(see pic) Should I replace these drum shoes? Tips on rear brake drums
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yoyoboydoag, Sep 14, 2024.
  1. Sep 14, 2024 at 4:00 PM
    yoyoboydoag
    yoyoboydoag [OP] Member
    07 Tacoma with 160k miles
    This is my first time inspecting the rear drum brakes, thought I would do so because my brake pedal is kinda soft!
    I have about 3mm on these shoes? Give or take
    any advice or tips on adjusting these is appreciated. My drivers side shoes are much tighter than my passenger side
  2. Sep 15, 2024 at 8:49 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    This is just me, if nothing else is wrong with them I'd put it back together and drive. I'm glad to see the pictures as I have about 125,000 miles on my 2010 and now I don't see any reason to worry about mine.
    Rougarou680 likes this.
  3. Sep 15, 2024 at 9:17 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    IIRC, 1mm is the minimum.
    What ever you do, make sure to use an OEM spring set.
    Aftermarket springs are hit and miss. If they aren’t bent correctly, they can cause issues. (Ask me how I know)
    As for the shoes, take your pick.
    As long as it’s a name brand shoe, it will be fine.
    The rear drum setup on these truck are mediocre at best.
    Most guys don’t adjust them as often as they should. (Including me)
    But you’d be surprised at how much better the truck stops with properly adjusted rear brakes.
    And don’t listen to the guys that say they are self adjusting. They are designed to self adjust. But in practice it doesn’t work well at all.
  4. Sep 15, 2024 at 9:37 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Agree. The self adjust mechanism on the rear drums should click the star automatically as the shoe wears down, but it seems like it is not guaranteed. I suspect I need to manually adjust mine but have not done it yet.
    TnShooter[QUOTED] likes this.
  5. Sep 15, 2024 at 9:40 AM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Those are fine.
    Wash them down, lube the backing plates and adjust them……just a very slight drag. Don’t forget to clean the mating surface of the hub and drum, put a very light coat of anti seize on it.
  6. Sep 15, 2024 at 12:53 PM
    2015WhiteOR
    Gainesville TX
    So out of curiosity I took a stab at my rear drums this afternoon.
    I have about 80k miles on the truck and the rear shoes still have around 3-4mm of life left, although the trailing edge of one shoe was maybe a smidge under 3mm.
    Before I removed the drums, I could tell that each side had a slight drag to them, although it was lop sided. Basically as you spun the drum around, you would hear a spot maybe 4" long where you can hear the shoe rubbing against the drum. I've owned the truck since brand new and this is the first time I've even popped off the rear drums so I don't think anything is warped or damaged.. Just seems like natural tolerances.
    There was plenty of dust inside there.. was it 80k worth of dust? Hard to say.
    When it came to manually adjusting the adjuster.. what a pain in the ass. The principle is simple, but the problem is that there is a slight amount of natural slop in every tolerance so you aren't able to go at it like a machinist with a lathe and a micrometer. If you take off the drum, adjust it, then remove the drum, adjust it, and put it back on the variables all change each time. Plus the axle itself has a certain amount of drag with each rotation so you never quite know if you are feeling drag from the axle or the brake.
    The weird thing is that sometimes it was impossible to put the drum back on, even though I had adjusted the shoe spacing to the less than when I originally started the job. It's like the drum was out of round at times, or the shoes were splayed out a few extra mm on occasion for some reason.
    It was much easier to adjust the star with the drum off, although that has its own issue because you can reach a point where you cannot install the drum back on so you have to undo the star adjustment. Trying to adjust through the rear port hole was a pain in the ass too because you can't really see clearly in there and it seems to fight you, even though you are pushing the teeth in the "natural" direction where it would fall on a new detent.
    Best I could do was get each side to the point where spinning the drum by hand resulted in 1 rotation (rather than 2-3 when there is zero brake drag).
    Now that everything inside there is clean and dust free, and if the stupid auto adjuster actually works, hopefully it will do the rest of the work for me and auto-click to the right point.
  7. Sep 15, 2024 at 2:55 PM
    mk5
    mk5 Probably wrong about this
    SoCal
    '05 access cab 4x4
    Yeah, I would just grease everything that's supposed to be greased, adjust it, and keep driving. If they're not malfunctioning, replacing parts won't make these work any better.
    Mine made it to 200k or so before I replaced them, and they still had a bit of life left. But I had to swap the axle seals, so I figured I'd replace all the brake stuff too. Having a little screwdriver-style spring compressor really helped. I think I used an aftermarket kit for the parts... with all the springs and a new cylinder. Maybe I got lucky there, the brakes seem to work as well as they ever did -- i.e., poorly. Drum brakes just suck.
    To adjust the star things, I always have to pull one of the drums so I can see what I'm doing. Then I can usually adjust the other through the little access hole. But not really any faster.
    If you do pull the brakes apart, consider also replacing the axle seals. Especially if you haven't recently changed the oil.
    For a spongey pedal... check if the front pads and rotors are too thin. It turns out that wearing the pads almost down to the plates and never changing your rotors will eventually give a very spongey brake pedal. A proper blead might help too, if there's air in the system. I had to take mine to the dealership earlier this year for that... requires special equipment to bleed the ABS. Another thing to check is the brake booster. If it's the vacuum booster, then the spongey pedal is normal.
  8. Sep 15, 2024 at 3:11 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    This ^^^. You should get at least 250k out of a set of factory rear shoes. Unless you’re extremely hard on the brakes or tow a lot.
  9. Sep 15, 2024 at 6:43 PM
    vtdog
    vtdog Well-Known Member
    NH
    2mm is the standard in many states. You have the brakes apart anyway, just get a pair of new shoes, service/grease the whole unit and you are good to go for another 160k miles.
  10. Sep 15, 2024 at 11:59 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    The rears are adjusted (after initial by hand to specs) by using the parking brake and as such there is a pivot point (stud on shoe near where the parking brake cable attaches) to the brake shoe that often freezes/rusts solid so that needs to be freed and lubed to keep that parking brake working (lever action).
  11. Sep 16, 2024 at 6:16 AM
    2015WhiteOR
    Gainesville TX
    This is incorrect. Older brake drums did work this way.. like early 90s 4runners, but it seems any Toyota made after 2005ish uses the newer setup where the star wheel clicker only moves in relation to shoe wear.
    Bishop84 likes this.
  12. Sep 16, 2024 at 5:00 PM
    muddog321
    FL
    2015s comment is correct that the star wheel moves in relation to shoe wear but since 2005 the parking brake is the action that activates/levers the star wheel arm.
    If in doubt follow the movement when the parking brake is applied. These are not like GMs.
  13. Sep 16, 2024 at 5:08 PM
    Bishop84
    Bishop84 Well-Known Member
    They self adjust to a bare minimum.
    For reference, its rare for me to see drums adjusted when I service a Tacoma.
    If you aren't sure, its probably time.
    3mm is like 50-60% left, 1mm or less is toss. 4.5mm is new.
  14. Sep 16, 2024 at 6:29 PM
    2015WhiteOR
    Gainesville TX
    You are still incorrect!
    This guy even made a video and posted it online because he assumed the same. In the video, he shows all the parts of the system, and then at the 4:26 timestamp he actuates the parking brake but you can see that it only moves the left shoe outward; the star adjuster has ZERO movement.
    https://youtu.be/hzZ7qfZ4u8U?si=UxZFQQCjNnZXsrU5&t=193
  15. Sep 16, 2024 at 6:40 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    I'm the guy that won't change their oil until the warning goes off and then I'm in no hurry. The guy that runs a belt for 80K miles after a tech recommends replacement. I've never changed antifreeze in my life and never will because I've never had a problem with a cooling system... and I'm seventy so I've driven a lot of miles. So I'd run those puppies... except...
    You've already got the drums off. Slap a new set of shoes on and you will probably never have to take the drums off again. I tend to put a new hardware kit on at the same time but you do you. It's your brakes, right?
    And after you snug up the new shoes with the star wheel so they barely touch the drums and you can still get them on, the star wheel is actuated by putting on the brakes as you stop in reverse. Do this a couple of times and as long as the shoes were slightly snug when assembled they will adjust to fit just fine.
  16. Sep 16, 2024 at 7:36 PM
    lr172
    lr172 Well-Known Member
    ‘11 DCLB 4.0 Auto
    Mine got loose a couple months ago. Long pedal travel. I really struggle finding the star through the hole, so tried what works on most American cars. Went to a parking lot and got to about 20 mph in reverse and slammed on the brakes. Repeated 6 times and pedal travel came back to normal. I am convinced these are just like most modern drum brakes and only adjust when braking in reverse. Most of us never brake hard in reverse and these won’t adjust when going forward. Therefore , most of us see them as non functional. Most modern drum setups will also adjust each time the parking brake is applied. Didn’t try this on mine as they are seized.
  17. Sep 17, 2024 at 4:02 PM
    muddog321
    FL
    The adjuster arm is mounted differently on the Tacoma.
    That video simply showed that when the parking brake was applied if the drum had been on the shoes were already correctly adjusted.
    When they applied the brakes with the pedal and no drums that proved nothing and lucky the wheel cylinder plunger didn't poop out.
    Oh well enjoy.
  18. Sep 17, 2024 at 4:58 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I check mine every year, just did a couple of weeks ago. I sprayed them down, re-lubed the contact points, adjusted them out and put them back together. I'm at 167,000 miles and still have about 1/8".
    When I have my drums off, I put them on backwards (inside out) and put the truck in gear to let them spin at idle speed. Then with a small die grinder, I smooth the inner edge where the step develops.
    If you do this, DO NOT step on the brake pedal with the drums off. I did this inadvertently on a Corolla a few years back and popped the pistons out of the cylinder. That was a mess.
  19. Sep 17, 2024 at 5:03 PM
    killerkeener
    killerkeener Well-Known Member
    2011 trd 4x4 manual
    None yet
    Check front brake pads 80% of braking is done from the front....you can adjust the rear pads out....I recommend CHANGING your brake fuild as it breaks down with heat and time and 100+k ...
  20. Sep 17, 2024 at 5:10 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    You usually get 2 sets in front for every one set in back. I replaced the the 2nd set of rears this week with 3/32 left. I get about 100K out of a set. I replaced the drums this go around because I had to really back them off to get over the ridge. At 200K miles I felt the drums didn’t owe me anything.
