Seeking CEL troubleshooting advice (P0441, P0442, P0446)
Discussion in '1st Gen. Tacomas (1995-2004)' started by AmherstAndy, Sep 13, 2019.
  1. Sep 13, 2019 at 8:14 AM
    AmherstAndy
    AmherstAndy [OP] Well-Known Member
    Andy
    Masshole
    2003 2.7L 5 speed, 4x4 J shift, Xtracab
    Hi all, first post on Tacoma world.
    Last spring, I took ownership of my father's 2003 Tacoma Xtracab 4x4, with 2.7L engine. It is a well-maintained, low mileage (109k) truck, but due to 16 years in the Northeast, has some rust (Toyota replaced the frame a few years ago).
    Last weekend, the fuel tank strap broke due to rust. This model year has only one rear strap, so the front of the tank remained bolted in place, while the rear sagged considerably. It's worth mentioning that the fuel tank skid plate has completely rusted away.
    I replaced the strap with the OEM part, which required jacking the tank back into place. After a couple of driving cycles, the CEL came on. When I had it scanned at Autozone, the following codes were reported:
    • P0441 (evaporative emission system incorrect purge flow)
    • P0442 (evaporative emission system leak detected (small leak))
    • P0446 Evaporative emission system vent control circuit
    My questions are as follows:
    • Is there likely a single cause that could explain all three codes? I suspect something atop the tank was damaged when the tank was sagging. What should I look for?
    • Will I likely harm the truck if I continue to drive until the repair is made?
    Thanks,
    Andy
  2. Sep 13, 2019 at 8:32 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    The charcoal canister is ontop of the fuel tank. You probably ripped out a vacuum line of something.
    AmherstAndy[OP] and underaroof like this.
  3. Sep 13, 2019 at 9:42 AM
    underaroof
    underaroof ember
    Eastern Sierra
    2004 Xtracab 4x4 V6 TRD
    I'm currently in the same boat, although no rust for me. I've heard of people needing to replace the whole charcoal canister, but that is expensive.
    Like wolfgang said, check your connections and hoses for any leaks. A vacuum pump might help here. Also, those codes take a few hundred miles to light up a CEL for future reference.
  4. Sep 13, 2019 at 10:59 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Most likely just leaking hoses since you got the small leak code. Best way to find is a smoke test. Next time you take a drive park, turn off engine and slowly loosen the gas cap, you should hear a hiss, if not,you got a leak. Check the gas cap o ring and filler neck seat for signs of faulty sealing. If you hear a hiss the purge control selnoid AKA VSV(vacuum switching valve) may be stuck open or working intermittently. This EVAP system is designed to prevent gas vapors entering the air we all depend on to LIVE. Due to the severity of corrosion your fuel tank and fittings may be beyond repair and need to be replaced. Cross your fingers and hope for a HISSSSSS.
  5. Sep 13, 2019 at 11:08 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    You might want to replace the rusted out fuel tank skid entirely.
    https://www.summitracing.com/parts/...3g49LKnG30RIf03XnmN5E29Vp_x3m5E0aApZzEALw_wcB
  6. Sep 13, 2019 at 11:25 AM
    Black DOG Lila
    Virginia
    The need to replace the EVAP cannister is usually due to over filling the fuel and soaking activated charcoal in the cannister. When the gas punp clicks off never try to add more. If it takes a few hundred miles to get P0441 your purge control selnoid is working intermittently or sticks open occasionally.
    underaroof[QUOTED] likes this.
  7. Sep 13, 2019 at 1:45 PM
    underaroof
    underaroof ember
    Eastern Sierra
    Interesting I'll have to look into that.
  8. Sep 13, 2019 at 2:20 PM
    Black DOG Lila
    Virginia
    For some unknown reason P0441 will often show PENDING on my scan tool after CEL is on for P0420, most often its just the gas cap or loose vac hose but when P0441 trips CEL,purge selnoid or VSV is most suspect and was PENDING the longest distance. I love taking trips in other peoples yotas with my scanner as my excuse for a road trip on their $$ They are just happy to have CEL out.:)
    cruiserguy likes this.
  9. Sep 13, 2019 at 11:12 PM
    Glamisman
    Glamisman Well-Known Member
    the pending code on the scan tool means nothing more than that error have not met parameters to turn the CEL on. Most evap codes are a 2 trip test with a certain set of operational parameters before that test is run.
    Black DOG Lila likes this.
  10. Sep 14, 2019 at 6:26 AM
    Black DOG Lila
    Virginia
    You are correct. Winner winner chicken dinner!
  11. Sep 14, 2019 at 3:50 PM
    AmherstAndy
    Andy
    Masshole
    Hopefully this was the correct answer. I inspected everything I could that didn't require dropping the tank or removing the bed. I noticed that one of the vac lines that runs alongside the filler neck (there are two; I mean the one closer to the front of the truck) was disconnected, so I hooked it back up. These lines seem especially vulnerable to being tugged loose when the tank drops, while most of the others connected to the evap system seem less so.
    I'll go tomorrow to have the trouble codes cleared and will update after a few days of driving. Thanks to everyone who chimed in.
    Lastly, I'm learning that there is a lot of knowledge/experience dealing with the evap system, and it can be frustrating and expensive to repair. Hopefully it remains trouble free after this.
    Best,
    Andy
    02ToyMan likes this.
  12. Sep 14, 2019 at 4:02 PM
    AmherstAndy
    Andy
    Masshole
    I added bold to highlight this statement, which I'm curious about. It is mentioned above that the evap system needs to go through two operation cycles to run a test for P0441. In my other reply, I described reconnecting a disconnected vac line I discovered near the filler neck. I wonder if a disconnected line is a severe enough fault condition to trigger a CEL more rapidly? It seems plausible that the tank strap failure, disconnected vac line and evap system DTCs are all related, and rather unlikely that some other yet unknown fault from a few hundred miles ago triggered the CEL two days after the tank strap failure. I'm not trying to be critical of your statement; to the contrary, I appreciate the advice.
    Enough speculating on my part...time will tell if reconnecting the vac line resolves the issue.
  13. Sep 14, 2019 at 4:07 PM
    AmherstAndy
    Andy
    Masshole
  14. Sep 14, 2019 at 4:10 PM
    Digiratus
    Roaming the PNW
    The RedHead
    No personal experience with it but several people on TW are running it and give it positive reviews.
  15. Sep 16, 2019 at 2:31 PM
    02ToyMan
    02ToyMan Member
    Dave
    02 Tacoma manual transmission
    Back in 2014 I was running into the same issues. I had the system vacuum tested and there were no leaks. I replaced the vsv and still kept getting the same error codes. After speaking to the local Toyota dealership they say my charcoal canister was saturated. (I was topping off my tank every time I filled it. Bad idea). They wanted $1400 to swap it out. They said they had to put it up on the lift, drop the gas tank, yada yada.
    I left and went straight to Autozone. Paid $80 for a new canister. Went home and crawled under the truck. I was able to sit up and see the canister mounted over the tank and swap it out myself.
    When I did it I disconnected my battery. After I was done with the swap out I reconnected the battery and started it up. No more check engine light or error codes. Passed smog just fine. Hope this helps.
    underaroof and Black DOG Lila like this.
  16. Oct 6, 2019 at 3:59 PM
    AmherstAndy
    Andy
    Masshole
    Hi all,
    I meant to update sooner, but since driveability wasn't a factor with this issue, I wasn't in a huge rush. Anyway, I reconnected the aforementioned vacuum line alongside the filler neck and hoped the CEL would eventually shut itself off. Well, that didn't happen, so after about a week, I bought an inexpensive OBDII code reader from harbor freight. I connected and verified that the same codes originally pulled at Autozone were still showing, then cleared the codes.
    After a couple of drive cycles, the CEL came back on, so I connected the scanner and pulled the same three codes that started this ordeal. After a few more days went by, I had the chance to poke around again, and discovered that another vacuum line was disconnected. I discovered this by feel, since it was in a spot that I couldn't see. This was the second of the two lines that run alongside the filler neck. Amazingly, the filler neck itself appears to be intact, so that's a relief. Anyway, I reconnected the second vacuum line, again, purely by feel, and noted that my hand was completely black from what resembled soot, which I'm speculating may have been charcoal from the EVAP canister that leaked out...I don't know if this is possible, but that's what it seemed like.
    After a week a driving and several cycles, the scanner says all readiness codes (including EVAP) are set and the CEL has not come back on. I'm remaining cautiously optimistic that the problem is solved and the EVAP system will work correctly for the foreseeable future.
    Thanks again for all of your help.
    Best regards,
    Andy
  17. Oct 6, 2019 at 4:22 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    That's great news man. And even if it does come back on, hopefully not, you already have a good grasp on what's going on and possible fixes, etc. Nice work hombre
  18. Oct 9, 2019 at 3:39 PM
    Jooeee!
    Jooeee! Active Member
    Joe
    2002 TRD Black Tacoma
    OC Cali!
    I have the same 3 codes on my truck. What should i do? Ive replaced the gas cap w/ oem from Amazon. Do i need a new charcoal canister or purger valve? Smog is due at end of this month dam California!
  19. Oct 9, 2019 at 4:06 PM
    AmherstAndy
    Andy
    Masshole
    You should probably start a new thread, since my issue has been resolved. That said, the solution to my problem involved re-connecting the vacuum lines that run alongside the filler neck. I don't understand the system or its components well enough to explain why these lines being disconnected caused the codes, although to someone who understands the EVAP system thoroughly, it would probably make complete sense. Just be wary of self-proclaimed internet experts who claim to understand.
    If it helps, I thought this article was a good read...it got me thinking a bit about how to inspect the system.
    https://us.autologic.com/news/toyota-tacoma-evaporative-emission-faults
    In any event, I suggest you begin by conducting as thorough an inspection as you can, without taking anything apart, for fear of causing further damage. Use an EVAP system diagram to guide you. You may get lucky, like me, and find an obvious, easy solution.
    Lastly, EVAP readiness codes are set after two "trips", in which certain operating parameters need to be satisfied. I suggest clearing the codes after you make a fix (gas cap in your case) and drive for a few days to see if the codes come back.
    Good luck.
  20. Oct 9, 2019 at 4:25 PM
    Jooeee!
    Joe
    OC Cali!
    Thank you for the quick response.
