Show your 285/75/16 and 285/70/17
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Spewed, Jan 14, 2017.
  1. Aug 17, 2020 at 4:17 AM
    #1881
    RoughRder
    RoughRder What fresh hell is this?
    Garrett
    Hampton Roads, VA
    2011 DCSB TX TRD
    5100s and OME 885 coils front, 5100s and AAL for the TSB leaf pack (overload left in) rear. Jeraco camper shell.
    Continues to prove that you do NOT have to cut structural members to fit bigger tires.
  2. Aug 18, 2020 at 4:57 PM
    #1882
    sweeneyp
    sweeneyp Well-Known Member
    Patrick
    2019 Toyota Tacoma TRD Offroad, 1994 FZJ80
    Installed my new 265/75R16 BFG KO2s
  3. Aug 18, 2020 at 5:24 PM
    #1883
    outlaw_taco
    outlaw_taco Well-Known Member
    Houston
    2021 moon rock
    BLOCKBUSTER:eek:
  4. Aug 25, 2020 at 6:04 AM
    #1884
    weagle22
    weagle22 Well-Known Member
    Josh
    Birmingham, AL
    2018 Blue SR5 DCSB 4x4 2022 Lexus GX 460
    Bilstein 6112s/5100s Deaver AAL
    What's the wheel specs?
  5. Aug 25, 2020 at 6:06 AM
    #1885
    weagle22
    Josh
    Birmingham, AL
    What notch on the bilstein 6112s did you go with? and what offset are your wheels?
    Installed basically the same setup as your with my bilstein 6112s on the 6/5 setting. Looking for wheels with the right offset to fit the 285s.
    RollYourOwnWay likes this.
  6. Aug 26, 2020 at 9:37 AM
    #1886
    RollYourOwnWay
    RollYourOwnWay Active Member
    Tennessee
    '17 TRD OR MT
    Bilstein 5160's Bilstein 6112's OME Dakar HD's JBA UCA's
    I'm curious about the discussion around 285's rubbing. According to the TW tire comparison, there is negligible difference between 75/r16 & 70/r17.
    Currently running stock TRD 16'' wheel, adding Bilstein 6112/5160's & OME Dakar. Wondering whether the headache is worth the gains w/a 285, vs just running a 265/75r16
    pingoflamingo likes this.
  7. Aug 26, 2020 at 10:32 AM
    #1887
    bttrbsch
    bttrbsch Well-Known Member
    Michael
    Bellingham, WA
    2018 Inferno Tacoma TRD Off-Road
    Kicker speaker upgrade Rockford Sub TRD Grill Raptor Lights Oedro Running Boards Seat Covers Black Emblems MBRP Exhaust Sound dampened doors Blacked out turn signals Pro comp 7069 wheels BFG KO2 285/70/17 Ram mount Joying Head Unit Fogs Soft topper canopy Fox 2.5 RR DSC Fox 2.0 RR rear HS AAL 1.5" rear plus overload (2" total) Center console divider Axe/Shovel Mount Traction boards 32" light bar Shift sense pro v2 iDrive throttle controller Xentec 35W HIDs Vair 88p air compressor Dome LEDs LED reverse lights + pods JBA Upper Control Arms Full size spare tire Driver seat riser
    285/70/17 on ProComp 7069 wheels. No CMC but it looks like it will rub if flexed a little bit. Stock UCAs, low caster so it wanders a bit on the highway. I think I can live with the drifting and save $500+
    71tattooguy, Recondite and trailbound like this.
  8. Aug 26, 2020 at 10:50 AM
    #1888
    Recondite
    Recondite Well-Known Member
    NCWA
    2018 MGM DCLB TRD OR
    It depends on your selection of tire, rim and alignment. Different tire manufacturers 285's are actually different sizes. Some are a bit wider in width, some are a bit taller in height, some both. It will also depends on the backspacing and offset of your rim and finally how your caster is aligned. I just swapped out the stock TRD OR rims and tires for a set of SCS 16x8" rims with -12mm offset and 265/75/16 Duratracs. I have rubbing at full hard lock in forward and reverse and approaching incline. I could easily fix it with a heat gun or trimming, but it's really not that noticeable the majority of the time and I'm having my lift put on on the 11th, which I'm sure will eliminate it once I go up 2.25" in height.
    I was in the same dilemma as you and not knowing whether I would have to do a CMC for $350 or $650-$1200 for a new set of UCA's or both on top of trimming or massaging the fender wells, I decided the return on investment wasn't there for me for one extra inch in wheel and clearance height.
    You can use this to compare and play around with tire size, rim offset, etc., as well as compare different tires in whichever size you're looking for:
    6MTPro likes this.
  9. Aug 26, 2020 at 10:56 AM
    #1889
    TRD4X4TOY
    TRD4X4TOY Well-Known Member
    2019 Toyota Tacoma TRD OFF ROAD
    trailbound and Recondite like this.
  10. Aug 26, 2020 at 11:09 PM
    #1890
    tac0will
    tac0will Well-Known Member
    Will
    California
    ‘19 TRD Pro
    BFG A/T KO2
    285 /75 R16
    I don’t remember if I posted here yet ? Lol
  11. Aug 27, 2020 at 1:33 AM
    #1891
    Brostjoe
    Brostjoe Well-Known Member
    British Columbia
    2017 Limited DCLB
    285/70R17 Falkens
  12. Aug 27, 2020 at 6:53 AM
    #1892
    LaggyEvo
    LaggyEvo Well-Known Member
    Gainesville, FL
    2018 Cavalry Blue TRD PRO MT
    285/75r16 BFG KO2
    285/75R16, its squatting because it had about 900lbs of flooring in the back ;)
    DMhhghc_TQUspIN77N7XaqTlG9nawlB4nZoGggUE_3fd4ad0695f631c118cebbde9dd15eddb889caa0.jpg
    TRD4X4TOY and trailbound like this.
  13. Aug 27, 2020 at 8:34 AM
    #1893
    Taco1.1
    Taco1.1 Well-Known Member
    2018 TRD Off-Road
    Debadged, Kenwood 9905 Head Unit, Tinted Windows, Remote Start
    285/70/17 Nitto Ridge Grappler
    0 offset, 4.75 Inch Backspacing
    Approximately 3 inch lift, No CMC
    Camburg UCA
    Caster 4.5 (L) & 4.2 Right
    No rubbing on/off-road lock to lock.
    Highway MPG = 18.74; Off-Road MPG = 13.34. Calculated same way TFLTruck calculates.
    E91F781D-5B4E-424D-9DF6-E6DF9B6576D8.jpg CDD12C82-F2BC-40E4-8625-98512F4EDC0B.jpg
  14. Aug 27, 2020 at 8:49 AM
    #1894
    Toyo-fan16
    Toyo-fan16 New Member
    16' Silver TRD Sport 4x4 DCSB
    Nitto Ridge Grappler 285/70/17BD072E0F-D568-4DAA-9301-BD254FFF6212.jpg
    trailbound and CXYyuppie like this.
  15. Sep 7, 2020 at 10:46 PM
    #1895
    iTzTacoSupreme
    iTzTacoSupreme New Member
    2018 cement trd
    What did you do about rubbing in the front? Looks like you trimmed a little, trying to decide how to do mine without chopping the whole corner off like I’ve seen a lot of people do.
  16. Sep 8, 2020 at 8:54 AM
    #1896
    weagle22
    Josh
    Birmingham, AL
    285/75/16 Ridge Graps
    F7F85A73-1C5A-4538-9921-19480554BF0D.jpg D6FD6F1C-8DBE-4952-8910-9866E67D18E9.jpg
    what PSI you guys running?
    TRD4X4TOY likes this.
  17. Sep 10, 2020 at 3:27 PM
    #1897
    Dario
    Dario New Member
    Dario
    2020 TRD OR cement
  18. Sep 12, 2020 at 2:49 PM
    #1898
    RedHeadedStepside
    RedHeadedStepside Active Member
    2002 4×4 Manual Stepside + a crappy 19'
    Just put on yesterday. Small bit of rubbing at the rear of the front tire. Alignment tomorrow will hopefully fix it. Got the SPC UCA's. From what I've seen here on TW, the caster adjustment will get rid of that problem.
  19. Sep 12, 2020 at 3:00 PM
    #1899
    weagle22
    Josh
    Birmingham, AL
    Make sure and ask if your alignment shop can adjust those.
  20. Sep 12, 2020 at 3:48 PM
    #1900
    RedHeadedStepside
    Thanks for the heads up. I've called about a dozen shops in San Diego and none seem familiar with the SPCs. Most say "we'll figure it out..." So I found one with the most off road focus and will cross my fingers. From the 3-4 hours of reading TW forums, I'm going to set the LCAs to max forward caster and have the shop only adjust with the spc UBJ. This seems to be the best bet.
    Any San Diego people on this thread?? Shop reccomendations?
    Thanks.
    weagle22[QUOTED] likes this.
