Shims on stock leafs
Discussion in 'Suspension' started by Vea, May 14, 2018.
  1. May 14, 2018 at 5:32 PM
    Vea
    Vea [OP] Well-Known Member
    2018 Tacoma or
    Looking at the leaf springs on a stock 2018 off-road, it appears to have a 2 or 3 degree shim below the springs. Is this the norm?
  2. May 14, 2018 at 5:35 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Shim yes but I hardly doubt is that much of a degree of a shim. My 2015 had one but it was like a thin piece of metal. You have a pic of the area?
  3. Jul 21, 2021 at 10:59 AM
    blqchclt
    blqchclt Oh, that's what this is for
    2018 Quicksand DCSB
    Reviving this because I just took off my stock leafs to install the icon multi-rate RXT pack and discovered that my 2018 also has shims.
    Only problem is they're basically seized to the OEM leaf and I can't get them off without bending/most likely just can't.
    Should I even bother using them?
  4. Jul 24, 2021 at 10:30 AM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    They are bolted on using the center pin. If you remove the center pin it should slide off.
    blqchclt[QUOTED] likes this.
