Shell to cab boots?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gsubioguy, Sep 30, 2020.
  1. Sep 30, 2020 at 6:05 PM
    gsubioguy
    gsubioguy [OP] Well-Known Member
    Evan
    Maine
    '21 TRD OR
    I'm tired of snow getting between my cap & cab then thaw/freeze into blocks of ice that rattle around and do the paint no service during the winters. What are folks using to seal their caps to the cab?
    Came across the following site. Thoughts?
    https://www.custompickup.com/shop/index.php?l=product_list&c=18
    Thanks!
  2. Sep 30, 2020 at 6:16 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    That's crazy man. Reason 6,345,976 I'm glad I live in AZ!
  3. Sep 30, 2020 at 6:24 PM
    gsubioguy
    Evan
    Maine
    '21 TRD OR
    Haha don't get me wrong, I love the winters/snow. But its a major PITA to clear the roof of a DCLB and try to avoid dumping snow in the gap. Depending in what mother nature does, I've had ice blocks rattling around for a week+. Gets obnoxious hearing it and @ 70mi/day work commute its not doing the paint a lot of good.
  4. Sep 30, 2020 at 6:25 PM
    cactushead
    cactushead Well-Known Member
    San Diego
    2017 MGM DCSB 4x4 TRDOR
    Front hitch, 5100's, 885's, Snugtop XV, Slimline II, Sumos, bed platform, AAL, interior LED lights in cab and bed, exterior camp/backup LED's, Rigid DOT Fogs and D2 Pro Spots, Mega Ultra +130 bulbs, heavy-duty fog light, spot light, and low beam wiring harness, Weathertech mats, Re-routed dif breather and A/C drip line, dash cam, front and side cameras, anytime rear camera and nav, Blue Seas fused bus bars to cab and bed, heavy-duty bus bar w/Anderson quick disconnects under the hood for powering winch, solar, air compressor, and other accessories.
  5. Sep 30, 2020 at 6:29 PM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    What cap do you have? I live in northern MN and never have ice chunk build-up between the cab and cap. Water and snow pass through there but nothing plugs up and stays there. I rarely even have to clean the glass between the two. Maybe it is the design of the cap?
  6. Sep 30, 2020 at 6:48 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Pool noodle wedged between the cap and cab might work. Cheap to in case it blows away lol.
    Never had this issue with my ARE cap in Ohio though.
    Skydvrr likes this.
  7. Oct 1, 2020 at 8:57 AM
    gsubioguy
    Evan
    Maine
    '21 TRD OR
    Its a Leer 100XL. Sides & top follow the cab's lines and while it looks like a giant scoop I don't see rain or snow getting directed down while driving. The issue is more of when I clear the roof, snow falls between. Wouldn't be an issue but the lower front lip of the cap overlaps the bedrail and results in a narrow gap of ~1".
    Skydvrr likes this.
  8. Oct 1, 2020 at 11:03 AM
    mhornco
    mhornco Well-Known Member
    My first two toyota pickups way back when had a boot on the front of the shell (no window) that sealed against the cab. Tell you this though. you had better but some clear bra or something similar on the cab, because fine grit and such that got on the boot wore through my paint in no time at all.
    hiPSI, Skydvrr and gsubioguy[OP] like this.
  9. Oct 1, 2020 at 11:12 AM
    gsubioguy
    Evan
    Maine
    '21 TRD OR
    Oh I hear you on that one @mhornco! My 1st gen I went full bore moron: had a rack on the cap and mounted the wind defector on the forward bar but so that it's seal was on the cab--to help keep snow from going between the cab & cap even though it had a boot. Sometime later I discovered it'd worn to bare metal a perfectly straight line all the way across the cab from the difference in body flex.
  10. Oct 1, 2020 at 11:15 AM
    gsubioguy
    Evan
    Maine
    '21 TRD OR
    Looking @ the 2nd picture & thinking a bit. Wonder if getting some rubber similar to what nearly seals the bed to the cab on the sides & putting that on the cap would help. Doesn't make contact but nearly fills the gap
  11. Oct 1, 2020 at 1:09 PM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    I used some pipe insulation duct taped into a ring to seal between the cab and shell on a previous truck and it worked well. I had originally used a inflatable pool toy but when the temp dropped it would deflate enough it would slip out. I wanted the window openings sealed so my dog would get heat in the bed.
