Self tapping oil pan plug
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shotfun, Feb 27, 2019.
  1. Feb 27, 2019 at 7:31 PM
    shotfun
    shotfun [OP] New Member
    2007 TRD Tacoma Double Cab
    None
    Hey everyone. Quick question. I’ve got a stripped oil pan plug and I want to yank it and use the existing pan. What size self tapping plug should I use and does anyone have any hints so I can bypass any headache? Thanks in advance.
  2. Feb 27, 2019 at 7:35 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If you have to use a self tapping drain plug to correct a pan which already has damaged threads in place you will have a headache either now or later on, or both. That's just the way it will be.
    shotfun[QUOTED][OP] likes this.
  3. Feb 27, 2019 at 7:38 PM
    Clearwater Bill
    Billy
    Largo Florida
    shotfun[OP] likes this.
  4. Feb 27, 2019 at 7:47 PM
    shotfun
    None
    It’s just buggered. I actually have a new oil pan to put on but I have a larger engine issue I’m toying with and I want to get some clean oil in there and check my vvt and oct. it’s a fix that I only need to have last a week. Thanks for the prompt reply.
    12TRDTacoma likes this.
  5. Feb 27, 2019 at 7:48 PM
    shotfun
    None
    Thanks a bunch. I totally agree with you. Not usually someone who digs patches.
  6. Feb 27, 2019 at 9:08 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah man. I strongly suggest getting a new secondary oil pan. They should be cheap enough and since they dont take a gasket other than RTV it should be relatively easy to swap out.
