Should I pay $1000 to get my injectors replaced
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jrose, Jan 17, 2013.
  1. Jan 17, 2013 at 11:38 AM
    Jrose
    Jrose [OP] Member
    Jacob
    BC
    98 Tacoma 2.7l 4x4 SR5
    Tires, for now
    So I've been having some trouble with my truck, a 98 2.7 4x4. It had been periodically stalling at a low idle, and running a bit off. I brought it in to get checked, and was told that my injectors were clogged and would need to be replaced, at a cost of about $1000. I believe that he's right about the injectors being fucked, the fuel filter was the stock toyota one, after 150,000 miles.(I didn't know this, was led to believe it had been changed by the previous owner.) Anyways, I want to know if its worth getting this done at this shop, the price seems ridiculous to me. I know I can buy the injectors much, much cheaper, but I don't know if I'd be able to install them myself. I don't have a ton of mechanical experience, but I can follow a good set of instructions well. What do you guys think, is it doable myself, should I look to get it done else where, or bite the bullet?
  2. Jan 17, 2013 at 11:51 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Shouldn't cost that much for 4 injectors. Depending on your skill you could do it.
  3. Jan 17, 2013 at 11:54 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    what is the cost of a flow test ? check around, yank your injector(s) and bring
    them somewhere for a quick flow check. with the right equipment should take
    just a few minutes to tell if they are crap or not
    ask around, $1000.00 is a hefty 'guess' unless you yourself see the injectors dribble instead of spray
    get junkyard injectors if you need them replaced
  4. Jan 17, 2013 at 4:02 PM
    Jrose
    Jrose [OP] Member
    Jacob
    BC
    Tires, for now
    I'll check around to see who can do a flow test, I'm living in whistler so pretty everything is overpriced here to. Does anybody know of a guide to removing my injectors?
  5. Jan 17, 2013 at 4:10 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'd be running a concentrated amount of fuel system cleaner through it and see if it frees up the injectors, first.
    DO NOT LET THIS GUY REPLACE YOUR INJECTORS.
  6. Jan 17, 2013 at 5:03 PM
    Mossy
    Mossy Mechanic for Honda
    billy
    san antonio, TX
    ProComp lift Borla exhaust Borla air filter Nfab bars
    Where u from. If your close ill help u put them in. Please don't spend that much to do something so simple.
  7. Jan 17, 2013 at 5:14 PM
    Jrose
    Jrose [OP] Member
    Jacob
    BC
    Tires, for now
    I"m from whistler BC. Ya I didn't let the shop do anything. Another option would be to buy the injectors myself and get a shop to install them, cause they were saying they would cost 175 apiece to buy, plus installation, but I can find the parts online for 45 apiece.
  8. Jan 17, 2013 at 5:15 PM
    Mossy
    billy
    san antonio, TX
    Buy them yourself and watch videos or get a book. Or take a ton of pics and post them. We can walk you through it!
  9. Jan 17, 2013 at 5:22 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    For shits and giggles I'd replace the EGR valve, too. [​IMG]
  10. Jan 17, 2013 at 7:29 PM
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    2018 Tacoma TRD Sport access cab, magnetic grey metallic.
    My same thought!
    Run some fuel injector cleaner, and dry gas, or seafoam in a tank or two of gas, and go from there. Maby clean the throttle body also.
    I've run three 4-cyls.; 2>186,000 mi., 1>227,000 mi., and never had a problem with the injectors.
  11. Jan 18, 2013 at 3:43 PM
    Jrose
    Jrose [OP] Member
    Jacob
    BC
    Tires, for now
    Ya I think I'll do this, I'll post up here for some advice before I start, probably will be a little while, to cold to work on a truck now haha
  12. Jan 18, 2013 at 4:59 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    they are pretty easy to pull. the hard part is
    pulling all the other crap off to get to them.
    it is plug-n-play like a spark plug, but with gas inside
  13. Jan 25, 2013 at 11:07 AM
    Jrose
    Jrose [OP] Member
    Jacob
    BC
    Tires, for now
  14. Jan 25, 2013 at 11:26 AM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Beck Arnley is a good brand.
  15. Jan 27, 2013 at 5:02 PM
    Jrose
    Jrose [OP] Member
    Jacob
    BC
    Tires, for now
    does anybody know of a good guide online on how to do this. All haven't seen anything for a tacoma yet
  16. Jan 27, 2013 at 8:02 PM
    BamaToy1997
    Bill
    Navarre, FL
    Personally I would NEVER put junk yard injectors into a vehicle. You have no idea how long they have been sitting with fuel in them, and getting all gummed up. Too risky in my opinion.
    If you like I will post what I can tomorrow on how to replace injectors on your truck. It is a simple job, and you will be maybe looking at 2 hours tops to do the job yourself depending on what hand tools you have, and your skill level.
  17. Jan 29, 2013 at 5:41 PM
    Jrose
    Jrose [OP] Member
    Jacob
    BC
    Tires, for now
    that would be amazing
  18. Feb 17, 2013 at 7:12 PM
    Jrose
    Jrose [OP] Member
    Jacob
    BC
    Tires, for now
    So i'm just ordering the parts now, got a little busy and put it off. I should get them in a week or so. Any guides or tips would be awesome. Are there any special tools I will need that I should buy as well, I just have a standard socket set.
  19. Feb 17, 2013 at 7:25 PM
    Moco
    Moco Well-Known Member
    Eric
    NoVA
    96 Regular Cab 4x4 5spd
    Jesus, yes.
    Even the hardest job is made easier with the right tools and the easiest job is made impossible with incorrect tools.
    As a caveat, I've never done injectors on a Tacoma, but I have done them on my old 4.6L SOHC Mustang.
    My recommendation on tools would be:
    • quality metric socket set - at least 8-19mm
    • ratchet extensions 3,6,9 in.
    • a telescoping magnetic wand
    • fuel line disconnect tools
    • rags
    • a pair of needle nose pliers
    • 2 or 3 sizes of flat head screwdriver
    • wobble extensions
    • a flashlight or light
    • torque wrench
    • penetrating lube/oil
    • carb cleaner
    You can get most if not all of the above at places like SEARs and Harbor Freight for less than a $100.
  20. Feb 18, 2013 at 11:10 AM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    is your truck throwing any codes? the codes will tell you what area to look into. it may be an ignition, MAF or throttle body issue. Or even an exhaust O2 problem. a lot of things can cause your syptoms.
