Should tires be re-balanced when rotating?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pushgears, Dec 3, 2023.
  1. Dec 3, 2023 at 7:13 AM
    pushgears
    pushgears [OP] Well-Known Member
    2021 OR DCSB MT
    This is actually a 2-fold question regarding my '21 at its 40K mile service appointment:
    1. Should the tires be re-balanced when rotating? If so, how frequently?
    2. Was my dealer trying to rip me off? Between PUSHING the wheel balance and DISCOURAGING me from changing the oil (telling me that I could "go another 5,000 miles"), I got the feeling that something wasn't right.
    I like to use the dealership when possible. It helped get an out of warranty repair covered on a Rav-4. I never re-balanced before on any vehicle though.
    I told him to only change the oil and rotate the tires -just like I asked for -and not to balance the wheels. Drove a 300 mile ski trip since then and there were no vibrations at any speed up to 84 mph.
  2. Dec 3, 2023 at 7:16 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I usually have them rebalanced every 25-30k
    They do not need balanced every 5k rotation
    koditten and pushgears[OP] like this.
  3. Dec 3, 2023 at 7:19 AM
    LanceRN
    LanceRN Well-Known Member
    Lance
    1998 Purple Tacoma TRD
    Balancing during a rotation isn't a bad thing, it just checks to make sure the tires are in balance. They aren't going to remove the weights and rebalance, all they do is put them on the balancer to make sure you are good.
    I don't know about your Tacoma, mine is a 98, but my Honda tells me what maintenance is due, for everything, and that's based on mileage, temperatures, how hard I drive it, etc. I assume your truck has something similar. It's not going to hurt anything by changing your oil early, but you can certainly hurt the engine by changing it late, so I don't agree with the dealership there.
  4. Dec 3, 2023 at 7:21 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    In my experience, rebalancing tires that exhibit no balancing issues doesn’t do anything but add potential to screw up their balance.
    A bit anecdotal and probably doesn’t happen to many, but when I got my Jeep 10 years ago I put new tires on it (Duratracs). They were perfect, balanced only with stick on weights. Got them at a tire shop in Kansas where I got the Jeep. Time came to rotate them and I figured I needed to take them in for R&B. I paid discount to do it because I lived in Texas. Must have been a bad discount location because for the “Balancing” part, they immediately ripped off all the stick-ons and rebalanced them with crappy clip on weights. I could never get them balanced again and they essentially ruined my tires. i also paid for road force balancing and went back multiple times until I gave up.
    At this point I just rotate them. I have yet to get so far into a tire’s life that it needs rebalancing on its own. But if you take them to the dealer or a tire shop, there is a strong chance they’re going to try and rebalance them.
    If all they do is throw them on the machine to check balance briefly, that’s fine.
    ChevyJ7, pushgears[OP] and Rusty66 like this.
  5. Dec 3, 2023 at 7:21 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    I would consider rebalancing when it became apparent the tires are no longer in balance, it's not like you can't feel it when that occurs. There's no downside to having it done as they recommend except that it's kind of expensive. It's not a requirement by any means.
    pushgears[OP] likes this.
  6. Dec 3, 2023 at 7:27 AM
    Clearwater Bill
    Billy
    Largo Florida
    Typically I've always rotated myself in the driveway.
    But since getting tires at Costco a few years ago, I let them do it. For free. They re-balance as well.
  7. Dec 3, 2023 at 7:47 AM
    OBXPaul
    OBXPaul Just do what you say you're going to do!
    Paul
    Kill Devil Hills, NC (Outer Banks)
    2016 Black Tacoma Limited, 1983 Blue Deluxe Pickup
    1983 restoration in progress, major mods so far new 6" lift and 35" Mickey Thompsons.
    I've been driving for 46 years, never rebalanced tires on any vehicle I've owned. My experience is make sure you rotate the tires every 5k miles, and make sure your front end alignment is correct. By doing this every set of tires I've bought has at least lasted as long as the mileage claim by the manufacturer.
    Chew, pushgears[OP] and musicisevil like this.
  8. Dec 3, 2023 at 7:52 AM
    Bishop84
    Bishop84 Well-Known Member
    You guys have to understand it depends on the customer base. We have a few dealers that enforce this.
    We get loads of complaints "Ever since you rotated my tires there's a shake"
    Sorry we don't test drive at 60mph and what do you want us to do after, bring it in to undo the rotation or sell a rebalance? People don't understanding of the process.
    With all terrains I do diagonal rotations and warn it may vibrate a bit, but truck owners should always be prepared for this with heavier tires.
    Same with winter tire swaps, winters trap rocks intentionally and lose balance. So customer books a 40$ swap, gets a vibration and we have to waste shop time by bringing it in for a free balance.
    Can't win.
  9. Dec 3, 2023 at 7:55 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    If it ain't broken....
    Definitely not worth doing it every rotation. You will know if it drives bad, or if they start to show uneven wear.
    As far oil changes go.... I wouldn't go over 10k, and not more than 1 year on the same oil, regardless of mileage.
    Chew and pushgears[OP] like this.
  10. Dec 3, 2023 at 7:56 AM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Simple answer: No. They’re draining your wallet. On rare occasions we might get a complaint after a rotation but not the norm. Usually if you see fresh curb rash on a wheel you might want to recommend a balance but my experience is you can take a tire that does not exhibit vibration, put it on the balancer and it’s off a half ounce or so. Balance it, take it off then reinstall it on the balance and it wants another half ounce 180 degrees from where you just added it. Take off the half ounce you just installed and it spins up all zeros. Sometimes it can drive you nuts.
    Chew, pushgears[OP] and joba27n like this.
  11. Dec 3, 2023 at 8:56 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    It's a good idea but not compulsory. When I had access to a wheel balancer i'd usually check them when I rotated them but, anything 0.25 Oz or less out of balance and I would just leave them be.
    for me though it depends on the vehicle, when it was last done, the condition of the tires, condition of the wheel hub, customer, etc whether I recommend a balance with a rotation. Usually it's based on tire condition and wheel hub condition for me though whether I try to upsell it or not.
    My shop was a stickler for cleaning wheel hubs when ever the wheels came off if there was any corrosion at all. So if I had to hammer/pry the wheel off, or the tires had abnormal wear then usually I would recommend a wheel balance
  12. Dec 3, 2023 at 9:02 AM
    eurowner
    eurowner Duke Sky
    Scoty
    As tires wear they get lighter and in my findings, they are off balance after 10k miles; GY MTR, Toyo Open County ATII and ATIII, and Toyo Observe, BFG K02 have all needed to be rebalanced. I rotate my tires from 2-5k depending on the vehicle and conditions.
    The MTR and K02 are the tires on mine that benefit from rebalancing sooner than later.
  13. Dec 3, 2023 at 9:16 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Don’t waste your money, you only need to rebalance with each rotation if your wheels were road force balanced (while mounted on the vehicle). But nobody does that anymore so don’t worry about it and just do it if you get a new TPMS unit or a patch and they removed the tire to do it or if you feel a new vibration (like from having a weight fall off a wheel which is rare with newer stick-on weights- I’ve never had one of those fall off over a decade of driving work trucks and my own truck off-road).
  14. Dec 3, 2023 at 9:21 AM
    TCB2020
    TCB2020 Well-Known Member
    2020 Tacoma TRD Sport
    None
    I'm getting my 40K service later this month. I assume the tires were rotated every 5K per the service manual when I took it to the dealership but who knows? I've never had an issue with vibration after the rotations.
  15. Dec 3, 2023 at 9:50 AM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    I think it’s personal preference. However, I think if you spend a majority of your time off-road like I have since April, get it done when you have them rotated. Not hard to lose a wheel weight in some shite and not know it until a vibration starts. Or something else.
    I’m sure there’s someone out there that keeps track of where every single wheel weight is on every wheel, knows the weight of each one and checks each one after every wash. That’s not me.
  16. Dec 3, 2023 at 4:29 PM
    Mbtstaco
    Mbtstaco Well-Known Member
    2023 Tacoma Pro MGM
    Yes, if they want to do it for free otherwise no.
    RedWings44 likes this.
  17. Dec 3, 2023 at 4:47 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    It doesn't hurt anything (other then your wallet) to balance the tires every 5000 miles but I wouldn't bother, if you do lots of interstate driving it may be nice to balance them every 20,000 miles. Different for me since I am a mechanic I can balance them for free whenever, I usually balance my tires once a year before the road trip vacation so I don't get vibrations when breaking the speed limit for hours.
  18. Dec 3, 2023 at 5:27 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    I was in the tire biz for several years. To me rebalancing is a cash grab and a gimmick. If they're balanced/ not balanced that's the way they they are. Rotation or not.
