in the same place.
