Show off your aux fuse panels.
Discussion in 'Lighting' started by Newlife, Dec 29, 2013.
  1. Sep 29, 2019 at 6:22 AM
    #921
    motofish84
    motofish84 Well-Known Member
    Tyler
    The panel I’ve been working on is finished and installed. I cut the panel out of 16G steel then milled out the necessary holes and openings and bent it 90 degrees. Currently it supports a light bar on my roof rack and some scene lights. The bar isn’t able to be used yet because my switch has yet to arrive. Scene lights are tied to the cargo light switch. I also plan to add a circuit for bed lights and possibly a 12v circuit in the bed.
    I’d like to get some battery terminals that will allow some additional posts.
  2. Sep 29, 2019 at 9:23 AM
    #922
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Just this morning seeing this post. There are two main benefits, if there's a short you just find it, fix it, and reset the breaker, instead of having to buy a new fuse. The other is it acts as a switch so you can de-energize the panel.
    Taco-Obsessed likes this.
  3. Sep 29, 2019 at 9:39 AM
    #923
    badkids
    badkids Well-Known Member
    ‘83 Hilux with a 2JZ
    Still have it? Pm me
  4. Sep 29, 2019 at 12:42 PM
    #924
    yodataco
    yodataco Well-Known Member
    Alex
    Orange County, CA
    2000 4Runner
    MCM fab 3.5" LT front, OME 861 rear
    These are what i used.
    https://www.amazon.com/Military-Spe...ocphy=9031582&hvtargid=pla-777032180552&psc=1
  5. Sep 29, 2019 at 1:29 PM
    #925
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Still have it. Still waiting on my other box to be made. I can let you know when it comes in if you'd like. Or I can give you the link to the rtmr thread too. All about options
  6. Sep 29, 2019 at 1:30 PM
    #926
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Panel is from Paranoid... Don't think there is another one out there for the 1st gen. I still need to assemble everything (have all the parts, just need to find the time to do it) but here is a shot of the panel in the engine bay. From the bottom, there is enough space. We'll see.
    (ignore that long screw to the left of the RTMR :rofl:)
  7. Sep 29, 2019 at 1:40 PM
    #927
    bagleboy
    Scott
    Norcal, Santa Rosa
    Area51Runner likes this.
  8. Sep 29, 2019 at 2:10 PM
    #928
    badkids
    Both, thanks
  9. Sep 29, 2019 at 3:00 PM
    #929
    m603holden
    Marteeen
    New England
  10. Sep 29, 2019 at 5:23 PM
    #930
    Stryker420
    Stryker420 Well-Known Member
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    Is this looking correct?
  11. Sep 30, 2019 at 11:43 AM
    #931
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    I have a general question for anyone with knowledge...
    For the above, so far I have a 6 circuit Blue Sea with an 80 amp breaker the bracket is from Overland Equip. I have "minor" accessories planned. My ARB 40 amp dual compressor, I'm assuming, should be wired direct to the battery because it exceeds the 30 amp limit. Honestly, I doubt I'll get up to 40 amps total with all my planned accessories.
    I've been looking at the Blue Sea Low Voltage Disconnect from here. Does anyone see a problem installing this before the breaker? Thanks...
    Stryker420 likes this.
  12. Sep 30, 2019 at 4:32 PM
    #932
    bagleboy
    Scott
    Norcal, Santa Rosa
    Nope, should work fine there.
  13. Sep 30, 2019 at 4:51 PM
    #933
    RyanDCLB
    4/19 DCLBOR
    Great, thanks! :hattip: I just ordered it. :thumbsup:
  14. Sep 30, 2019 at 7:55 PM
    #934
    Stryker420
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    Dude you are squared away... Good plan
    RyanDCLB[QUOTED] likes this.
  15. Sep 30, 2019 at 9:35 PM
    #935
    RyanDCLB
    4/19 DCLBOR
    Thanks. I didn’t like the idea of the panel always being hot and draining my battery. The low voltage disconnect will be perfect for shutting down the fuse panel. The one thing about the disconnect is that it has a continuous rating of 65 amps. For those with more accessories, they may want two disconnects with the Blue Sea Split Panel to "spread the load". :thumbsup:
    Stryker420[QUOTED] likes this.
  16. Oct 1, 2019 at 3:43 AM
    #936
    bagleboy
    Scott
    Norcal, Santa Rosa
    Yes, polarity isn't important on relays, only getting the coil connections and high current connections to the right components.
    Switch is 85/86
    Accessory 30/85
    And you have those correct.
    maybe angle the plus cable away from the engine block a little(more toward the grill).
  17. Oct 1, 2019 at 4:52 AM
    #937
    Stryker420
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    Thanks! Time to get splicing
  18. Oct 1, 2019 at 5:05 AM
    #938
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    So where are you installing the LVD? Under the hood or in the cabin?
  19. Oct 6, 2019 at 10:05 AM
    #939
    Hyland33
    Hyland33 Well-Known Member
    Andrew
    Leicester, MA
    2015 Tacoma TRD Offroad
    Powering mine with my solar setup. Only using it for some 12v ports at the moment. I run my dometic, a charger for my macbook, and a phone/ipad charger off the ports now.
  20. Oct 6, 2019 at 10:19 AM
    #940
    RyanDCLB
    4/19 DCLBOR
    I haven't decided yet. The LVD unit itself will be flush mounted on the aux fuse bracket next to the breaker, while the switch can be mounted inside the cab or inside the engine bay. I don't have any extra slots ATM inside the cab, so my current plan is to mount the switch in the engine bay below the 6 blade aux fuse panel.
    JustinL[QUOTED] likes this.
