Shortening my exhaust system
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PittIsTheMan, Mar 10, 2015.
  1. Mar 10, 2015 at 4:45 PM
    PittIsTheMan
    PittIsTheMan [OP] Member
    Jordan
    Alabama
    2006 SR5
    So i have a 2006 taco with the 4.0. I want to install a flow master 40 series and would like to shorten the exhaust system to dump in front of the rear axle. However i am unsure how short is too short in regards to back pressure issues and loss of power. Any guidance would be much appreciated.
  2. Mar 10, 2015 at 4:48 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    The length will not affect the power as much as the change in the type of muffler. Also you have to be sure it will pass inspection in your state. Some states that would not pass.
  3. Mar 10, 2015 at 4:51 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    Won't loose any power, but get ready for a nice annoying drone inside the cab. I had mine dumped before the axle with an AERO muffler for a while and didn't like it. I have magnaflow run out the back now and like it better.
  4. Mar 10, 2015 at 4:55 PM
    PittIsTheMan
    Jordan
    Alabama
    2006 SR5
    Luckily my state doesn't require a vehicle inspection of any kind. I hear rumor of the exhaust system being an odd size on my truck such as a 2.398". Do you know if it will mate up with a 2.5" without major redneck engineering?
  5. Mar 10, 2015 at 4:56 PM
    PittIsTheMan
    Jordan
    Alabama
    2006 SR5
    Hmmmm i may have to reconsider shortening them then. Was the drone totally unbearable or just got old after some time?
    Also how obnoxious will removing my cats make it?
  6. Mar 10, 2015 at 5:01 PM
    reece13
    North Carolina
    Wasn't awful, just got annoying if you're driving for a while. Plus i had to turn up the radio pretty load to hear alot of the time. I think some people that rode with me were annoyed with it too. You might like it if you like that kinda thing, i personally just didnt. These v6's can put out some noise.
  7. Mar 10, 2015 at 5:03 PM
    PittIsTheMan
    Jordan
    Alabama
    2006 SR5
    Sweet thanks for the info
  8. Mar 10, 2015 at 5:12 PM
    PittIsTheMan
    Jordan
    Alabama
    2006 SR5
    is that a huge issue with the 4.0 cause i have had them on multiple V8s and never had a problem with restricted exhaust flow?
  9. Mar 10, 2015 at 5:18 PM
    PittIsTheMan
    Jordan
    Alabama
    2006 SR5
    Ah i wasn't aware
  10. May 7, 2015 at 3:59 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    What do you guys think of this? I'm also going to dump my exhaust in front of the axle to make room for an auxiliary fuel tank. I was going to have a shop cut it off and weld on a down turn so the exhaust exits toward the ground.
    I just saw this at a local auto parts store for like $8. What are your thoughts?
  11. May 7, 2015 at 4:22 PM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    hahaha, hope you are just kidding? those are junk
  12. May 7, 2015 at 4:23 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    Is it because of the sharp edges?
  13. May 7, 2015 at 4:49 PM
    gottaToy
    JJ
    1985 Moped
    it's a metric size exhaust. 2.5 won't even be close. I'd say screw the muffler and buy a couple 20" MRBP resonators and dump it short. You'll have to take it somewhere to have something fabricated to accommodate going from the metric to 2.5 or try and find an aftermarket maker that will sell you a piece from the flange to the muffler inlet ONLY. I bought the DBX kit and it was so loud inside it unbearable, the added resonator made it so much better, deeper tone, and less raspy. I considered the 2 resonator setup, but couldn't find one 2.5 in 3 out to replace the flowmaster muffler and I want stock dump location.
  14. May 7, 2015 at 4:51 PM
    gottaToy
    JJ
    1985 Moped
    That cheap thing will break within a month and is total junkyard, demo derby, white trash, redneck, and every other stupid name one can think of.
  15. May 7, 2015 at 4:54 PM
    Justn868
    Justn868 Well-Known Member
    Justin
    Kansas City
    14 4x4 TRD OR
    Just cut it after the stock muffler and throw on a turn down.
  16. May 7, 2015 at 5:58 PM
    otis24
    Mark
    California
    I had a dumb moment...it's pretty obvious now that I've posted it.
