SIBI BUILT (OC SoCal IE) CMC|Toyota Suspension Install Specialist| (REGEARING SPECIALIST)
Discussion in 'Southern California' started by Jason TRD OR, Apr 28, 2019.
  1. Apr 28, 2019 at 2:50 PM
    Jason TRD OR
    Jason TRD OR [OP] SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
    (Orange County, Southern California, Inland Empire) CMC|Toyota Suspension Install Specialist|
    REGEARING SPECIALIST, INSTALLS, (CAB MOUNT CHOPS) & MUCH MORE
    1001 S Melrose St, Unit C & D, Placentia, CA 92870
    :muscleflexing:Hello everybody,
    We are a local shop specializing in Suspension work, Differential Regearing, fabrication, installs, CMC’s, CMR’s, gussets and much more.
    We have been doing this for many years now and decided to make a post here for anyone looking to get the best work done at a great price. Located in Socal/OC area. Feel free to PM, text, or Email us for any inquiries.
    Thanks to all of our amazing clients thus far! The community support is amazing.
    Follow us on Instagram! @sibi.built
    Check out our Website! www.sibibuiltoffroad.com
    Check us out on Google! (Sibi Built)
    (https://g.co/kgs/auoC1P)
    SERVICES OFFERED: (but not limited to the following)
    REGEARING/Differential Repair/Upgrade
    CMC (Cab Mount Chop)
    CMR (Cab Mount Relocation)
    Armor Installation
    All Suspension Installs(Toyota, Chevy, Ford, Nissan, Jeep, Subaru, Etc)
    Preload Adjustments
    Fender Trimming
    ECGS differential bushing install
    Spindle Gussets
    Cam Tab Gussets
    COIL swaps
    Service/Repairs
    (714) 390-3399
    Sibibuilt@gmail.com (best contact)
    Thanks!
    (Regears)
    (Cab Mount Chop)
    (High Clearance Bumper Cuts)
    (Fender trimming)
    (Demello Front Bumper W/ Winch)
    (Icon Stage 5 with Billet)
    (King 2.5 Coilover with Bajakits UCA)
    (6112/5160 AAL and SPC UCA)
    (Eibach ProTruck Coilover with Camburg UCA)
    (Bilstein 6112 Coilover with JBA UCA)
    (Eibach Shock with Icon 3 Leaf AAL Expansion Pack)
    (King 2.5 Smoothie with Adjuster. Icon RXT leaf pack)
    (4Runner Bilstein 5160 Shocks with OME Coils)
    (Jeep Wranger 2 inch lift)
    (Ford Raptor Mid Perch Mod)
    (Coil Spring Swaps/ Preload Adjustments)
    (TC Cam Tab Gussets)
    (F150 King Coilovers and Dirt King UCA)
    (Wheel Hub and Bearing Assembly Replacement)
    (Spindle Gussets)
    (F150 Eibach Coil Swap and Bilstein 5100 Coilover)
    (ECGS Bushing. Needle Bearing Replacement)
    (Some Finished Pictures)
    chrisdjc4, Trd420, BOMBS and 5 others like this.
  2. Apr 28, 2019 at 2:52 PM
    TWTaco
    TWTaco Well-Known Member
    Dave
    Just had my front body mounts done , Pinch weld and CMC done today by Jason and Carson. Carson really did a great job on the CMC came out really good! Jason knocked the pinch weld down sprayed it up with some rubberized sealer for stop leak protection and he did the front body mounts. They did this all in less then 2 hours. If you need some work like this done give them a PM you will be happy you did! I have more work they are doing next month.
    Jason TRD OR[OP] likes this.
  3. Apr 28, 2019 at 2:53 PM
    Jason TRD OR
    Thanks Dave,
    See you soon :muscleflexing:
    TWTaco[QUOTED] likes this.
  4. Apr 28, 2019 at 8:01 PM
    Jason TRD OR
    Thanks @Ethan22 for coming by the other day to have your Gas can holder welded to your swingout! Looks great!
    Ethan22 likes this.
  5. Apr 28, 2019 at 8:21 PM
    Gary99
    Gary99 Well-Known Member
    Gary
    SoCal
    19 QS TRD OR DCSB
    Jason's a buddy of mine who really takes pride in his work and his truck. I recommend hitting him up for a great price on installs and fab or whatever you have in mind.
  6. Apr 28, 2019 at 8:24 PM
    Jason TRD OR
    Thanks Gary :D
    Gary99[QUOTED] likes this.
  7. Apr 29, 2019 at 9:35 AM
    Jason TRD OR
    Finished this late night install on a Tundra with a Stage 4 Icon coilover setup with Delta Joint. The rear got an add a leaf and piggy back shocks and finished the truck off with a custom X-Pipe exhaust all welded in!
    Thanks for stopping by!
  8. Apr 30, 2019 at 8:22 AM
    Jason TRD OR
    Thanks Victor for coming by the other day and having your coilovers installed and trimming done to fit those mean 35’s on your F150 Platinum :thumbsup:
  9. May 1, 2019 at 3:34 PM
    Jason TRD OR
    Installed front bumper, winch, Baja designs lights and black headlight mod on the personal rig.
  10. May 3, 2019 at 11:50 AM
    Mista_G
    Mista_G Well-Known Member
    Costa Mesa, CA
    '13 DCLB 4x4
    Kings F/R 2.5" EXT w/700lb springs, JD Fab UCA’s w/ Lower Pivot Kit, Icon Progressive AAL (with TSB and overload in), CB drop, 285/75-17 nitto ridge grapplers, SCS Deep Dish Ray Dimes, Snugtop Rebel Shell, Prinsu Toprac, Gibson SS Catback Exhaust, ATH front /rear steel bumpers, CVT awning, Airflow snorkel, @ Shmellmopwho sliders, SC w/ @justdsm HPtune, 3° Cam Gears @mightytacoman, 2.8 smooth flow pulley, StopTech BBK
    Everything looks super nice
  11. May 3, 2019 at 12:46 PM
    Jason TRD OR
    Thank you sir :thumbsup:
  12. May 3, 2019 at 6:49 PM
    Jason TRD OR
  13. May 3, 2019 at 9:30 PM
    Jason TRD OR
    Thanks @taco_tallua for coming by to have your front radiator support repaired and supported with sheet metal!
    TWTaco likes this.
  14. May 4, 2019 at 12:58 PM
    Jason TRD OR
    Thanks for stopping by @lane26 for having your Fox coilovers rear shocks and SPC UCA installed! Looks great!
    lane26 likes this.
  15. May 4, 2019 at 1:26 PM
    lane26
    lane26 Member
    SoCal
    2015 MGM TRD Sport 4x4 V6 DCSB
    Thanks Jason. Great install by you and Carson. My Tacoma is sitting nice and level.
    Jason offered to pick up my truck and also offered to take it for an alignment. These guys take pride in their work and have great service. I’ll be giving Jason a call for the next install.
  16. May 4, 2019 at 1:29 PM
    Jason TRD OR
    Thanks Kristen! Glad your happy with everything! looking forward to seeing the new tires. Post up a picture once you get them installed!
  17. May 4, 2019 at 4:43 PM
    Jason TRD OR
    Next opening, Wednesday 5/8
    Thanks guys!
  18. May 5, 2019 at 9:17 PM
    taco_tallua
    taco_tallua MEGA-Known Member
    Anaheim, CA
    2016 MEGA Toyota Tacoma
    I'm here for the memes
    Thanks guys for taking me on very short notice. Talked to Jason a bit and seeing what would be best for my truck in this certain situation and he was able to answer all my questions. Great guy doing some good work.
  19. May 5, 2019 at 9:33 PM
    Jason TRD OR
    Thanks very much Brian! :D
  20. May 8, 2019 at 7:22 PM
    Jason TRD OR
    Thanks for coming by Jordan for your cmc. Badass rig single cab and 4x4. So rad @jordanedeson
