Serpentine belt replacement. 2011 V-6
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gregzz, Jan 17, 2020.
  1. Jan 17, 2020 at 12:55 PM
    benzy
    benzy Well-Known Member
    Bay Area, CA
    2006 DCSB TRD OR
    Simple OME/884/AAL lift. 32” WP’s
    I’m hardly the auto mechanic and was able to do it in 30 min. You just finagle the belt around the fan and route as per the diagrams online. I think it’s a 14mm socket. I could never find the hole for a pin to keep the tensioner collapsed but it can be done with the right length socket wrench
    Also inspect all pullies once the belt is off. They should spin freely. If any of the bearings are rough then they need replacing pronto.
    I also went with a continental belt. People swear up and down that OEM is the only way to go, but I think that’s based on us getting well over 100k from that belt on a new motor with new idle pullies, new fan, compressor motors etc that induce less stress on the belt. They then put a new belt on an old motor and wonder why it doesn’t last as long.
    gregzz[OP] likes this.
  2. Jan 17, 2020 at 12:57 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Helps to have a second set of hands to put the belt on by them holding the belt on the PS pulley (from above so they do not get dirty) as you align the belt grooves on the grooved pulleys from underneath. Will save a few choice words and time as the new belt is stiff.
  3. Jan 17, 2020 at 1:03 PM
    Tacoma Mike
    Southern Maine
    Second set of hands get in the way . Then you need to worry about his fingers.
  4. Jan 17, 2020 at 1:06 PM
    gregzz
    gregzz [OP] Well-Known Member
    greg
    las vegas nv
    2011 tacoma crew cab 4x4 v6 4.0
    Wheels/ tires, tint, level kit. Rock crawler rails. 3- 6" procomp lights with light bar on front bumper. Magnaflow # 12256 stainless muffler. Billet shorty antenna.
    I would love it if I had an extra set for f hands but the only person I have to help me of my wife and I REALLLLY don’t want to hear OH GOSH I CHIPPED A NAIL!! I think I’ll just put up with the extra aggravation and attempt it alone to save the drama. Lol
  5. Jan 17, 2020 at 1:22 PM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    I went with a OEM belt, purchased from a Toyota dealer on Amazon (free shipping).
    Recommend taking a picture with your cell phone, so you can refer back to see how the belt is routed. Feel free to take time to study the belt routing before you start. You can also find a copy of the belt routing online.
    The whole procedure, from lifting until shutting the hood, should take less than 5 minutes. (Not including the time you take to study the routing of the belt.)
    I was disappointed there wasn't a belt routing sticker under the hood. Would buy one if anyone ever decided to print them.
  6. Jan 17, 2020 at 1:32 PM
    benzy
    Bay Area, CA
    2006 DCSB TRD OR
    Well, you have to remove the bash plate too.
    For me, wrapping it around CS wheel with my left hand while wrenching the tensioner with my right was the easiest.
  7. Jan 17, 2020 at 5:05 PM
    muddog321
    FL
    Wife helped me but yes she did get a little cut holding it on the PS pulley no idea how ha ha so had to wait while she got a band aide!
    If you all get confused or disorientated when doing the belt just remember groove side onto grooved pulleys and smooth side onto the smooth/flat idlers and tensioner.
    If still confused have another beer and look at the diagram again.
  8. Jan 17, 2020 at 6:00 PM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    Replaced two upper idler pulleys, one lower idler pulley, belt tensioner bearing, and serpentine belt. Easier than I thought. Part numbers listed for reference incase anyone asks. The Gates pulleys were from Amazon, Nachi bearing from ebay, and belt from Toyota.
    (2) https://www.amazon.com/gp/product/B001FKEMGM/ref=ppx_yo_dt_b_asin_title_o01_s01?ie=UTF8&psc=1
    (1) https://www.amazon.com/gp/product/B001FHQZDI/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
    (1) https://www.ebay.com/itm/5203-2NSL-...e=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
    Pro tips:
    -Approach this task from the bottom, once the skid plate is removed, you'll have all the room you need.
    -The belt tensioner pulley is reverse threaded. The bearing is very easy to press out/in.
    -Route the belt around the fan, its very easy.
    -Top two idler pulleys 29ft/tq, bottom pulley 40ft/tq, belt tensioner 27 ft/tq
    I was long overdue for this maintenance. This immediately solved my cold start squeaks and a loose knocking sound. Turns out the tensioner pulley bearing and lower idler pulley were shot and loose.
  9. Jan 18, 2020 at 2:24 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    This is an easy maintenance job for those that are mechanically inclined. If you are not and have never done this, you are better off taking the car to a mechanic.
    A red flag here is when you said, "... there’s ABSALUTLEY no room to move around in there." [sic]
    This tells me you have no business trying to do this job on your own. Get a buddy that has done this before to help you, or take the car to a mechanic.
    If you want to continue, this video is probably the most helpful. He also replaced the idler and tensioner pulleys. What he doesn't elaborate much is that he bought an aftermarket tensioner and swapped out the tensioner pulleys. He also doesn't cover removing the engine guard and two brackets at the bottom to allow easier access.
    https://www.youtube.com/watch?v=DLnawMigjOI
  10. Feb 9, 2022 at 6:06 PM
    GRNT4R
    GRNT4R Well-Known Member
    NC - Triad
    2010 TRD Sport DCLB 4WD Silver
    TBD
  11. Feb 10, 2022 at 6:18 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    Go in from the bottom and you can get it without removing a lot of stuff. One caution... be careful if you use a ratchet on the tensioner. If you aren't careful you can get it stuck in there with tension forcing the ratchet handle against the frame... then it is almost impossible to pull the damned socket off the hex head. I would have said impossible instead of almost impossible, because I did this and somehow eventually got it off. I wouldn't use a ratchet except there is little room to turn it and I had to use the ratchet to be able to release the tension to get the belt off.
    GRNT4R likes this.
  12. Feb 10, 2022 at 11:56 AM
    Chuy
    Lakeside, CA
    Silver Taco
  13. Feb 10, 2022 at 3:51 PM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    Pipeliner51 and Alexely999 like this.
  14. Feb 12, 2022 at 7:52 AM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    New bearings don't spin freely, the grease should prevent them from doing so. An additional thing to check for (beyond obvious roughness or play in the pulley) is whether they spin TOO freely. If they remind you of the sound of a 70s skateboard wheel when spun - spinning freely for a long time - the grease is gone or broken down, and the bearing should be replaced.
    And don't forget to check the water pump, power steering pump, alternator, and A/C bearings while you're at it. It can be hard to tell on those; my alternator bearings seemed fine but it froze up HARD a couple of months after I did the pulley/tensioner/belt replacement.
  15. May 7, 2022 at 4:59 PM
    #35
    GreggyG
    GreggyG Well-Known Member
    anyone have trouble with the Bando belts? Reviews on Amazon indicate some break/shred? Or, should I get the Gates belt if I'm buying the Gates pulleys as mentioned earlier in this thread?
  16. May 7, 2022 at 5:07 PM
    #36
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Just did the bando today. Ask me in a while lol.
  17. May 7, 2022 at 5:16 PM
    #37
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Get the Gates, every Bando I've used started squeaking in less than a month
  18. May 7, 2022 at 5:37 PM
    #38
    GreggyG
    Alexely999[QUOTED] likes this.
  19. May 7, 2022 at 5:38 PM
    #39
    GreggyG
  20. May 7, 2022 at 5:39 PM
    #40
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
