Show your 285/75/16 and 285/70/17
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Spewed, Jan 14, 2017.
  1. May 23, 2022 at 10:21 AM
    #2921
    kas2828
    kas2828 Well-Known Member
    Austin
    Arizona
    2020 TRD Off-road 4x4 DCLB
    Looks really good. I like the wheel color on white.
  2. May 23, 2022 at 2:40 PM
    #2922
    Rahjer
    Rahjer New Member
    Roger
    San Diego, California
    2020 Toyota Tacoma TRD 4x4 Off-Road
    Fox 2.5 DSC with 2.5" lift plus Fox 2.0 DSC with Deavers AAL Method MR305 wheels with BFG KO2 285/70/17 Misc Overlanding gear
    "Well, one does want a hint of color"
    geoyota760 and kas2828[QUOTED] like this.
  3. May 24, 2022 at 10:06 AM
    #2923
    stressler
    stressler Well-Known Member
    Scott
    Orlando
    19 TRD -OR
    285 /75 R16 on 16x8 level 8 mk6 zero offset
  4. May 24, 2022 at 10:44 AM
    #2924
    Raijin822
    Raijin822 Well-Known Member
    Canada
    2021 TRD OR
    Looks really good! How much poke do you have with the 0 offset from the fenders?
  5. May 25, 2022 at 10:43 AM
    #2925
    Rahjer
    Rahjer New Member
    Roger
    Nothing at the top, some at the bottom. I can see the tires in the rear-view mirror, which looks cool, but nothing drastic.
  6. May 28, 2022 at 11:29 PM
    #2926
    gattoka
    gattoka Well-Known Member
    2021 tacoma trd offroad
    what perch are you on, 1?
  7. May 29, 2022 at 3:21 AM
    #2927
    OldCity
    OldCity Well-Known Member
    St Augustine Florida
    2022 Tacoma TRD Offroad DCLB
    Icon Stage 3, 285/70/17 KO2/Fuel Tech 17x9 +1 Offset, Cab mount chop, DiamondBack Tonneau, KDMax Pro+XT,
    285/70/17 KO2 Fuel Tech 17x9 +1 offset. Icon stage 3. Rubbing on the cab mount at full lock. Going to chop the cab mount Tuesday.
  8. May 29, 2022 at 7:46 PM
    #2928
    c2tm
    c2tm Active Member
    2020 TRD Off Road 4x4, 2012 VW Jetta 5MT
    Bottom perch
    gattoka[QUOTED] likes this.
  9. Jul 29, 2022 at 1:06 PM
    #2929
    DmiRider
    DmiRider Well-Known Member
    Cale
    Anybody notice much gas mileage difference between the 285/70/17 and the 265/65/17? I currently have the 285’s which came on the truck but was considering going down to the 265 if it’ll help my gas mileage since I’ll be driving further for work soon?
    thanks!
    33yrsoftoys likes this.
  10. Jul 30, 2022 at 3:02 AM
    #2930
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    Its at least 2mpg difference. More if the 285s are e load 10 ply or mud terrains
  11. Jul 30, 2022 at 4:00 AM
    #2931
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    Remember, you need to add 1mpg for every 14mi traveled because of the tire size difference unless the speedo has been adjusted for tire size. I'm running nitto terra grappler G2's in 285/70/17. They're a light SL tire that weighs 44.53lbs. I'm currently averaging a little over 21mpg. I've lost around 1/2mpg compared to the 265/70/16's when I was stock. It's an MT with 4.30 gears so the tire size difference didn't really affect it's performance as much as it does with the auto's. IMG_20220523_201818405.jpg
    2wdSR52022 likes this.
  12. Jul 30, 2022 at 3:45 PM
    #2932
    DmiRider
    Cale
    Running bf Goodrich Baja champions they’re LT 285s.
  13. Jul 30, 2022 at 3:47 PM
    #2933
    DmiRider
    Cale
    running bf Goodrich Baja champion all terrains, they’re LT285/70/17 Don’t really need that beefy of a tire except maybe in winter but gonna be doing more highway driving for work and maybe wanted something for better gas mileage. Averaging 17 maybe 18 mpg now highway.
    33yrsoftoys[QUOTED] likes this.
  14. Jul 30, 2022 at 3:55 PM
    #2934
    2jyoda
    2jyoda Well-Known Member
    Stevie
    Chandler az
    2021 Super White SR Taco 3.5 V6
    SDHQ ABS Guards, AC Drain mod lol. Bed Mat and Bed lights.
    are 33s or 35s better for off road?
  15. Jul 30, 2022 at 6:43 PM
    #2935
    33yrsoftoys
    joel
    mid Michigan
    That's a beefy tire. Before you go down in size, check out the nitto terra grappler g2's in 285/70/17. Make sure they're the SL's. They're under 45lbs and their rolling resistance is excellent. That's what I'm running and I'm really happy with them. Ride great and really quiet too. Definitely worth a look.
  16. Jul 30, 2022 at 6:46 PM
    #2936
    DmiRider
    Cale
    Yeah it is and it’s honestly more than I need but it’s what came on the truck. Ok thanks I’ll look into them. Just want something more fuel efficient to help with gas mileage. Appreciate the input.
  17. Jul 30, 2022 at 6:51 PM
    #2937
    DmiRider
    Cale
    I was mostly just wondering if sizing down to recommend factory 265/65/17 would be best for optimal gas mileage instead of the taller tire
  18. Jul 30, 2022 at 7:02 PM
    #2938
    33yrsoftoys
    joel
    mid Michigan
    I just got back this evening from silver lake sand dunes in Michigan. It's a few hundred miles from me, basically across the state. I averaged 22.1mpg running the nittos coming home. 65mph. On the way out, and all day in the dunes in low range, it was 18.7. Climbed every friggin hill there. It's been 21-22mpg this summer, pretty happy with that.
  19. Jul 30, 2022 at 7:11 PM
    #2939
    DmiRider
    Cale
    Frick yeah, sounds like good tires to me. Ima definitely check em out. I need to get some off roading done in my trd sport. I mostly just haul bikes and kayaks and my camper. Not much for off roading in the middle of Iowa besides gravel roads.
  20. Jul 30, 2022 at 7:22 PM
    #2940
    33yrsoftoys
    joel
    mid Michigan
    Very low rolling resistance. I have a MT and I can be doing 55mph and put it in neutral, just coasting to a stop sign 1/2 mi away and I'll be hitting the brakes at 40mph at the stop sign. It coasts better than it did with the stock tires. If I lost 1/2mpg with these tires compared to stock, I'd be surprised.
