Shifting into 3rd speed causes grinding noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, May 4, 2015.
  1. May 4, 2015 at 2:07 PM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    I have a 2007 v6 4x4 manual transmission.
    When I shift from the 2nd to the 3rd speed, unless done super carefully, it causes a grinding noise. By "super carefully" I mean I first rev it up to 3K RPM, then keep the clutch pressed some 2-3 sec at least, then shift very slowly, much slower than other speeds. The process takes so long that the truck loses a lot of speed and when I am finally shifted into the 3rd speed, the RPM is more like 1.5K from about 3K where it was in the 2nd speed.
    What causes this grinding noise and can it be fixed without replacing the whole transmission?
  2. May 4, 2015 at 2:13 PM
    4x4Banger
    4x4Banger Gold Member
    Ham
    Los Angeles
    2012 DCSB/OR 4x4
    The 5 speed has its issues also
  3. May 4, 2015 at 2:20 PM
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
  4. May 4, 2015 at 4:20 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Sounds like the 3rd gear synchro is bad. The reason it's shifting more smoothly when you rev it is because your bassically doing what the synchro is suppose to do.
  5. May 4, 2015 at 5:53 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    3rd and 5th on these trucks have poor synchronizers. They tend to clunk from the factory. My guess is that you have almost or totally lost the synchronizer in third. Forget about third and fifth, and just use 1st 2nd, 4th, and 6th. Rarely is 3rd and 5th needed.
  6. May 4, 2015 at 6:06 PM
    TRD 603
    TRD 603 Well-Known Member
    Michael
    Seacoast, NH
    2005 Tacoma TRD
    Custom Paint
    Def third gear synchro. had the same issue.
  7. May 5, 2015 at 8:52 AM
    foampile
    Mid-Atlantic
    Can I just replace the 3rd gear synchro ?
  8. May 5, 2015 at 9:03 AM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    My 5spd does this but only to a minor degree when I'm hammering through the gears on the freeway late for work other than that it's silent and I drive like an old man in the city
  9. May 5, 2015 at 9:38 AM
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    I skip shift normally. Only time I've really used 3rd was in the mountains or in 4WL. The Times I've ground 3rd on the street it was because I was really hammering on the truck and the revhang caught me.
    Normally I putt along going 1_2_4_6
    ***I actually meant to put this in the other 3rd gear grinding thread but I guess it's still mildly relivent***
  10. May 5, 2015 at 10:45 AM
    TRD 603
    Michael
    Seacoast, NH
    2005 Tacoma TRD
    Custom Paint
    Yes you can, I don't know the exact way to do it but I know a transmission shop can
  11. May 5, 2015 at 11:31 AM
    savedone
    Gerald
    Texas
    Replacing just one gear synchro would be like pulling a head because you had one burnt valve and only grinding one valve. Grind them all on that head. So yes you can but that would be sort of silly since you have the thing out and tore down. Just replace them all while you are at it.
  12. Jun 8, 2015 at 3:54 PM
    foampile
    Mid-Atlantic
    OK, I've decided to take my tranny down and rebuild it. Can you identify a list of items that should be replaced once I do that, in addition to the 3rd gear synchro ?
  13. Jun 8, 2015 at 4:04 PM
    foampile
    Mid-Atlantic
    you mean all the moving parts/gears inside the tranny case ? I don't want to buy a replacement of the whole thing. I am trying to identify the most frequently worn out components.
  14. Jun 8, 2015 at 4:08 PM
    foampile
    Mid-Atlantic
