Shifting from 2H to 4H?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by oldschoolczar, Dec 19, 2016.
  1. Dec 19, 2016 at 5:47 PM
    oldschoolczar
    oldschoolczar [OP] Well-Known Member
    '16 DCSB TRD OR
    I picked up my 2016 in June and am just getting around to driving in the snow.
    There's lots of mixed driving here in Colorado. You'll be driving down a road that's got a few inches of snow/slush/ice, turn the corner, and be driving on a road that's bone dry. It'll snow 1ft here and then it'll all be gone 3-4 days later.
    Anyway, I find myself switching between 2WD and 4WD (Hi) a lot. Have a few questions about switching back and forth.
    Can you switch from 2H to 4H while not moving? For example, I'll pull into a parking spot in 2H that's got 6 inches of snow/slush. When it's time to leave, it's hard to get out sometimes in 2H, so I'll try to switch to 4H while not moving. Today I switched to 4H while not moving and I cranked the wheel all the way to the left to get out of the spot while it was still transitioning from 2H to 4H (i.e., the 4WD indicator was still flashing on the dash. Kind of "popped" into 4H while I was turning out of the spot with the wheel cranked. Any concerns with this technique?
    Anyway, this is my first part-time 4WD vehicle so am I doing any damage by doing this? Would it be better to just leave it in 4WD while parking on snowy/slushy roads?
    Any advice would be much appreciated!
  2. Dec 19, 2016 at 6:14 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    You can switch between 2H and 4H pretty easily and any time you want. I used to live in CO myself and even in ice conditions here in VA I just leave 4H on while driving. You won't run into any issues driving in 4H even if road conditions change to dry. You can however experience binding if making tight turns like pulling into your driveway, parking, U-turns, etc while in 4H. You will know when it happens.. Just switch to 2H when making tight turns on dry pavement.
    p_sando, Knute, ajroder and 1 other person like this.
  3. Dec 19, 2016 at 6:20 PM
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    Sometimes it takes a bit for it to click into 4H, perfectly normal
  4. Dec 19, 2016 at 6:30 PM
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    Transitioning to or from 4h with the wheel cranked will be difficult because you're turning front and rear at different speeds. 4h will be aggressive and going to 2h while binding is unlikely to disengage.
    JoeCOVA likes this.
  5. Dec 19, 2016 at 6:59 PM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    If there is 6 inches of snow just pop it into 4h as you roll into the spot and leave it in 4h? Will still be in 4h when you turn the truck on and if conditions have changed for the better turn back to 2h.
    Or other option is roll in with 2h, when you start truck, turn to 4h, roll forward a few inches or backwards a few inches straight to get it into 4h. Then pull out as normal. Just what you have to do with an electronic 4wd switch.
    TacoRD16 likes this.
  6. Dec 19, 2016 at 11:21 PM
    RidgeSport604
    RidgeSport604 Well-Known Member
    Maple Ridge, BC
    2016 TRD Sport DCLB
    3" RC lift 17x9 Fuel Octanes 285/70/17 BFG KO2s Go Performance LEDs Exceptionally good looking driver
    Noob question, somewhat related: have noticed when I am in 4H and am at full crank with the wheel tight turning, feels like I am grinding to a stop...that because all 4 wheels are engaged, whereas in 2wd it's only rear propelled? First time truck/4x4 owner...
  7. Dec 19, 2016 at 11:31 PM
    Jrobb
    Jrobb Well-Known Member
    Jon
    SF Bay Area
    2017 Double Cab Lb SR5 Magnetic Grey Metallic
    I noticed sometimes switching out of 4H if under power like accelerating moderately or going uphill there is a clunk when disengaging. To prevent this I try to engage or disengage under with as little load on the drivetrain as possible.
    J
    RidgeSport604 likes this.
  8. Dec 20, 2016 at 3:05 AM
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Front and rear are locked together to turn at same speed but if you're turning the wheel, front want to turn faster than rear. Causes binding.
    RidgeSport604[QUOTED] likes this.
  9. Dec 20, 2016 at 5:18 AM
    RidgeSport604
    Maple Ridge, BC
    2016 TRD Sport DCLB
    Thanks! That's what I figured. Binding going to cause damage?
  10. Dec 20, 2016 at 6:10 AM
    backtrack2015
    backtrack2015 Well-Known Member
    Austin TX
    2016 Silver DCSB OR 4x4 AT Tech (sold 8/17)
    Pop-n-lock tailgate. New radio knobs. Rear step.
    Just make sure you don't use 4WD unless you are on a surface that allows the wheels to slip (dirt, gravel, snow, ice, etc.). You don't want to use 4WD on dry pavement as it can damage the transfer case (someone here grenaded a case almost a year ago by using 4WD on dry pavement and making a sharp turn).
  11. Dec 20, 2016 at 6:14 AM
    Truggin
    Truggin What a long, strange trip it's been
    Don
    39.15737720308645, -77.92212986904099
    Black 2016 TRD Sport V6 4x4 Access Cab
    It's a work in progress. See my build thread.
    Never, ever, run 4WD on dry pavement at low speeds, unless you are going in a straight line. There is no "slip" built in to compensate for the wheels turning at different speeds. Google 4WD versus AWD.
  12. Dec 20, 2016 at 6:35 AM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    This is why I don't buy used cars
  13. Dec 20, 2016 at 7:01 AM
    jholc21
    jholc21 Well-Known Member
    Colorado
    2017 White Tacoma TRD OR
    Bilstein 6112/5160 w/Dakars Leafs 255/80/R17 Cooper ST MAXX Skinnies 4.88 Gears TRD Pro Fog Lights Cali Raised 5D Combo Leather Seats LED Bed Lighting ARE Overland Shell
    both 2nd and 3rd gens seem to click in to 4HI quicker if you are moving. I usually try to unload the engine when switching, ie. no acceleration and no deceleration when switching. click over wait a second and then apply some power and it clicks in right away.
  14. Dec 20, 2016 at 10:06 AM
    RidgeSport604
    Maple Ridge, BC
    2016 TRD Sport DCLB
    Lol, gotta learn somewhere right? Plus, I give it back and exchange it in a coupme years anyways.
  15. Dec 28, 2021 at 9:42 AM
    gheeno
    gheeno Member
    Gheeno
    2021 Tacoma TRD off-road
    full stock
    Is it safe if you constantly toggle between 4H to 2H vice versa?
    Example: I live in a community where there is a lot of snow and very low traction due to ice. I use 4H,
    But as soon as I leave the community, it's a highway, and then I switch to 2H. I do this twice a day, every day.
    I can't read anywhere in the manual if this practice is okay. What do you guys think?
  16. Dec 28, 2021 at 9:49 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Its fine. 4H is designed to be used 'on the fly'. Just make sure you never engage it when the tires are slipping (ie - you start to slip and decide to suddenly hit the 4hi button, good way to break things). A good rule of thumb is to just remember to take your foot off the gas when engaging/disengaging 4hi.
    And keep in mind the speed limit for engaging 4hi...I don't know what it is for 3rd gens. 55 or 60 mph maybe. Once its engaged you can go as fast as your heart desires, or conditions allow.
    Junkhead likes this.
  17. Dec 28, 2021 at 9:55 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Right around 60mph. That's a lot of mass and speed for the syncro to spin up, so slower is better if you can.
    Junkhead and eon_blue[QUOTED] like this.
  18. Dec 28, 2021 at 10:09 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Switching it all the time is actually a good idea. Toyota still uses a brushed motor for the ADD and Transfer case actuators and the commutator will be kept free of corrosion by having the motor spin. Also the small gears that actuate the shift forks will have the gear lube redistributed. I would say a well used system would easily outlast one that is seldom used.
    G8R_Taco, Junkhead and tonered like this.
  19. Dec 28, 2021 at 10:21 AM
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    Totally fine. I often do the same. My community doesn't usually plow residential streets so it's often deep or rutted snow. Then I hit the highway and it's bare and dry.
    While it is fine to do, and it's good to excercise the 4x4 every now and then, don't feel you need to be in 4x4 just because there is snow. When you need 4x4 you'll know. Same goes for 4Lo. It becomes quickly apparent when you need, or will need, 4Lo.
  20. Dec 28, 2021 at 10:25 AM
    Stocklocker
    17TRDORDCSBAT
    4lo can save your transmission from overheating on long ascents, and you’ll have baked your tranny before you get any warning. Some times it’s good to anticipate as well.
