Shock Boots- Like a wrinkled sock....??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crow Horse, Aug 21, 2018.
  1. Aug 21, 2018 at 1:00 PM
    Crow Horse
    Crow Horse [OP] Well-Known Member
    Central NY
    2012 DCSB TRDOR
    I just installed Billy 5100's in the rear, pretty simple. They did come with the boots already "installed" with the tie rap. Trouble is, in the neutral position it looks like a wrinkled sock. I'm inclined to cut the tie rap and either leave it hang loose or just reposition it. In the past with similar shocks, I've cut it a bit shorter and it hung loose. My thinking was that water and crud won't collect just above the tie rap and below the drain holes.... Any thoughts on this?
  2. Aug 21, 2018 at 1:05 PM
    obhuan
    obhuan Well-Known Member
    Tacoma, WA
    09 DCSB TRD OR
    I run mine without the boot entirely. Cut it off a few months after installing them because of the "wrinkled sock" look you mentioned. I've heard some people say leaving it on traps dirt/debris back there whereas without them nothing gets trapped and you can clean it off after wheeling. Its worked fine for over a year for me.
    Gunshot-6A likes this.
  3. Aug 21, 2018 at 1:10 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    happened on my new dirt bike back in 91 after going through lots of thickets, I just ignored it and been fine since
  4. Aug 21, 2018 at 1:50 PM
    Pigpen
    Northwest Montana
    The boots do nothing. It looks better with them off too.
  5. Aug 21, 2018 at 3:01 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    My sense of it is if they are removed, road debris could "sandblast" the shaft and create minute defects in it's finish. As the rod cycles through the seal(s), it could lead to premature failure of the seals.
    On the other hand, if water and debris breach the boot and can't evacuate, this could lead to developing rust and thus compromise the seal(s).
    I think I'm going to cut the tie rap and see if I can get the boot to hang like a skirt. It might require some trimming and additional drain holes. A leather punch makes dandy drain holes.....
  6. Aug 21, 2018 at 3:06 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    Wrinkled sock?
    Are you implying you iron your socks? If so, do you starch them? If you use starch, what brand and how much?
    PS I don't care what shock boots look like.
    Hobbs likes this.
  7. Aug 21, 2018 at 3:36 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    LOL! I couldn't come up with a better visual than wrinkled socks (saggy).......
    ABNFDC[QUOTED] likes this.
  8. Aug 21, 2018 at 3:56 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    Unrelated to the saggy sock boots, being that a 5mm allen wrench is required to hold the shaft while the nut is torqued down, I thought it was prudent to use a vinyl cap on the end to keep crud from filling it up......
    ABNFDC likes this.
  9. Aug 21, 2018 at 4:19 PM
    ABNFDC
    Granite State
    Good call.
    When I changed out my 5100s a couple years ago, the end of the shaft where the allen wrench goes in was full of crap. While it wasn't a ginormous pain in the dick, it was enough of a pain to slow me down a bit.
  10. Aug 21, 2018 at 7:09 PM
    CBenfell
    CBenfell I don’t know sh*t about f*ck
    Christian
    Western Washington
    21 DCSB TRD OR Midnight Metallic Black
    Crippling Debt
    I cut mine off. Looks funny. I think it may be to accommodate some lift, but I don’t have any lift in the rear.
  11. Aug 22, 2018 at 6:32 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    You simply put dish soap on the bottom of the shock,just below the boot and pull it down ,easy.
  12. Aug 22, 2018 at 7:25 AM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    Yep that's easy but still doesn't address water and crud not being able to completely evacuate......
  13. Aug 22, 2018 at 7:57 AM
    lynlan1819
    Tacoma
    Lifted
    Silcone the top of the boot
  14. Aug 22, 2018 at 9:00 AM
    Pigpen
    Northwest Montana
    Shocks are a wear item. Even if the debris had enough velocity to cause an issue. your shocks will need replacing before this becomes an issue.
    Jazz1one likes this.
  15. Aug 22, 2018 at 9:08 AM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    I guess we'll never know if it's really an issue that shortens the service life of the shocks. I cut mine so it just hangs loosely. Can't hurt and no more saggy, wrinkled socks....
  16. Aug 22, 2018 at 9:29 AM
    lynlan1819
    Tacoma
    Lifted
    Guess your whole thread was just for fun and games.
  17. Aug 22, 2018 at 9:42 AM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    No, not for sh!ts and giggles. I was serious. I'll probably never have our Tacos built like many have (I do drool over them), but the few things I can do, I want them to be as spot on as possible. My mantra is "Set your goals high, then try to surpass them. If you set your goals low, you'll hit them with amazing accuracy."
  18. Aug 22, 2018 at 9:43 AM
    Micatom33
    Micatom33 Under the Truck with Beer!
    Santa Cruz,CA
    2008 BSP DCSB
  19. Aug 22, 2018 at 9:58 AM
    ImMrCrash
    ImMrCrash Intermittent Error
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    Bilstein 5100’s Dakar CS047R Supreme Suspension U-Bolt flip kit Sumo Springs Blue ADV Fiberglass Fenders 1st Gen Snorkel DV8 Apex Plate Bumper X-Bull 13k Winch KC HiLiTES 6x9 Trail-Gear Sliders 4x Innovations LCA Skids Spidertrax 1.25” Eagle Alloy 16x8 4” BS Fierce Attitude M/T 315/75R16 Bearcat 980SSB CB
  20. Aug 22, 2018 at 10:23 AM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    I suppose you're right.... This after I cut the boot so it just hangs. No more saggy socks....
