Secret for Mini Maglite Owners!
Discussion in 'Lighting' started by HedgehogOutdoors, Oct 15, 2012.
  1. Oct 15, 2012 at 6:34 PM
    HedgehogOutdoors
    HedgehogOutdoors [OP] Well-Known Member
    CT
    '98 4runner SR5
    *I believe this is for the non-LED models only, someone with the LED model can either confirm or deny this for me*
    Well, one of the threads on here asked what we have for survival gear in our 4runners. I went through all my stuff and remembered the bulb in my Mini Maglite is burnt out. It's been that way for months, I just never got around to getting a new bulb. So, I went on Maglite's website, so that I could look for the part number. I found the exploded diagram of the Mini Maglite, and found something that looked like a bulb, but I couldn't tell. I looked at the part name below, and sure enough, it was. So here's how to get at it:
    It is inside the tailcap:
    This is what you need to be looking at once you remove the tailcap:
    Next, you have to pull the spring out. It pulls straight out, doesn't need to be twisted out or anything. *NOTE: when putting the spring back into the tailcap, be sure to seat it in nicely, or else the light may not work. This spring completes the circuit.*
    Here is the bulb inside the little red housing:
    And it works again!
  2. Oct 15, 2012 at 6:35 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Most maglites have an extra bulb. Good on you for finding it though! I'm sure there's plenty of other people that don't know.
  3. Oct 15, 2012 at 6:38 PM
    ToyotaKTMracing
    ToyotaKTMracing The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
    Holy crap! Never knew that. Now to see if anyone has discovered this with the LED. Sub'd to find out :D
  4. Oct 15, 2012 at 6:39 PM
    memario1214
    Colton
    Missoula, MT
    Ill check my LED one right now
  5. Oct 15, 2012 at 6:42 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    Now remember to order a new one to put back in the spare spot so you have it next time you need it, otherwise the whole idea of having a spot for a spare is pointless.
  6. Oct 15, 2012 at 6:42 PM
    memario1214
    Colton
    Missoula, MT
    Negative. The LED is soldered down and I can't even remove it...
  7. Oct 15, 2012 at 6:42 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    You never knew that? Lol, the fullsize ones have that as well..
  8. Oct 15, 2012 at 6:44 PM
    Boerseun
    Ferdie
    Sarasota, Florida
    My LED light doesn't have a spare. LEDs are not supposed to burn out.
  9. Oct 15, 2012 at 6:44 PM
    ToyotaKTMracing
    Shay
    West Virginia
    I need to check my 2D LED one in my truck sometime!
  10. Oct 15, 2012 at 6:44 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    you have to take the whole top assembly off and then you can pull out the LED bulb. LED maglites come with an extra regular bulb to replace it if you want.
  11. Oct 15, 2012 at 6:46 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i never knew that... thanks for showing that! :)
  12. Oct 15, 2012 at 6:50 PM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    I discovered this a couple years ago, just because I can't ever stop dissasembling random shit. :notsure:
  13. Oct 15, 2012 at 6:51 PM
    memario1214
    Colton
    Missoula, MT
    That's on the full size one like I have in the Tacoma. The Mini, the one the other guy and the OP were asking about, won't come apart. Or at least the one I have won't.
  14. Oct 15, 2012 at 9:52 PM
    joes06tacoma
    Joe
    Central Coast, CA
    The first LED maglites that came out in the D cell sizes have an LED assembly that can be removed and replaced with a standard bulb. The standard bulb is included in the tailcap. The later LED maglites have an LED that does not come out. I believe that includes the mini mags as well.
    There are few aftermarket LED conversions for the mini mags that significantly up the runtime on a pair of batteries. Usually can be found at ACE hardware or Walmart. Worth looking into, usually talking about 5-12 dollars. That's half the cost of a factory built mini mag LED and totally worth it if you already have a minimag.
  15. Oct 15, 2012 at 10:49 PM
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    The MiniMag LED model also has an SOS Morse code flash and strobe function as well...
    Keep one in the wheelhouse on the boat. Spent hours messing around with that thing!:D
  16. Oct 15, 2012 at 11:34 PM
    NWTacoGuy
    NWTacoGuy Well-Known Member
    James
    Pacific North West
    2010 TRD Off Road DCSB
    Fabtech 6", xd addicts/35x11.50 Nitto Terra Grapplers, Black badges, Pioneer HU, 11' grille, ect ect ect....
    I have been using these for years and the crap bulb always burns out....I actually had one within arms reach when I read this and decided to look. What do you know!!! an extra bulb. The cool thing is I usually just toss them in a box when I think the bulbs are gone, so when I go home I will have to check the box for the new bulbs.
    Thanks a lot OP that was a cool find, I can't believe I never knew about it before :eek:
  17. Oct 15, 2012 at 11:39 PM
    jeverich
    Jake
    PNW/Kodiak
    07 2.7 4x4
    I find it interesting how quite a few people had no idea about the extra bulb.
    Pretty much my first instinct as soon as I buy something is to disassemble it. Which yes, it has bitten me in the ass on a few occasions.
  18. Oct 16, 2012 at 12:29 PM
    HedgehogOutdoors
    CT
    '98 4runner SR5
    This thead done took off like a rocket! Didn't think I'd get many replies! I posted the same thing on T4R.org, 2 replies in the same amount of time haha. Thanks to the LED owners, and thanks to the full sized guys as well(no homo). :D
  19. Oct 23, 2012 at 7:47 AM
    cajunron
    cajunron Active Member
    Ronnie
    Atlanta, GA
    2006 PreRunner Access Cab
    Yep. I can't tell you how many mini mag lights I've taken apart and put back together with different colored parts from other mini mags. I love to take crap apart to see how things work.
