Serpentine belt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hwf3, Mar 1, 2018.
  1. Mar 1, 2018 at 6:15 AM
    Hwf3
    Hwf3 [OP] Member
    Skip
    2005 toyota tacoma
    Im looking to replace my belt, can anybody recomend the continental v belt. Im trying to get rid of some noise issues
  2. Mar 1, 2018 at 9:45 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Changing to another brand of belt will not eliminate noise. If it does, the belt that you replaced was defective. There are countless threads here about belt/tensioner/pulley generated noises.
    Too Stroked likes this.
  3. Mar 1, 2018 at 9:51 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    my exs 05 sienna PS squeaked for years until the pulley on engine was changed by recall
    sometimes its not the belt
  4. Mar 1, 2018 at 10:07 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Let me offer some advice speaking as the father of a Toyota / Lexus Certified Service Technician. A few years ago, I replaced the belts (it has two) on my 2006 Scion xB with the best aftermarket replacement belts the local parts store had. (Remember, there are different levels of quality.) I replaced them simply because the car had 60,000 miles on it and I figured it was time.
    About a week later, I started to get a light squeal that I couldn't get rid of. I stopped by the dealership where my son worked and he had me pull right into his bay where we popped the hood. He called his Team Leader over for a consultation and the first thing he said was "Aftermarket belts. Get rid of them and put some OEM Toyota belts in." I did and the problem never returned. Needless to say, I use Toyota parts whenever I can now. Just saying.
  5. Mar 1, 2018 at 10:25 AM
    Hwf3
    Hwf3 [OP] Member
    Skip
    2005 toyota tacoma
    Thanks guys, i ordered 3 new pulleys just waiting for delivery. I read the continental poly v belt was designed to make less noise with any alignment issues.
  6. Mar 1, 2018 at 10:27 AM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    BUY OEM BELT!!!
    Blockhead and Shark18 like this.
  7. Mar 4, 2018 at 12:29 PM
    Hwf3
    Hwf3 [OP] Member
    Skip
    2005 toyota tacoma
    I replaced the 3 idler pullys <took 30 min> and that was the majority of my noise. I will also go back to an oem belt, use the aftermarket belt as a spare.
  8. Mar 4, 2018 at 12:46 PM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    I'd stick with OEM: I went in for a belt change on my 07 highlander after 11 years/80k miles. It wasn't cracked but was prob stretched a bit; they wanted $90. retail for the belt plus 150 labor!!!; I talked them into a discount but on toyota disc. sites, they want 50 plus for an OEM.
    For my Tacoma, I've heard Bando is the maker for Toyota belts, but really cannot be sure that quality is the same. That said i got a Bando off of Amazon as the belt on the truck is ok now at 40000miles, carrying a spare made sense for about $20.00.
    https://www.amazon.com/Bando-7PK212...automotive&vehicleId=1&vehicleType=automotive
  9. Mar 4, 2018 at 12:50 PM
    TheDude94
    TheDude94 Basement Operator
    Mom's basement
    2008 TRD Sport 4x4
    Workin progress...
    I made the mistake of buying a aftermarket belt once... it lasted a year... OEM all the way now.
  10. Mar 4, 2018 at 2:36 PM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    Bando for me........
  11. Mar 4, 2018 at 3:52 PM
    A-Team
    A-Team Member
    Harford Co. MD
    2005 Black AC
    Use an oem belt or continental elite (formally goodyear "gatorback") nothing else. I have sold the Goodyear, now continental belts to repair shops for 18yrs. Hands down their highest praised belt.
  12. Mar 4, 2018 at 9:09 PM
    Shark18
    Shark18 Well-Known Member
    Daniel
    2007 White dbl cab Tacoma 4x4 TRD
    OEM to the bank....I made a huge mistake going aftermarket the belt separated got behind the lower pulley cut the face of the crank seal oil everywhere what a mess....replaced seal and OEM toy belt non issue.
  13. Mar 4, 2018 at 10:24 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Bando is generally US made and the OEM supplier for a lot of manufacturers. It's all I use.
  14. Mar 4, 2018 at 11:21 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I've used Bando and Gates. Both are good and trouble-free in my cars.
    @Hwf3 You didn't mention replacing the tensioner pulley. The bearing in the pulley, as well as for the others, is replaceable. The bearing size is 17X40X17.5 (ID X OD X Width), a readily available size - this size is only for the tensioner pulley; the others use a proprietary size with a 10mm ID.
  15. Mar 5, 2018 at 6:30 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    OEM, $35, 15 minutes to install
  16. Sep 20, 2018 at 1:47 PM
    MilSpec
    MilSpec Well-Known Member
    2014 Tacoma TRD Off-Road [1GR-FE] [A750F]
    I agree... solid belt, USA made and I believe it is the OEM supplier.
    RHHousehold and Maticuno[QUOTED] like this.
  17. Sep 20, 2018 at 1:54 PM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Meh, what does Toyota know about building automobiles? :anonymous:
  18. Sep 20, 2018 at 2:01 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    buy an aftermarket belt and find out
  19. Sep 20, 2018 at 5:35 PM
    RHHousehold
    RHHousehold Well-Known Member
    CA
    2008 Access Cab TRD Offroad 4x4 V6
    Bando and no issues whatsoever.
  20. Sep 20, 2018 at 6:12 PM
    s.e.charles
    s.e.charles Well-Known Member
    interesting conflicts!
    what problems could a properly sized belt cause? I don't mean manufactured defects, but an apple to apple comparison. if the diameter is correct, and the V-profile fits the sheaves, what else could go wrong? rubber composition? (hard or too soft?)
    does bando & gates give toolbox stickers?
    thanks
