Securing plastic storage containers to truck bed?
Discussion in 'Off-Roading & Trails' started by coff33, May 25, 2022.
  1. May 25, 2022 at 10:21 PM
    coff33
    coff33 [OP] Well-Known Member
    5vzfe manual
    What's the best way to do it? I'm talking containers like Pelican cases or maybe even storage totes from Home Depot.
    Just drill a hole through the box and the bed and secure with nut and bolt? Is there a better way?
  2. May 27, 2022 at 10:29 AM
    Stuck Sucks
    Stuck Sucks Aerodynamic styling with functional design
    Jim
    North American Plate
    I used this tie-down method for my last few Tacomas: simple tie-down racks + some 3M non-skid tape. Use some ratchet-straps and your stuff will not move. Baja proven.
    Toyoda213 and ToyoTaco25 like this.
  3. Jul 18, 2022 at 9:49 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    there are 8 anchor points in the bed or a use a net to cover the whole bed
    and most of the better than average storage containers have holes or hooks on them
  4. Jul 18, 2022 at 10:00 PM
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    An aluminum rack which attaches to the bed rails and is built to the case dimensions. Ratchet straps hold the cases to the rack. This is something I have had in mind for my own truck. My tonneau has a panel by the cab that opens independently so I want to have a rack I can reconfigure for different loads or remove completely and I want it off the bed floor.
    If I can ever get a day where my time doesn’t belong to someone else, I’ll build it. I’ve had the materials for like a year. Isn’t that how it always goes though?
  5. Apr 1, 2023 at 2:29 PM
    Jab969
    Jab969 Active Member
    Jefferson County
    2022 Gray Tacoma TRD OR
    What does this tie into to prevent it from coming out?
  6. Apr 1, 2023 at 4:41 PM
    Stuck Sucks
    Jim
    The rails have fasteners every foot -- underneath the composite floor are big-ass washers and nylok nuts. Since the underside of the floor has a waffle pattern, some creativity is required for the installation.
    This tie-down system has held multiple Trophy Truck tires, dump cans, other heavy stuff, etc. while bopping down Baja -- things do not move.
    BKinzey likes this.
  7. Jun 9, 2023 at 7:06 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    I use Rubbermaid totes (or whatever the brand is for "good stuff" at the hardware store.
    Filled with food stuff, cooking gear, or clothes, when set on the Toyota bed mat, They DON'T MOVE. In fact, it's a pain to slide them in and out.
