Seepage around rear diff fill plug?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Creel, Feb 3, 2017.
  1. Feb 3, 2017 at 6:22 PM
    Creel
    Creel [OP] Well-Known Member
    Georgia
    08 SWB DC PreRunner OR
    Wife was following me home tonight and saw some greasiness on the "axle thing" :p. Got down there to check the diff and sure enough, a thin layer of oil on the outside of it. It appears to be coming from the fill plug. The drain plug was dry around it. I have not seen any puddling below where I park.
    My course of action is to drain the oil, fill it, and replace the crush gaskets. After that, monitor and see if it returns. Any thing else I should look out for? I checked the torque and it was 36 ft lbs.
    Bad picture attached.
    Thanks!
  2. Feb 3, 2017 at 6:33 PM
    badger
    badger Well-Known Member
    07 SR5
    No need to drain and fill, unless it is time,right? Just replace the crush washer and check the level. A piece of wire bent 90 degrees makes a good dipstick.
    Creel[OP] and outlawtacoma like this.
  3. Feb 3, 2017 at 6:36 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    X2
    Creel[OP] likes this.
  4. Feb 3, 2017 at 6:42 PM
    Bishop84
    Bishop84 Well-Known Member
    I wouldn't be too concerned, I'd probably just replace the gaskets and fluid as a service rather than a repair. It's doubtful the fluid is low if at all.
    Also, take a second to make sure your breather plug extension is working. Most leaks are due to pressure build internally.
  5. Feb 3, 2017 at 6:46 PM
    1320Fastback
    1320Fastback Active Member
    05 4.0L 6spd
    Don't need to drain and fill unless it's due for service. The proper oil level is the bottom of the threads of that plug so when the fill plug is removed some oil may start to seep out and that's fine. If no oil comes out use your pinky and see if you can dip it in the oil and if not then it needs to be filled up until it dribbles out the fill hole. New crush gasket, tighten plug and clean diff.
  6. Feb 3, 2017 at 6:49 PM
    Creel
    Georgia
    It's time for a change anyway so I will go ahead and do it. I tow a boat so I try to change it every other oil change. I did do the breather extension mod. I wonder if it is not venting properly? Is there an easy way to check?
  7. Feb 3, 2017 at 6:50 PM
    Bishop84
    I usually just visually inspect it. Also when you remove the fill plug pay attention, if the breather is plugged it will feel like a vacuum inside the diff and the fill plug will resist coming out.
  8. Feb 3, 2017 at 6:52 PM
    Creel
    Georgia
    Thanks man. I'll be sure to pay attention to that tomorrow when I tackle it.
  9. Feb 3, 2017 at 7:00 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    That's wayyyyyy too soon. You can easily go 30k miles before needing to change it again. You're changing it way too often. I'd probably go 50k+ if I were you.
  10. Feb 3, 2017 at 7:06 PM
    1320Fastback
    05 4.0L 6spd
    I do every 3rd oil change on rear diff and transmission but I'm my own mechanic and it just takes another couple minuets. I believe the Toyota interval is 30,000 for the diffs and the manual trans it just says to inspect level not that I'd ever not change it!
