Serpentine Belt and Hose Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rjtoc2, Jul 11, 2020.
  1. Jul 11, 2020 at 7:39 AM
    rjtoc2
    rjtoc2 [OP] Burglar of Turds
    Dallas/Fort Worth
    2008 Double Cab Prerunner SR5 (Super White)
    My 2008 Tacoma has its original belts and hoses. Although they don't feel rigid or brittle, they are still 12 years old. Should I swap them out as preventative maintenance or keep until they "feel" like they need to be replaced.
    ...asking for a friend.
  2. Jul 11, 2020 at 7:43 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    That's a pretty long time. Any cracks or missing spots in the belt ridges? I would probably do it. IIRC, the tensioner on the 4.0 takes some work to get to, but you may not need to do that.
  3. Jul 11, 2020 at 7:53 AM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    Swap the belt. Hoses are probably good to go if hey still feel supple.
  4. Jul 11, 2020 at 7:57 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I would recommend changing the belt.
    I removed the front skid plate. The tensioner was easy to access once it was removed.
    Look at and feel the hoses. They should not be swollen or have soft spots.
    You need to physical squeeze them, it should be fairly obvious if you feel a soft spot.
    I still have the OEM hoses on my 07’.
    I figure I’ll change when they show signs of needing it, or a cooling system component fails. Like the water pump or radiator.
  5. Jul 11, 2020 at 10:43 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This ^ its easy to do also.And KEEP the old belt in the truck for back up.
    rjtoc2[OP], tacomarandy and BillsSR5 like this.
  6. Jul 11, 2020 at 10:49 AM
    Bishop84
    Bishop84 Well-Known Member
    I've never changed a hose on a Toyota due to degradation. It's always because of damage or fluid contamination (oil, or ice etc)
    Change the belt, its not that bad, and its good to have a spare as mentioned.
    BillsSR5 likes this.
  7. Jul 11, 2020 at 10:59 AM
    fatrip
    fatrip Well-Known Member
    Vince
    Upstate NY
    07 Taco 4D Short
    Bilstein 5100's , 885.
    Agreed, if the belt doe break it can damage other things inside the bay.
  8. Jul 11, 2020 at 1:31 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I have an ‘08 and just did this a couple months ago. It’s much more quiet. Do the pulleys too. Both will honestly take under an hour.
  9. Jul 11, 2020 at 1:47 PM
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    Still on stock hoses on a purchase date of November 2004 TRD Sport. I’ve changed the belt a few times but not hoses or pulleys. Have new ones laying around JIC. I’m hoping I get a tiny hole in my radiator so I can change them all out at the same time. Thermostat as well.
    Asianguywithatruk likes this.
  10. Jul 11, 2020 at 2:54 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Does anyone have a list of the part numbers for all the pulleys that should be replaced with the belt?
  11. Jul 11, 2020 at 3:04 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You're well overdue on the belt. I still have a hard time wrapping my head around it but my mechanic does not recommend changing my 13 year old hoses. I'm going to trust him on it.
  12. Jul 11, 2020 at 3:10 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Crosis[QUOTED] likes this.
  13. Jul 11, 2020 at 4:21 PM
    Crosis
    Dunedin Fl
  14. Jul 11, 2020 at 7:17 PM
    R0dzilla75
    Rodney
    Virginia
    05 Sport
    I’ve had mechanics tell me the same.....doesn’t make sense but they all tell me the factory hoses are the absolute best and not to touch them.
    TRDSport10 likes this.
  15. Jul 12, 2020 at 3:49 AM
    FJBub
    FJBub Well-Known Member
    Doug
    2010 Tacoma PreRunner 2015 Tacoma TRD Off-Road 2008 V8 4Runner
    The truck is 12 years old. Change the hoses while you do the belt. It's cheap insurance. Just did this on a 4.7 V8 4Runner.
  16. Jul 12, 2020 at 10:44 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    12 years 2008 changed belt - still looked ok and no noise - just though it was a good idea - didn't touch hoses.
  17. Jul 12, 2020 at 12:23 PM
    Crosis
    Dunedin Fl
    My belt is 11 years old and looks new but age is age so replacement is on my list too.
  18. Jul 13, 2020 at 6:45 AM
    helomech
    helomech Well-Known Member
    Bryan
    San Diego, CA
    '10 4wd TRD Sport DC LB
    20% Tint on all windows
    I'm in the same boat. I bought it in Sept '10 and it's at 118k+ right now. Probably due for a new belt.
  19. Jul 13, 2020 at 6:50 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    My coworker has an '08. We were talking about maintenance the other day and I asked him about his serpentine belt.
    He said..."nope, never replaced it. Guess I should at some point".
    Now wait for it.............his rig has 310k miles on it. I'm at 75k. Think I'll hold off until about 100k......with no worries. o_O
  20. Jul 13, 2020 at 7:25 AM
    helomech
    Bryan
    San Diego, CA
    I dont feel so bad now. That's crazy.
