Self-cleaning direct injectors?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoJonn, Aug 19, 2015.
  1. Aug 19, 2015 at 9:36 PM
    TacoJonn
    TacoJonn [OP] Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
  2. Aug 19, 2015 at 9:59 PM
    Noahs2015Taco
    Noahs2015Taco aka TheOverlandingDad
    Michael
    Contra Costa County
    '15 TRD Off Road - Manual w. TRD Quick Shifter
    King 2.5 25001-119A EXT with Icon Billet UCA giving a 2.5" lift in the front, Icon 2.0 w. remote resi, OME HD Dakar Leaf pack giving a 3" lift in the back. Wheelers Superbumprs paired with All-Pro U-Bolt flip kit. 17" Black 4Runner TRD Pro Rims - 32" for DD 17" Black 4Runner TRD Pro - 33" BFG KM2 255/80r17 for dedicated off road set. Dissent Offroad Bed Rack over a softopper
    Nothing new, all of Toyota's D4D engines have this. The "self cleaning" is simply the engine switching between direct and port injection depending on what's optimal? As a side affect by going into the port injection system it helps clean some of the excess carbon build up left by the direct injection?
  3. Aug 19, 2015 at 10:07 PM
    7thSeal
    7thSeal Well-Known Member
    Yeah the port injection is using fuel to help clean the top side of valves from carbon buildup and the fuel entering the cylinder from intake would help clean the direct injectors from carbon buildup. Direct injected engines alone doesn't have this option available.
  4. Aug 19, 2015 at 10:16 PM
    TacoJonn
    Jon
    Laramie, Wyoming
    Ahh ok. Got it.
  5. Aug 19, 2015 at 10:29 PM
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    Did anyone else notice the fact that the TRD OR has a different class braking system than the TRD Sport??
    Also, e-Locker in the back for all TRDs!
  6. Aug 19, 2015 at 10:31 PM
    7thSeal
    Notice that he mentions that its during idle which would be when port injection is being used. The interesting thing is that he mentioned that you'd hear a small 'ticking' noise for a few seconds while this is happening from time to time. The ticking noise is a sign of the pressured direct injectors being opened which makes me believe that they're simply allowing air to pass through the direct injectors at the same time during port injection to help blow off carbon buildup.
    James_Bond likes this.
  7. Aug 19, 2015 at 10:39 PM
    TacoJonn
    Jon
    Laramie, Wyoming
    I think only TRD OR. He is kind of vage in the video.
  8. Aug 19, 2015 at 10:44 PM
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    You're right. TRD OR has a different braking system because of the crawl control.
    shakerhood likes this.
  9. Aug 19, 2015 at 11:13 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    that video is terrible. it's already been mentioned that he is wrong.
    The OR gets a boosted brake system for more low speed brake power. Only the OR gets the rear locker
    Also, why does everyone keep saying D4D? That is the diesel code
    TopherWV likes this.
  10. Aug 20, 2015 at 12:00 AM
    7thSeal
    I must have missed it.. please show where its wrong?
    On the trans maybe?
  11. Aug 20, 2015 at 12:26 AM
    Noahs2015Taco
    Michael
    Contra Costa County
    LOL sorry, wishful thinking of my part... I secretly want the D4D in a Tacoma. I love my 2015 Taco... with that being said I would trade her in less than a minute and put up with the upgly Gen 3 grill if it were available in a D4D connected to a 6MT - 4x4. Yes it should read the D4S system in the 3.5 petrol V-6 Tacoma is not new to Toyota.
  12. Aug 20, 2015 at 12:47 AM
    Z50king
    Eric
    Southern California
    Stock and loving it
    All the paperwork from Toyota says he is wrong about the locker on the Sport.
  13. Aug 20, 2015 at 1:30 AM
    Drews
    Drews Well Sir....... Its a Cluster F@#k!
    On Hiatus in the Kingdom of Bahrain
    08 Double Cab Sport Pkg (Sold in 2011) 1997 TLC (Still my daily driver)
    2.5 OME Kit Luna Dual Battery Kit (Pending Install) Front Runner SL2 (Pending Install) ARB Fridge and Outback Slide (Pending Install) And other Stuff
    Couldn't resist...:anonymous:
    TacoJonn[OP] likes this.
  14. Aug 20, 2015 at 2:57 AM
    7GR
    7GR Well-Known Member
    GSJ15W
    Actually no air passes through the direct injectors, since they are under high fuel pressure at all times. Air within that system means there might be a vacuum lock somewhere along the fuel system, which is not a good thing.
    I think what you meant to say was that the fuel-air mixture coming from the port injection helps clean and lubricate the rod-side of the intake valves, effectively minimizing carbon-deposits that would otherwise build up on those intake valve surfaces that direct-injection-only engines experience all the time because only the combustion chambers get exposed to fuel but not the intake valves' rod-side, thus accelerating carbon-buildup process mostly due to nasty EGR or PCV byproducts.
  15. Aug 20, 2015 at 3:19 AM
    imom
    imom Well-Known Member
    CAL
    2014 Regular Cab
    Two reasons why I got rid of my BRZ. 1. 2nd gear tranny issue...known factory design flaw 2. Is the direct injection system by Toyota for Subaru. There's a gasket around the direct injector that when gets hot can leak and then eventually causes engine failure. I never understood why the DI fuel systems was a high pressure threaded screw on injector instead of a dumb gasket to hold the injectors in place. I also wouldn't be surprised if the 2016 Tacoma will have the cricket problem with the fuel pump.
    I really like a lot of the features of the 2016 model, but I wish they had a turbo 4 cylinder like the ecoboost mustang and offered as regular cab...but that will never happen the regular cab part.
