Show off your Cooper ST Maxx
Discussion in 'Wheels & Tires' started by Chux, Oct 4, 2014.
Do your Maxxs pull ?
  1. To the right
    233 vote(s)
    32.0%
  2. To the left
    20 vote(s)
    2.8%
  3. Neither, drives straight down the road
    474 vote(s)
    65.2%
  1. Oct 25, 2015 at 6:02 PM
    #1441
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    It isn't.
    jaredc2306 and TacoVio like this.
  2. Oct 25, 2015 at 6:21 PM
    #1442
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    That's true but if you off road they could still rub
  3. Oct 29, 2015 at 8:01 PM
    #1443
    BigBenzo1
    BigBenzo1 Well-Known Member
    Big Benzo
    Phoenix, AZ
    cooper st maxx 265 70 17 on level 8 mk6
    Mike O, Poncate, DustStorm4x4 and 2 others like this.
  4. Oct 30, 2015 at 5:54 AM
    #1444
    Dctaconny
    Dctaconny Well-Known Member
    Don
    Watertown, ny
    2021 T4R sr5p
    Looking good
  5. Oct 30, 2015 at 3:25 PM
    #1445
    Dctaconny
    Don
    Watertown, ny
    2021 T4R sr5p
    Looking good
  6. Oct 30, 2015 at 3:30 PM
    #1446
    WheelInTheSky
    G
    Jackson Hole
  7. Oct 30, 2015 at 3:53 PM
    #1447
    Dctaconny
    Don
    Watertown, ny
    2021 T4R sr5p
  8. Oct 31, 2015 at 3:31 PM
    #1448
    vbduketaco
    vbduketaco Active Member
    Rockingham, Va
    2103 TX PRO
    Cooper St Maxx Fox 2.5, Fox Rears, Icon AAL BHLM Weather Techs Clazzio Seat Covers LED Footwell lighting
    ^^^^^ freakin sweet man. 265/75?
  9. Oct 31, 2015 at 3:51 PM
    #1449
    Dctaconny
    Don
    Watertown, ny
    2021 T4R sr5p
    285/70-17. Wanted to stay with 16 inch wheels but the ones I liked the most were 17s
  10. Oct 31, 2015 at 8:24 PM
    #1450
    BTHawk
    BTHawk OFP
    Will
    Warrenton, VA
    2025 LC250
    Are you running a lift?
  11. Nov 1, 2015 at 2:25 AM
    #1451
    Dctaconny
    Don
    Watertown, ny
    2021 T4R sr5p
    Yes 5100s front and rear. Front set at 2.5 and toytec aal rear for 2 inch
    BTHawk likes this.
  12. Nov 1, 2015 at 6:48 AM
    #1452
    BTHawk
    BTHawk OFP
    Will
    Warrenton, VA
    2025 LC250
    Thanks. Looks great! Mine is lifted to a similar height and I am debating 285/75/16 or 265/75/16.
  13. Nov 1, 2015 at 7:06 AM
    #1453
    Dctaconny
    Don
    Watertown, ny
    2021 T4R sr5p
    I have some rubbing on the fender flares while turning with suspension compression
  14. Nov 3, 2015 at 3:21 PM
    #1454
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    Does anybody have reliable weight #'s for these tires? The only numbers I can find are on TreadDepot... and I'm not sure I trust those.
    They have the 10-ply 255/80R17 at 51 lbs, and the 6-ply 255/75R17 at 53 lbs. Which makes no sense to me.
  15. Nov 3, 2015 at 3:26 PM
    #1455
    WheelInTheSky
    G
    Jackson Hole
    Probably has to do with cost/weight of compounds they use. I wouldn't read too much into it, less than 10lbs of tire weight is not noticeable whatsoever.
  16. Nov 3, 2015 at 4:10 PM
    #1456
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 S/T Maxx 16X8.5 Level 8 Trackers 5100 1.75 HID, LED interior, 3" N-Fab step bars
    I posted the following on another thread a while back:
    I have been looking into these and this very topic lately. And specifically on 265/75/16 St Maxx. There is no definite answer out there.
    I also did some research of this the myth of tire weights and fuel economy. On several engineering forums, many professional engineers concurred that just a few pounds of additional tire/wheel weight would NOT impact "Rolling Resistance" (the engineering term). Other factors such as aerodynamics of the sidewall, the tread lugs, tire pressure, rigidity, and how much the tire extents past the wheel well have the biggest impacts on Rolling Resistance & fuel economy. Obviously if they were 20lbs more each, they may be an impact, but not a 10% increase in weight.
    I am not thrilled about going from my C load range Duratracs, to load range E. But The noise is getting out of hand. and the new BFG KO2 only come in load range E too.
    49lbs
    http://www.treaddepot.com/tire/90000003094.html
    54lbs according to this guy referencing Discount Tire Now. But if you continue reading, a poster says his 285 weighed 7lbs more than what was reported.
    http://www.jeepforum.com/forum/f15/cooper-discoverer-st-maxx-jeep-lj-rubicon-1364065/#post13513103
    54lbs
    [​IMG]http://www.amazon.com/Cooper-Discov...1876&sr=8-1&keywords=cooper+st+maxx+265+75+16
    Livinserene likes this.
  17. Nov 3, 2015 at 5:19 PM
    #1457
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    If I did go with 255/80R17 Coop's, and I go by the specs on TreadDepot, I would be adding 13 lbs per tire. And this is for a daily driver. As much as I'd love to add another inch, that sounds like a big jump to me.
    Currently running 255/75R17 Hankook Dynapro's.
    My badass side wants the Coop's, but my sensible side tells me the Hank's are everything I need in a tire.
  18. Nov 3, 2015 at 5:30 PM
    #1458
    Dctaconny
    Don
    Watertown, ny
    2021 T4R sr5p
    I went with 285/70-17 I put on on the scale and it weighted in at 66lbs, yes it's heavy but I don't care in my situation if I wanted gas mileage I would drive a corolla. This is my daily driver but still want to play with it. Just my 2 cents
    Chux[OP] likes this.
  19. Nov 3, 2015 at 5:47 PM
    #1459
    Utah Off-roader
    Utah Off-roader Well-Known Member
    Middle TN
    StormTrooper '14 DCSB
    Diff Breather OME full lift kit with 886 coils and dakars sway bar removed 31.5" LED light bar from CaliRaisedLED
    Does anyone know if the ST Maxx tire size 255/85/16 will fit on a stock lift Taco OR?
  20. Nov 3, 2015 at 6:35 PM
    #1460
    WheelInTheSky
    G
    Jackson Hole
    I don't understand your question.
