shifting without clutch
Discussion in 'Toyota Trucks & SUVs' started by mrdinh, Jan 14, 2011.
  1. Jan 14, 2011 at 10:16 AM
    mrdinh
    mrdinh [OP] Active Member
    TRD SR5
    westin nerf bars and argricover soft roll up bed cover
    was told that this can be done...save the money of replacing the clutch...i don't do this...any recommendation?
  2. Jan 14, 2011 at 10:23 AM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    It can be done and will reduce wear on the clutch if done properly. If not done correctly, it'll wear on the clutch and synchros worse than using the clutch. As someone who's done it many times in 18-wheelers I can tell you I find it hard to do just right on my 4 cylinder Tacoma. I think it's due to the small engine.
  3. Jan 14, 2011 at 10:26 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Your clutch takes a lot more wear from taking off than it does from shifting gears...
    Can it be done? Sure...BUT WHY!?
    If you drive a manual transmission properly, your clutch should last a very long time.
  4. Jan 14, 2011 at 10:29 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I say just use the clutch its a lot cheaper to replace the clutch then rebuilding the gear box. If you want to shift with out a clutch buy an auto.
  5. Jan 14, 2011 at 10:30 AM
    sethr21785
    sethr21785 Well-Known Member
    Seth
    Lake Jackson TX
    00 Tundra
    Even if you clutch wears out after 150k miles its a fun day project to replace and only sets you back a couple hundred bucks.. just use it
  6. Jan 14, 2011 at 10:42 AM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    WTF????
    Syncro'd transmission, hydraulic clutch and you want to "play" 18-wheeler ???
    After 30 ( yes 30;) ) years of Toyotas, I have had 1 transmission noise (3rd gear sycros on our '81 Corolla SR5,wife would rest her arm on the "stick":rolleyes: while driving to work ) ; no clutch's or other tran's including teaching 2 teen-agers to drive since!!!!!
    My "Office" has always been an over-size pick-up made by Peterbilt or Mack and "shifting" can be an "art" or a bad dream.....just ask the shop foreman ;):p:cool:.....Proper shifting technique is an "old timers" dream and explains why so many companies now have automatics...including ours....my current "Office" has an Allison 6 speed ;)
    SORRY .RANT over, they gave you a clutch.try to use it....
  7. Jan 14, 2011 at 11:35 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Lift on upshifts and blip the throttle to match revs on downshifts. It's doable but not worth the risk unless you are racing on the track (where you can maintain constant 8/10th concentration on just driving).
    I actually haven't seen a manual 2nd gen. in person. Are the pedals spaced well for heel-and-toe?
  8. Jan 14, 2011 at 12:35 PM
    macgyver
    Brad
    Canton, GA
    Yep...I heel-toe downshift when I am slowing down/braking. It makes downshifting much smoother.
    I have always heel toed my vehicles so it has become habit.
  9. Jan 14, 2011 at 12:47 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    I heel toe in mine, but only with certain shoes, in my work shoes its like suicide.
    Heel toe in the taco sucks cuz of drive by wire, its more like heel and pray the throttle goes up like u want it. In my wrx I can get it perfect every time, throttle cable ftw
  10. Jan 14, 2011 at 12:53 PM
    ::childstoy::
    ::childstoy:: Hi-Tech Rednek
    Southeast, PA
    Black 2010 TRD Sport
    TRD Exhaust, Tint, Stubby Ant., Debadged, Weathertech Mats, Grillcraft... Currently collecting donations for a New Tires Fund.
    I used to do this all the time in an old S-10 I used to have...My clutch eventually went in that S-10 and knowing how to "air-shift" got me through the work week until I could rip the tranny out and do the clutch.
    Knowing how to do it won't kill you in the event that you ever need to. But like the guys are saying above, its not worth it. You can really fubar your trans if done wrong.
  11. Jan 20, 2011 at 7:50 PM
    ISUGrad05
    ISUGrad05 Public Servant Enemy #1
    Wichita, KS
    2012 4x4 5.7 Tundra DoubleCab
    I did this from time to time in my 94. Don't think I'll be doing the same in my 2011.
  12. Jan 20, 2011 at 7:53 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    :laugh:
    what he said
  13. Jan 20, 2011 at 7:59 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    I had a vw van (bus ) clutch cable broke on the way to work. I just pulled off to the side of the road and smoked a bunch of pot. Then when I wanted to go home I reved each gear really high and when the transmission meshed into another gear I shifted. it works.
  14. Jan 21, 2011 at 11:57 PM
    drifter
    drifter moderately modded
    Sam
    Oregon
    good stuff
    OME 880's/Nitrochargers, Rebuilt leaf packs, diff breather extension, hole in air box, truck toolbox, panasonic stereo, Mag light mount, Glasstite canopy, Custom designed/built light bar, Hella 500's.
    80 horsepower man, those things are sleepers. ;)
    lol:
    http://www.youtube.com/watch?v=jzIshBeImFU?fs=1
  15. Jan 22, 2011 at 7:30 AM
    mntbiker2008
    mntbiker2008 First I derp.. then I herp
    Aaron
    Cincinnati, OH
    93 Pick up 4x4 (sold), 10' Mazda 3
    x2. I only put 2 clutches in my pre taco one at 50k and the other at 90k (it could have gone a lot longer though. The first blew on my dad when he had it.
  16. Jan 23, 2011 at 8:37 AM
    ISUGrad05
    Wichita, KS
    I've had 2 Accords with 200,000+ miles, 85 Volvo w/145,000 and 94 yota truck with 116,000 and never had to replace a single clutch.
  17. Jan 23, 2011 at 8:53 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Well said!
    For you guys who heel/toe, did that recall where they reflash the ECU affect you being able to do that? Just curious, I've got an auto so all the recall did to me was make brake stands impossible and the skinny pedal a little shorter....
