Should I replace just the burnt exhaust valves?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mustardman717, Jan 7, 2021.
  1. Jan 7, 2021 at 9:25 PM
    mustardman717
    mustardman717 [OP] Member
    2000 2.7 3rz tacoma MT 4x4
    .. I have 3 cylinders with low compression.
    Yadda yadda, I got the head off and tested the valves and i have a few exhaust valves that leak bad. See vid here https://youtu.be/aQji8LHWoiI
    It's like a oval shaped compared to its sister exhaust valve... you can see the lip in the pic when I put them end to end. ... and in the side by side pic the height difference is visible too
    Is it common to just replace them all at the same time? Or should I replace the 3 that are obviously not round?
  2. Jan 7, 2021 at 9:27 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I'm no expert in heads, but I would take it to a head shop and let them look. With my burnt valve they just replaced the one, surfaced the head, put in new valve seals, and set all the shims.
    @Speedytech7 might have some input too.
  3. Jan 7, 2021 at 9:27 PM
    Tacosrus
    Tacosrus Carpe Diem
    Northern California
    2018 Blazing Blue Pearl SR5 DCSB
    Looks like a double post
    PennSilverTaco likes this.
  4. Jan 7, 2021 at 9:28 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    My opinion. You’re already in there and have the head off. Do them all.
  5. Jan 7, 2021 at 9:30 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck
    Why’d you post the same thing twice?
  6. Jan 7, 2021 at 10:23 PM
    jayys05
    jayys05 Well-Known Member
    Jonathan
    97 shorty
    bash my head on it
    inspect valves if any others show signs of abnormal wear, otherwise no need to replace
  7. Jan 8, 2021 at 8:55 AM
    mustardman717
  8. Jan 8, 2021 at 8:56 AM
    mustardman717
  9. Jan 8, 2021 at 9:27 AM
    mustardman717
    So maybe another opinion sort of question... but how concerned should I be about getting OEM valves in there? I was thinking of buying a set from yotashop and bringing it to the machine shop for them to install... I assume they would put after market ones in, but I dunno if that's fine or not.
    OEM exhaust valves are 25$ each for this 2.7L 3rz head
  10. Jan 8, 2021 at 11:05 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I replaced my head with one from kingcylinderheads.com
    Been happy with mine and still going strong. Comes shimmed already and upper valve train already all assembled
  11. Jan 8, 2021 at 11:17 AM
    0xDEADBEEF
    The head shop I went to gave me no reason to replace valves that weren't burnt. Runs fine. As long as they're the right shape, they do their job.
    Come to think of it, replacing all the valves may add to your labor cost considerably.
  12. Jan 8, 2021 at 1:43 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    Not really, they need to take out all the valves and grind them anyway. Actually, it would be a bit less labor, because the new valves won't need grinding/machining.
    0xDEADBEEF[QUOTED] likes this.
  13. Jan 9, 2021 at 7:39 AM
    Glamisman
    Glamisman Well-Known Member
    if it were me I would determine why this needs to be done. If it was due to a valve adjustment isuse is one thing if it was due to high mileage, that is something else. If the seats are worn because of high mileage then a valve job is needed if it is due to lack of adjustment and the seats arent damaged the low budget way is new valves lapped in.
  14. Jan 9, 2021 at 8:35 AM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    I just had a head completely redone for 625.00 . You don’t want to tear it apart again
  15. Jan 10, 2021 at 9:05 AM
    mustardman717
    well, before i took the head off i checked valve clearances, and all exhaust but one was 0.000" .. the odd one was 0.006", still not in spec which is 0.010 to 0.014. So ya, with that in mind, im thinking ill just do all exhaust valves to be safe.. i was thinking maybe they are all "burnt" and maybe leak some anyway under higher pressure, but just the 3 that i marked with a X are the really bad ones that leak with a simple water test.
    anyway im going to have the machine shop resurface it anyway, so i think i will just let them handle the valves.. i do believe some of the exhaust valve seats might need some work, but the intakes seats look perfect.. ie. i can see the 3 angle cut clearly. the exhaust seats look a little more smooth. Off to the shop it goes next week.
    Now on to tackle the timing chain :)
