Shackles for rear leveling lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by igarrpan, Oct 15, 2010.
  1. Oct 15, 2010 at 5:08 PM
    igarrpan
    igarrpan [OP] Guest
    I'm looking to do just a 1" leveling with Shackles in the rear of my Tacoma. Anyone done this? Is it a good way to get the inch at a fairly inexpensive price?
  2. Oct 15, 2010 at 5:20 PM
    scocar
    scocar hypotenoper
    If you have the stock leaf springs, which are already notoriously weak, the shackles will wear them out even faster, from what I hear. I have never tried them, myself.
    All the "cheap" options (blocks or shackles) are not "good" long-term options, unfortunately.
    You could get an add-a-leaf, but again, if your stock leafs are already worn (sagging, or frowning), the AAL won't help. Even if your leafs are OK now, the AAL will make for a stiffer ride.
    But wait a second, why are you lifting the rear to level your truck? Did you lift the front? Whatcha doin?
    coma toy likes this.
  3. Oct 15, 2010 at 5:51 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    mine has 1.5" shackles and leveled mine out after i did the front, but my leafs are already frowning so im saving for new ones. but i like it!
  4. Oct 15, 2010 at 5:58 PM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    I do agree with scocar on going long tern instead of short but if you can afford a new set of leafs get them for a long term. idk about shackles wearing them out faster though? doesnt really make sense to me.
  5. Oct 17, 2010 at 10:47 AM
    igarrpan
    igarrpan [OP] Guest
    I did leveling blocks in the front cause my truck was stink-bugging. It didn't really "level" my truck. Now the front is about 1.5" higher. I'm just trying to get it level. Is replacing all the leafs the answer? MAybe my leafs are already sagging and thats why it didn't level my truck.
  6. Oct 17, 2010 at 11:47 AM
    scocar
    scocar hypotenoper
    Blocks (spacers) in the front? Is that making the ride stiffer/harsh?
    OK, time to start talking budget, use, etc. I can't tell if your truck is 2wd, Prerunnner 2WD, or 4x4. Let's settle that, first.
    Next, how many miles? Ever replaced shocks?
    Next, if you want to do it right and keep it close to stock, using Bilstein 5100s in the front to level with the orginal coils and replacing the rear leafs with aftermarket stock height leafs may be the right way for you.
    If you want to invest in a quality ride with a small lift front and rear that levels it, and you do some offroad stuff, I would suggest something like an OME lift (new coils and leafs, plus shocks to match).
  7. Oct 17, 2010 at 12:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Shackles have no affect on how the springs wear. All they do, is hold one end of the spring. Longer ones give lift on the first genners. if you want 1" lift, you need a shackle that is 2" longer than stock.
  8. Oct 17, 2010 at 12:30 PM
    kumaWRX
    kumaWRX Well-Known Member
    Jase
    Oahu, Hawaii
    2004 TRD Offroad PreRunner 3.4L V6
    SAW 2.0 Coilovers, Wheeler's 3-leaf AAL, Toytec 1" lift shackles, Bilstein 5100 rear shocks, aFE Stg. 2 intake, Doug Thorley headers, Magnaflow muffler, 16x8 ProComp 7089 wheels, Toyo Open Country A/T tires, Pamalu bedliner, Bakflip G2 bedcover
    I put on Toytec 1" lift shackles because even after I put the Wheeler's 3-leaf AAL the rear was too low. After I put the shackles on it leveled it for a few months, but now thw rear is about 1 inch lower than the front, which has SAW 2.0 coilovers at about 3". If I had to do it all over again I would just have bought new leaf packs and not waste time and money with AAL and shackles. My .02
  9. Oct 17, 2010 at 12:49 PM
    scocar
    scocar hypotenoper
    Hmmm. I don't know from personal experience, but if you add a longer shackle, doesn't this allow it to rotate out and away from the axle more, giving the leaf extra room to flatten out? Just curious. I haven't thought too much about it, but other folks said shackles tend to have a bad effect on the leafs, and now I can't recall the details.
  10. Oct 17, 2010 at 1:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    the spring compressing (flattening out) is going to dictate how far the shackle swings.
  11. Oct 17, 2010 at 5:12 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    What's the length of the stock shackles ctc?
  12. Oct 17, 2010 at 6:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im not sure off hand. Measure yours.
  13. Oct 17, 2010 at 6:05 PM
    scocar
    scocar hypotenoper
    Well, yeah, so that is pretty much my point. A longer-than-stock shackle would allow the spring to flatten out more than its original design intended. It seems that over time (god knows how much, but given the shitty quality of the stock leafs...), this could more quickly deform the leaf spring.
    On my truck, the stock shackles are 3.5 in. pin-to-pin center.
  14. Oct 17, 2010 at 6:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The leafs are only going to flatten out to a certain point, regardless of how long the shackle is. A Shackle can not stretch the leaf spring. All it does, is swing back and forth as the spring flattens out, and rebounds. Length makes no difference.
  15. Oct 17, 2010 at 6:16 PM
    Leadgolem
    Leadgolem Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
    Never measured mine, but the 1" shackle lift I've got in the rear is from toytec and the shackled looked to be the correct 2" longer.
    On my 98 the bushings where pretty much fused and I had to use a torch to get them out. I disassembled my leaf pack later to add a helper spring and that was actually easier then replacing the shackle.
  16. Oct 17, 2010 at 7:57 PM
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
  17. Oct 17, 2010 at 8:40 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    On my truck, the stock shackles are 3.5 in. pin-to-pin center.[/quote]
    Thx scocar :D When I bought my Taco it was already lifted...That's why I was asking about the stock length :p I'll measure my and compare when my vehcile gets back from the dealership...
  18. Oct 17, 2010 at 9:43 PM
    scocar
    scocar hypotenoper
    Thx scocar :D When I bought my Taco it was already lifted...That's why I was asking about the stock length :p I'll measure my and compare when my vehcile gets back from the dealership...[/quote]
    I figured that was why you were asking...if it was just because you were too lazy to go grab a tape measure, I was going to interwebz karate-kick you...
  19. Oct 17, 2010 at 11:54 PM
    MaTt98
    MaTt98 Well-Known Member
    Medford Or.
    96 4Runner SR5 V6
    Runner SR5, xeon headlights, 6inch kc spotlights, cb in ashtray mod, roof rack, 2.5 inch lift in front with dodge 1500 coils in the rear and skyjacker shocks
    i have a 2.5 inch spacers and 1 inch shackles and havnt noticed anything wrong with them mind you i broke a leafspring with stock shackles so who knows the rear leafs are kinda crappy when they are stock eventually im getting coils for the front & 1inch+ leafs and putting the stock shackles back in
  20. Oct 18, 2010 at 12:02 AM
    Leadgolem
    Greg
    Littleton, CO
    You actually broke a leaf spring. :eek: That isn't an easy thing to do. Do tell?
