Shuddering on Acceleration from Stop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by this_is_nascar, Sep 23, 2020.
  1. Sep 23, 2020 at 11:41 AM
    this_is_nascar
    this_is_nascar [OP] Well-Known Member
    Gloucester City, NJ
    2007 TRD Off-Road
    2007 Tacoma TRD 4x4, with automatic transmission and 162+ miles.
    I've read several threads with similar conditions, but wanted to outline my particular issues. This recently started as a condition in which I feel a pretty severe shudder/vibration when accelerating from the stopped position. I don't have to be accelerating hard for this condition to occur. It somewhat levels out within several seconds. Above 40-MPH or so, it seems fine. Most recently, I now have squeak coming from somewhere underneath, only while moving slightly forward and backward, moving while idling only in gear. I don't know if it's a byproduct of the shudder/vibration issue or something totally different.
    In reading some previous posts, it was mentioned to test the condition while being in 4x4 mode. I tried that and it drastically reduces the amount of shudder/vibration from a stopped position, while accelerating.
    Any help would be appreciated. I'm not a techie type, so doing anything on my own related to this is a stretch on my abilities. From what I've read, it could be any combination of u-joints, cv joint, carrier bearing, center support bearing and axle itself.
    Again, thanks for whatever feedback you can give to me.
    Thanks.
  2. Sep 23, 2020 at 12:10 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    All of those are possibilities.
    How often have you greased the u-joints?
  3. Sep 23, 2020 at 1:01 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Could also be the torque converter
  4. Sep 23, 2020 at 1:06 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    all the driveline stuff is easy enough to check for play, if all that seems tight and right could be the torque converter
  5. Sep 23, 2020 at 1:10 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    id start by pulling the driveshaft and checking the ujoints for play. The noise at low speeds kind of points to these as the culprit. Is it a rotational squeaking that you're getting at low speeds? bad universals can also cause weird driveline vibes like you mentioned..
    cmoore, Larzzzz and b_r_o like this.
  6. Sep 23, 2020 at 7:55 PM
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    Thanks everyone. Looks like I have some work to have looked at. Unless a dealer lubes that stuff as part of a normal service, I suspect it's never been lubed.
  7. Sep 23, 2020 at 7:59 PM
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    Anything I can easily do to eliminate or confirm a torque converter issue?
  8. Sep 23, 2020 at 8:21 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Well no actually, nothing easy for the torque converter.
    Start with the easy stuff first ( Universal Joints ). These are the most likely culprit anyway as it is a 2007 and only dealer serviced ( they never grease the drive shaft ). I would place my money on a universal joint.
    If you do find that one is bad, do yourself a favor and replace them all at the same time. If one is done the others are not far behind.
    3 universal joints on the PreRunner.
    5 universal joints on the 4X4.
  9. Sep 23, 2020 at 8:55 PM
    NEUMATIC
    NEUMATIC Well-Known Member
    Tucson Az
    06 TRD SPORT 4x4 DCLB
    6112-650lbs 5160 w 3 leaf AAL Spc uca Led ditchlights and fogs Bestop supertop 4rnr trail wheels
    How often should I be greasing the ujoints?
  10. Sep 23, 2020 at 9:31 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Every time you change the oil is my recommendation. Every 5K miles.
  11. Sep 23, 2020 at 9:38 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Sounds exactly like the carrier bearing. I believe the stock play allowance is 1/4". I lived with it for a while. Even if you replace the carrier bearing, it will come back eventually. The best option is to replace it with a 1 piece driveshaft with a double cardan joint (about $600). If you go with a new carrier bearing, its about $70. Id also check u joints since you mentioned that you never greased them, but those are pretty cheap in the grand scheme of things.
    Is your truck lifted?
  12. Sep 23, 2020 at 9:39 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    check the u-joints as mentioned
  13. Sep 23, 2020 at 9:41 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Dealer doesn't lube the U-joints during normal service. You would have to pay extra for it. And the carrier bearing has no grease fitting, so it's on-condition replacement.
    Island Cruiser likes this.
  14. Sep 25, 2020 at 3:27 AM
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    Thanks again all. No lift, no mods. Stock from the dealer lit 12-13 years ago.
  15. Sep 25, 2020 at 4:39 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    My truck is a manual, however it did what you are describing. Turns out, my intake and especially the throttle body was dirty....
    Cleaned it all out, problem solved
    Even if that's not your problem, it wouldn't hurt to clean out the whole intake anyway
  16. Sep 26, 2020 at 3:31 AM
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    Thanks, but I can guarantee this isn't the issue. It's definitely in the drivetrain. I do appreciate the reply and suggestion.
  17. Sep 26, 2020 at 3:45 AM
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    U-joints ... do all while you have it out. You’ll know which one is bad as soon as you remove it.
  18. Sep 26, 2020 at 4:25 AM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    After you have changed out the CB (cause it wont hurt to do this) and greased everything down there and you still have the shudder
    (as you will). Find a good local transmission shop. Not a chain store. Find by word of mouth.
    Ask them to determine about the torque converter, as that is what this sounds like.
  19. Sep 26, 2020 at 4:33 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Change the transmission fluid to Maxlife. Try lube guard platinum or red bottle additive to the transmission. People had said it fixed the shutter issue.
  20. Sep 26, 2020 at 7:32 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    I had a similar low speed shudder. No squeaks.
    Checked the 5 U-joints, all were tight, but very very very dry. Got busy with my grease gun to pump in about 5-8 strokes for each joint before I saw any purging. Consumed about a 1/2 mini-tube (3 oz) of grease. I used a lithium base EP grease with Moly additive.
    The shudder disappeared. Hopefully, I got to the joints before any serious damage. Time will tell.
    Also at 109 kmiles, replacing U-joints would not be a big surprise either.
    These will get a squirt at each oil change.
