Shock-based Bump Stop Failure
Discussion in '4th Gen. Tacomas (2024+)' started by Sinister184, Aug 12, 2024.
Thread Status:
Not open for further replies.
  1. Aug 12, 2024 at 6:38 AM
    Sinister184
    Sinister184 [OP] Well-Known Member
    23 Tacoma TRD OR 4x4
    Is this being discussed? I didn't see a thread on it. Apparently out of the TNGA vehicles, the Tacoma is the only one with this design. All the rest have frame-mounted bump stops. Seems like a weak design.
    https://www.youtube.com/watch?v=gn2Be4jAj_w
    batacoma likes this.
  2. Aug 12, 2024 at 6:41 AM
    Want-a-taco
    Want-a-taco Well-Known Member
    New Brunswick, Canada
    2024 TRD Offroad 6MT black
  3. Aug 12, 2024 at 6:43 AM
    Sinister184
  4. Aug 12, 2024 at 7:00 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I'll watch a rerun, What bump stop design does the LC 250 use? I thought I saw the answer posted, but I can't recall.
    What other vehicles have internal bump stop shocks? The 4G Tacoma is the only vehicle that I'm aware of with this design. I can't believe it's an all new way to design shocks.
  5. Aug 12, 2024 at 7:25 AM
    Sinister184
    The suspension is similar to the Tundra and Land Cruiser 250, but both of those use frame-mounted bump stops. Toyota could easily accommodate the switch to a similar design in the coming model years of the Tacoma - but will they?
    I imagine those with some welding experience could likely also buy the lower arm from a LC and weld on the bump-stop frame supports.
    batacoma[QUOTED] and Vidman like this.
  6. Aug 12, 2024 at 10:17 AM
    batacoma
    batacoma Truck Wars
    Seems strange to me that Toyota is using two different designs with the bump stops, but two completely different trucks built on two different sides of the world.
    I prefer the external bumps out of familiarity, and they sound more robust. Not so much with OEM, but with the aftermarket and AM coilovers needing to be design with the internal bump.
    This is the most interesting thing about the 4G IMO, I'll be watching to see if the design changes.
  7. Aug 12, 2024 at 10:44 AM
    Jacob06
    Jacob06 Well-Known Member
    Atlanta
    2024 TRDOR 6MT
    I think all these piggy back internal bumpstop shocks are mickeymouse.
    It's like they created this bizzaro shock type so that they could have aftermarket name brand suspension on their trucks (not just toyota)
    And then the aftermarket still has something to offer owners (normal external resi type)
    Not that I was planning on keeping the shocks it came with...
    Its just marketing gimmicks- look here on the Pro, you have 3 settings!
    Notice that they arent integrated into the truck in any way electronically because they know that the real offroaders will be taking them off.
    The only real upgrade on the TH and Pro suspension is the upper control arms and Id be curious to know what kind of extra travel or articulation they provide over the stock ones.
    Like how many degrees more does it yield?
    Ive wandered off topic... internal bumpstops not working out doesnt seem like a big suprise, I'm glad someone found a cheap fix
  8. Aug 12, 2024 at 12:36 PM
    Sinister184
    What I wonder is the shock tower's strength to absorb hard bottom outs. It has to be considerably less robust than than the frame. I could honestly see Toyota saying they made that hat piece designed to fail before potentially causing damage to the tower. If that's the case, then using the Icon solid hat could cause more damage. The biggest question is, why did they make the Tacoma different, and less robust, than everything else?
    glwood6 and Vitamins like this.
  9. Aug 12, 2024 at 1:09 PM
    Jacob06
    Atlanta
    2024 TRDOR 6MT
    Good point.
  10. Aug 12, 2024 at 1:09 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    According to the Chief Engineer, they didn’t.
  11. Aug 12, 2024 at 4:17 PM
    Tacowrench
    Tacowrench Well-Known Member
    Northern California
    2024 Bronze Tacoma TRD Off-Road
    Definitely a design flaw, you can see where the cap broke at each indent. Also, looks like cheap cast aluminum pot material. A nice stainless steel or high alloy carbon steel cap would fix it.
  12. Aug 12, 2024 at 4:20 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Locked since we have a thread on this already.
Thread Status:
