Should I Replace My Spare Tire?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bolt79, Jun 15, 2011.
  1. Jun 15, 2011 at 3:14 PM
    Bolt79
    Bolt79 [OP] Well-Known Member
    White Springs, FL
    2022 Lunar Rock Trail Edition
    Screen ProTech kit, JDMCAR center console organizer, JDMCAR Center Console Armrest Cushion, Toyota door sill protectors, Black Toyota tailgate letter inserts
    I think I'm about to pull the trigger on a new set of tires and rims for my 2011 DC Sport (Timberline Mica). I've got my eye on these:
    http://www.discounttiredirect.com/d...2011&pc=46403&counter=1&wd=17&rw=9&vid=019279
    along with a set of Nitto Terra Grappler AT's.
    My question is: Do most people replace their spare with the new tire and rim (so that it matches) when they get new a set-up? Or, do most just use the stock spare? My new size will be 265 70 17.
    Thanks for any input.
  2. Jun 15, 2011 at 3:26 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    I asked the tire guy about this and he said the factory spare is ok to use for short distances, kind of like the donut spares some cars use.
  3. Jun 15, 2011 at 3:27 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    it's ok to use for short distances, but make sure you put it on the front and keep the 4x4 off. If you have a flat in the rear, move one back from the front, and put the spare on the front.
  4. Jun 15, 2011 at 3:57 PM
    Bolt79
    White Springs, FL
    Sounds like I should replace my spare as well. Thanks.
  5. Jun 17, 2011 at 12:22 AM
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    If I were you, I'd just get a matching rim and replace the spare also. No need to worry about immediately repairing/replacing a flat tire down the road (since the tire sizes and rim styles will be the same).
    When I got my 265/75/16 Duratracs I got a full set of 5 and got a matching TRD Off Road rim. To make this set of tires last longer, I'm planning on doing a 5 tire instead of 4 tire rotation.
  6. Jun 17, 2011 at 12:54 AM
    sanga700
    sanga700 Well-Known Member
    San Diego, CA
    09 Red Tacoma SR5 4x4 V6 6sp
    TRD intake Airbox,4 corners 5100 front set @ 2.5".Rear TSB,1.5" Toytec AAL,skid plate.running board, EGR in channel sun visors,Valetine one radar detector, 17x8.5 Black MB Wheels. 265/70/17 Handkook Dynapro ATM
    X2. I had these blk wheels on my truck . I filled the blk paint on little polish to make total blk wheels and they look good with 265/70/17 handkook ATM.
    http://www.discounttiredirect.com/d...11&pc=61028&counter=1&wd=17&rw=8.5&vid=019279
  7. Jun 17, 2011 at 5:54 PM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    x2
    FWIW I have Terra Gripper AT's
  8. Jun 17, 2011 at 5:57 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I'll be replacing my spare with a full size matching one once its time to buy tires again. I'm getting a in bed tire carrier though from N-Fab
  9. Jun 17, 2011 at 9:35 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I would just get a used tire in that size or get the cheapest new one you can find, regardless of brand. As long as it gets you from point A to point B if you ever have a flat, I see no reason to go all out with a matching one.
  10. Jul 8, 2011 at 8:40 AM
    B1Dude05
    B1Dude05 Member
    Abilene,Texas
    2014 Limited Double Cab LongBed 4x4
    Extang Tonno cover, Body Side Molding, Ready Lift Leveling Kit #69-5212, TRD Rims, TRD Stainless Exhaust, WeatherTech Rain Deflectors
    I was looking at the same tire set up (265/75/16 Duratracs) & was curious if you had any problems with the spare fitting in the well on that size tire?
    Thanks.
  11. Jul 8, 2011 at 1:27 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    From the reviews I've read, the TreadWright retread tires are just as good as new ones. At the very least, I would run one as a spare. I'm actually considering a full set of the Wardens (BFG A/T clone).
    http://www.treadwright.com/c-21-265-70r17.aspx
  12. Jul 8, 2011 at 1:44 PM
    jasen7
    jasen7 Well-Known Member
    Jasen
    Jersey Shore Pa.
    2007 Tacoma 2.7l
    I have been running treadwright tires on my Ram 2500 for 3 years now with no problems. 46,000 miles and still holding up great. Since they have been holding up on my heavy ass Ram hauling more loads of firewood, stone, and scrap than I can count, and also lasted through 3 trips from Pa. to Tenn. I will also be putting a set on my Tacoma with a matching spare!
  13. Jul 10, 2011 at 4:57 AM
    808hiker
    Justin
    Big Island, Hawaii
    Nope, no problems. It fit fine...just barely though.
  14. Jul 10, 2011 at 7:32 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    This is a nice set up and a great way to go if you have the extra cash, and since you are only one tire size up from the stock tire size, your new spare will fit into the standard carrier. But my question is to the OP, did they change the spare tire type on the 011's? If not, you will only be one size down from your new tires with the stock spare? This is far from a temp. donut spare found on many vehicles. The spare might not be the same traction level as the new tires you put on, but at one size smaller you probably will not even feel the difference running down the road. My stock spare is rated for 50,000 miles (Dunlops), and whatever came with your truck stock should be simular. If it were me, I would use the brand new stock spare until it ages past safety, then I would look for a good used spare or buy a new tire to match the set you are running for your spare in the future.
    By the way, even if you get a flat and have the same size tire/rim for a spare, you still need to get the tire fixed asap regardless unless you like running without a spare at all!
  15. Jul 10, 2011 at 10:49 AM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    :confused:
    That's what a differential is for. Do you never go around corners either?
  16. Jul 10, 2011 at 10:53 AM
    jsmarine
    jsmarine Well-Known Member
    Jeff
    Dallas, TX
    2005 Tacoma SR5 Crew Cab 4x4
    ARB front & rear lockers ARB bull bar Warn XP9000 winch IPF lights
    X2, but if you are patient you can probably find one that matches. I was able to find a almost new matching BFG AT in my size off craigslist for $80.
  17. Jul 10, 2011 at 11:39 AM
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    You dont want two different size tires on any axle that has power to it. It will damage your vehicle, especially the differential.
  18. Jul 10, 2011 at 11:57 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Bingo.
    Fink:headbang:
  19. Jul 10, 2011 at 1:09 PM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    different sizes will ruin the diff.
  20. Jul 10, 2011 at 2:08 PM
    horwitzs
    Seth
    Dayton, WA
    TX Pro
    Then why aren't you harming it every time you turn? The different radii act no differently than having different tire sizes.
    I realize turns are just now and then instead of full-time, but still would stress the diff, no?
    I'm not trying to be a dick, I believe you about different tires sizes being bad... just trying to understand the logic here since the diff was invented to allow the wheels to turn at different speeds.
