Should I rotate my tires every 5k miles, even if it takes me a year+ to drive that many miles?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Grimble27, Apr 20, 2024.
  1. Apr 20, 2024 at 9:53 AM
    Grimble27
    Grimble27 [OP] Well-Known Member
    Washington
    '23 White Tacoma TRD OR
    I change my oil based on time not mileage since I do lots of short trips and only put about 4k miles on my truck per year. I change it every 6 months. Should I do the same for tire rotation and base it on time not miles? Typically a tire rotation is every 5k miles, but that means I would only rotate them every ~18 months or so. Does it really matter or am I probably overthinking it?
    TacoTime55 and SH10151 like this.
  2. Apr 20, 2024 at 9:56 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    You're overthinking it. The tire rotation is to help even out the wear caused by driving. If you aren't driving the tires aren't wearing and rotating them would serve no purpose. Although they do breakdown over time like the oil (why it's changed on time or miles) rotating them won't prevent the wear from aging. You might find you replace the tires outright at only 30k miles due to age rather than tread wear but that's a problem for future you.
    grogie, Barsoom, bgavin and 6 others like this.
  3. Apr 20, 2024 at 9:56 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I'd recommend longer trips and more miles, otherwise, tires will be the least of your problems. Short trips are murder on an engine.
    As for the tires, no need to rotate based on time. But if your truck sits for long periods, you may want it on blocks/stands to avoid flat spots and out of round tires.
  4. Apr 20, 2024 at 10:11 AM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    i rotate my tires every 5k miles therefore you have to as well
    E4562, amyracecar, Barsoom and 4 others like this.
  5. Apr 20, 2024 at 10:26 AM
    Unresolved Taco Issues
    Unresolved Taco Issues Well-Known Member
    Jeff
    FINALLY off the island!
    2020 Gray Tacoma Access Cab
    At 4k/yr your tires will need to be replaced from age before wear. Rotating them helps prolong wear so I would just leave them as be or maybe just drive your truck more...
    Chew likes this.
  6. Apr 20, 2024 at 10:30 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    I drive about as much as you do. I change the oil every 8 months and I rotate the tires then, don’t overthink it.
    Barsoom likes this.
  7. Apr 20, 2024 at 10:36 AM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    I can't see a reason to rotate your tires with less than 5000mi on them unless it's to clean up your hubs and inner wheel at the lugnuts with a wire brush. Makes changing a flat much easier.
  8. Apr 21, 2024 at 3:08 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I rotate every 5k miles and rebalance as its free from Discount tire.
  9. Apr 21, 2024 at 7:02 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I rotate mine every 2500
    Soft Taco likes this.
  10. Apr 21, 2024 at 7:14 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I change my engine fluids religiously on schedule. Tire rotations I shoot for every 5K miles but not so religiously. I want my engine in tip top shape. If I slack on rotations I might have to buy a new set of tires slightly sooner.
    Since you make short trips, watch for condensation build up on your oil cap. This would be another sign to get the engine up to full operating temperature more often.
  11. Apr 21, 2024 at 9:37 AM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    I forgot to rotate mine for at least 20k and they still look perfect and track straight. 35k on my Wrangler Ultra Terrain ATs. Hardly any wear… My opinion, if your truck is aligned and tires keep up on pressure its prolly not critical.
    hiPSI and RIX TUX like this.
  12. Apr 21, 2024 at 9:51 AM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
    While I'm religious about changing my fluids, I never rotate my tires. I got 85k miles of equal wear out of my original stock Dunflops
    https://www.tacomaworld.com/threads...preciation-thread.389098/page-6#post-26618894
    and I never rotated them. :crapstorm:
    I think for certain drivers (think grandpa drivers like me :D) rotating isn't that critical.
    TacoSR523 likes this.
  13. Apr 21, 2024 at 10:02 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Rotate mine when winter turns to spring. They are not marked so they get rotated like it or not when I store the tires for the next go around. Occasional alignments helps the issue.
    hiPSI likes this.
  14. Apr 21, 2024 at 10:49 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    no need to pre rotate, but I would be looking at some sort of battery maintainer with that little of use and short trips, if you can't find the time to take a long drive once a month (even better of an option).
    WilliamJames and RIX TUX like this.
  15. Apr 21, 2024 at 11:03 AM
    Blak Shinobi
    taco
    n/a
    gramps age has nothing to do it with it. Just remember this vehicle weighs 4k plus pounds . Dont want to cause an accident when your tire blows out because it could have prevented by rotating your tires
    :D
    P.s , not picking on you and no offense
  16. Apr 21, 2024 at 12:57 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    the tires dont get wear sitting still and the oil dont get dirty when engine isnt running ......do you wear socks one day and them throw them away?
    hiPSI likes this.
  17. Apr 21, 2024 at 1:02 PM
    RIX TUX
    Blak Shinobi and jmneill like this.
  18. Apr 21, 2024 at 1:05 PM
    RIX TUX
    praise the lord :anonymous:
  19. Apr 21, 2024 at 1:09 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    I rotate mine every 10,000, and I'm 1,000 past due..
  20. Apr 21, 2024 at 1:22 PM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Even though it takes you a while to get to 4K miles...your front tires are still wearing on the edges.
    If you "carefully" look/evaluate front edges to the rear tires, there should be a slight difference because there is "wear" there.
    Also, do the steering wheel test on a straight away at 30-45mph...does the truck veer to either side?
    If not, at least your alignment is good!
    Chances are, your front tires are getting wear on the edges simply because they steer the vehicle.
    I would recommend rotating the tires even at 4K miles.
