Show us what you tow.
Discussion in 'Towing' started by BBQ BOY, Feb 17, 2009.
  1. Feb 13, 2021 at 7:44 PM
    #5401
    Zillon
    Zillon Well-Known Member
    NJ
    2013 SR5 Access Cab 4x4 V6
    Added a queen-size bed frame to the inside to elevate the mattress off the floor, and give additional storage.
    Also added a few things inside like curtains, relocated the cargo nets, added some hooks to keep the front cargo net up when parked, and invested in a ton of storage boxes for under the bed.
    It’s been great having our own bedroom on wheels, though.
    cpc[QUOTED] and POOLGUY like this.
  2. Feb 13, 2021 at 7:47 PM
    #5402
    Zillon
    NJ
    I think you’ll be fine, just make sure you’re not hauling wet mulch or dirt, or filling it with rock.
    Also, pay attention to how you’re distributing the load in the trailer. Don’t put the majority of the weight behind the axles.
    In terms of upgrading your rear suspension, I’d go for either an AAL or airbag setup, or both.
  3. Feb 13, 2021 at 8:30 PM
    #5403
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    Do you recall who makes the bed frame you used?
  4. Feb 13, 2021 at 8:32 PM
    #5404
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    Timbren bumpstops is an excellent replacement for OEM to help load supporting. I run timbrens on both my 2nd gen tacoma and my 02 GMC Sierra as OEM bumpstop replacements for towing.
  5. Feb 13, 2021 at 8:36 PM
    #5405
    Zillon
    NJ
    Boyd: https://www.amazon.com/gp/product/B00IMWFKGW?ref_=pe_1811570_143775280_E_ReturnReceived_Asin_Title
    The frame itself is fairly light - and goes together very easily. Instead of using the legs for support, I fabricated a ledge to mount the frame to on the outside walls of the trailer and only used 3 legs underneath.
    We’ve slept in the trailer for the last 16 nights, and the slatted platform has really elevated the bed comfort levels, on top of being warmer now that it’s off the floor of the trailer. We’ve seen outside temps in the mid twenties at night.
    Fast1[QUOTED] likes this.
  6. Feb 14, 2021 at 4:52 AM
    #5406
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Welcome to the group. Nice truck and trailer. There’s also Firestone air bags to consider which would help with the sag from tongue weight.
    Stop over in the NE BS thread and say hi. Another member over there has a similar trailer he uses with a larger truck.
    https://www.tacomaworld.com/threads/new-england-b-s-thread.204874/page-8955
  7. Feb 15, 2021 at 12:54 PM
    #5407
    Bishop2Queens6
    SoCal
    2009 DCSB SR5 4x4
    Just got back from 4 days in Borrego Springs towing a 2021 Forest River No Boundaries 19.8NB. 4000# dry, 5000# loaded. First trip towing with the Tacoma. I usually use my full size GMC, but this trip we wanted to do some trails, and the Tacoma is better built for trail runs.
    The wind was pretty rough during our stay, luckily the wind was mild on our trip in/trip out.
    The tacoma pulls this trailer a lot easier than my 2002 GMC Sierra 1500 SLE with a 5.3L v8 LM7 and 4L60E trans. I think the tacoma has the better gearing with the 5 speed and 3.73 rear end versus the GMC 4 speed and 3.73 rear end. Both trucks have 31" tires. The tacoma is heavier than the GMC by 500# based on the cat scale I have at work.
    We did a couple trails such as San Felipe wash, Fonts Point, Borrego Mountain Wash, and Coyote Canyon.
    I did upgrade my trans cooler to a Hayden 679 replacing the factory OEM one. I have also flushed my trans with Valvoline Maxlife ATF. I'm also running a Tekonsha p3 brake controller, sway controller, and a WDH hitch.
    Towing PSI: I did 34 psi front and 38 psi rear on the trip in and saw a bit too many micro cracking on the tires shoulders. I switched it up to 35 psi front and 40 psi rear on the trip out and didn't have any micro crack and had even wear across the tire.
    The Tacoma suspension is ICON 2.5 CDCV front/rear, JBA standard UCA, all pro expo leaves w/ Timbren bump stops. I had CDCV set to 7 front/8 rear and it really did a great job on handling the bucking and bumps on the road when towing. I usually have about 2 inches of space between the frame and the timbren bump stops, but with camping stuff in the bed and the tongue weight, the frame was just touching the top of the timbrens. Never felt like I bottomed out or had any excessive sag issues.
    The route in we took 10E, to 86S, to S22. The highest trans temp I saw was 204*F on the grade after turning from 86S.
    The route out, I took S22 to Montazuma grade through Ranchita, then 76W back to north county SD. The S22 through Monyazuma grade, the trans temp got to 221*F with the ambient only being 58*F. I doubt I'll ever tow through the section when ambient is greater than 90*F.20210215_091446.jpg IMG_0129.jpg
  8. Feb 15, 2021 at 4:58 PM
    #5408
    Mike G
    Mike G Well-Known Member
    2020 SR5 Tacoma DCLB 4x4 Red
    Pick up my new Geo Pro 15TB next Monday!
  9. Feb 15, 2021 at 6:36 PM
    #5409
    Wild Crow
    Wild Crow Well-Known Member
    James
    Anywhere is home
    2014 Baja
    We just left Borrego Springs today after hanging around the area for 4 weeks! It's a beautiful area!
  10. Feb 15, 2021 at 6:50 PM
    #5410
    Fast1
    Minneapolis, MN
    Nice pick.. has been on my radar along with the Tag.. Really like to hear your impressions of this travel trailer when you get it, especially compared to the Tag.
    Mike G[QUOTED] likes this.
  11. Feb 15, 2021 at 6:52 PM
    #5411
    Enreeko
    Enreeko Member
    Enrico
    Maricopa, AZ
    2020 White Tacoma SR 4x4
    Forest River Evo :thumbsup:
  12. Feb 21, 2021 at 11:14 AM
    #5412
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Drug this home yesterday. Did much better than I expected. Now to figure out a towing mirror option.
  13. Feb 21, 2021 at 12:04 PM
    #5413
    Dansly56
    Dansly56 Well-Known Member
    Dan
    Valencia, California
    2013 Toyota Tacoma Baja Edition 4WD
    Light bars, electronic side steps, bed cover, light bars, grills, roof rack, falken tires, method racing rims
    my ambient hits 90° Without towing
  14. Feb 21, 2021 at 12:07 PM
    #5414
    Dansly56
    Dan
    1050lb cargo is rough with a family of 4, the tongue weight of travel trailer, the weight distribution hitch and a dog makes me maxed out SMH! I can’t even put anything in the back of the truck everything has to go in the trailer when towing
  15. Feb 21, 2021 at 3:27 PM
    #5415
    Rhann86
    Rhann86 Well-Known Member
    2017 TRD Off Road Crew Cab Long Bed
    I used cheap mirror extenders bought at a trailer shop and they did the job!
  16. Feb 21, 2021 at 3:30 PM
    #5416
    Rhann86
    Wasn’t the best towing...This isn’t the lightest camper or most aerodynamic. Hills didn’t help either. Need to find a campground that’s downhill both ways!
    gatriguy likes this.
  17. Feb 23, 2021 at 4:58 PM
    #5417
    Mike G
    Finally picked it up!
    The Tacoma did fine on the back roads.
    Tomorrow will be a good test, headed out to W.Md, plenty of grades on I-68!20210223_142051.jpg 20210223_111358.jpg 20210223_142051.jpg
    waterlogged86, Zillon, Fast1 and 3 others like this.
  18. Feb 23, 2021 at 5:32 PM
    #5418
    Fast1
    Minneapolis, MN
    Lucky you! Looks nice.
    Any initial impressions with it, towed behind the Tacoma?
  19. Feb 23, 2021 at 6:07 PM
    #5419
    Mike G
    I was only on back roads today, but it was fine. The WDH really helps.
  20. Feb 26, 2021 at 8:51 AM
    #5420
    Canyon lands
    Canyon lands Well-Known Member
    Bill
    Colorado
    2015 red Tacoma TRD off-road
    3” lift, leer topper, James Baroud tent, Lund bull bar, 4 wheel running boards, Pioneer stereo, fosgate speakers, amp, bed slide, Thule racks, road shower
    Looking at a Forest River Wolf Pup 16TS, dry weight of 3300 #. Will probably upgrade the tranny cooler. Running the 4.0 v-6. Any thought on the potential issues, or possible problems? Think the taco will pull it comfortably?
