Sensors, steering angle, roll and yaw
Discussion in 'Technical Chat' started by mcgiiver, Oct 2, 2009.
  1. Oct 2, 2009 at 6:15 PM
    mcgiiver
    mcgiiver [OP] Well-Known Member
    Princeton, NJ
    2009 Access cab 4x4, 4 cyl, stick
    Aftermarket Driving Lights, Hidden Hitch, Removed rear headrests, Side protective moldings, vacuum gauge, Scan Gauge, Leer cap.
    I am having a problem with my ABS and Slip Indicator light coming on simultaneously when the truck shakes going around a right turn or starting out on bumpy pavement. The light stays on until key is shut off. I understand there might be steering angle, roll and yaw sensors in the truck. Can anyone confirm that and give me their locations on the truck?
  2. Oct 4, 2009 at 9:07 AM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Warranty......Why fool around?
  3. Oct 6, 2009 at 7:20 AM
    viperstd
    viperstd Tacoma convert
    Maryland
    09 4x4 TRD SR5 DC LB
    AllPro Front and Rear trail armor & full skid plates, Demello Hybrid Rock Crushers, Old Man Emu suspension, Warn 8000# winch, PIAA SMR fogs, perforated + heated leather seats, in-dash DVD/NAV/Sound, RE subs
    I know there is a Yaw sensor is under the drivers side seat. Found it the other day.
  4. Oct 6, 2009 at 7:29 AM
    98tacoma27
    Ben
    Not Beech Creek
    That's not a Yaw sensor.
  5. Oct 6, 2009 at 7:32 AM
    viperstd
    Maryland
    I can take a picture of it tonight and prove it is... seeing as it has a nice sticker saying VSC Yaw Sensor
  6. Oct 6, 2009 at 7:33 AM
    98tacoma27
    Ben
    Not Beech Creek
    No need, you are right.
  7. Oct 6, 2009 at 7:39 AM
    viperstd
    Maryland
    ooh, nice find on the link. :thumbsup: When I saw it I was surprised. I would have expected Toyota to use a 3-axis sensor located near the CG of the truck.
  8. Nov 10, 2014 at 8:29 PM
    Skatefast
    Skatefast New Member
    Northern California
    2011 Prerunner DC LB
    Hi all - I am having a similar problem with my 2011 PreRunner DC LB. When I go around a right hand, slightly bumpy turn, my DSC light comes on. You can feel the computer cut power and the ABS feels like it is coming into play. This only happens when going right. If I apply some pressure on the brakes, it does not happen. The brakes are no longer under warranty. I took the truck into the dealer and they found that the sensor in the master cylinder reservoir was faulty. I changed this and it did not help my issue.
    Have any of you seen, or heard of this problem?
  9. Oct 18, 2016 at 9:44 PM
    Alfred
    Alfred Well-Known Member
    Alfred
    California
    14 TRD Sport 4X4 DCSB
    Get your vsc recalibrated
