Secondary Air Pump ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lickskillet, Dec 28, 2020.
  1. Dec 28, 2020 at 2:25 AM
    lickskillet
    lickskillet [OP] Well-Known Member
    Land Of Big Sticks
    2014 Tacoma
    I am seeing some scuttlebut regarding a secondary air pump and it having a filter etc. I did some searching and not sure of some things. Mine is a 14 4.0L. Is there a filter I should be cleaning? I hear of a mod. What does this do? Do I need to be concerned with failure of it? I'm right at 80k miles. Thank you in advance for info...
  2. Dec 28, 2020 at 2:52 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Yes your '14 has the secondary air injection, it's the the right of the motor (left side as you look into the engine bay from the front) behind the air intake hose going into the fender.
    It has a foam filter that breaks down and gets sucked into the pump, not a cleaning issue but an integrity issue.
    The pump is part of the '11+ emissions system.
    The mod is to remove the factory filter and fit a "K&N" style mini cone filter.
    The failure can cause a check engine light due to faulty emissions secondary injection pump failure.
    80k/8 years is about the time the oem ones fail as far as I know.
    The 05-10 does not have the secondary injection system.
    The secondary air injection system does nothing more than intake atmospheric air and inject it into the exhaust to cool the exhaust and dilute the exhaust particle concentration in order to pass emissions laws of that year and beyond, It's effectively a loophole and realistically does nothing to reduce emissions overall.
  3. Dec 28, 2020 at 3:42 AM
    lickskillet
    Land Of Big Sticks
    2014 Tacoma
    Interesting... Is the filter mod a pretty simple one to do?
    Kolter45 likes this.
  4. Dec 28, 2020 at 4:09 AM
    JMC3800
    JMC3800 Well-Known Member
    Western MASS
    2021 Off Road DCab
    Plenty of threads on here about it, it takes 5 minutes To change out once you take the cover off pull out the old brittle foam that’s what breaks off and damages the fan component.
    Kolter45 and tacotoe like this.
  5. Dec 28, 2020 at 4:11 AM
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    12TRDTacoma and Key-Rei like this.
  6. Dec 28, 2020 at 1:07 PM
    Soylent Green2012
    Soylent Green2012 RestoRides MotorSports
    jake
    Apopka, Florida
    2012 Tacoma Pre runner SR5 V6 Limited Edition
    chrome bull bar, 20" vision wheels, LED lighting, Custom grill.
    PzTank, jkuniverse and Kolter45 like this.
  7. Oct 6, 2021 at 4:40 AM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Has anyone that has done this mod seen any change in MPG ?
  8. Oct 6, 2021 at 5:11 AM
    snook 32
    snook 32 Well-Known Member
    Herb
    Davie Florida
    08 pre runner
    its called the Uni Filter, simple to install
    PzTank likes this.
  9. Oct 6, 2021 at 6:51 AM
    TacoFergie
    Iowa
    Removal of the SAIS doesn't affect mileage at all. The tune doesn't really impact mileage either, some say they get 1-2mpg better but for me it was no measurable change and I have been using fuelly since day one of my truck. Heavy ass 33" made my mileage much worse! But I expected that. lol
    That is an option, but if you already have a tune using HPTuners it gives you the option to just completely remove the system which has a few benefits. Less components to fail long term, less stuff under the hood, less weight (I would say 20-25lbs, though it's negligible on trucks like ours) and more room for activities under the hood especially if you plan to add a 2nd battery or the fact that any 05-15 aftermarket air intake will fit because you do not have to worry about provisions for the SAIS pump if you want to go down those routes. I know this mod isn't for everybody. But if you already have HPTuners, it is an option. If you don't have a tune using HPTuners, you should find someone who does and take it for a spin. There is a very big difference in drivability after it is tuned, honestly it makes the throttle response and trans characteristics the way it should have been from the factory plus a little bit better power, not much though on a stock truck.
    Marc70 likes this.
  10. Oct 6, 2021 at 8:15 AM
    tacoma guy
    Joe
    Phoenix Az.
    Ok sounds good . Thanks for your reply !
    TacoFergie[QUOTED] likes this.
  11. Oct 6, 2021 at 8:52 PM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    i have a '12 and hate that fucking thing. it's right where an ARB compressor should be. i live in CA so touching it is akin to a capital offense, per the DMV. i put the cute little filter on and the tech was asking questions about it when i got smogged last. i told him about the TSB and was stoked that i got out of there with a pass. meticulous rules are meticulous.
  12. Oct 6, 2021 at 9:08 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You just gotta keep the mods internal. You cannot fail what you don't see and as long as there is no check engine light, smoking out clouds of black or white smoke at first rev up, anything is possible. You just need to know what you're doing.
  13. Oct 6, 2021 at 9:16 PM
    lawless
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    i reckon i could figure out how to do the delete, but passing visual inspection after removing the pump would not likely fly. they are vultures. eagle-eyed vultures.
    haha, especially if there's a big air compressor where sap should be.
  14. Oct 6, 2021 at 9:20 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The SAI is a story entirely of its own, but If you are well intent on running an air compressor, there is TONS of space on the frame rail of the passenger side below. Why not run it there?
    You can also always relocate the SAI pump by the power steering pump, but you will need some brackets and extend wiring to do so.
  15. Oct 6, 2021 at 9:33 PM
    lawless
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    i like where the slee mount puts the dual compressor. there's not tons of room under my hood, hence, my reason for disliking that pump.
  16. Oct 6, 2021 at 9:48 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I edited my post above, as I forgot to put one thing on it. Go check it.
  17. Oct 7, 2021 at 6:02 AM
    TacoFergie
    Iowa
    How well trained are the techs and what are their visual references? Only reason I ask is when the system is removed it doesn't look like there was anything there in the first place looks like the 05-11 Tacoma's minus the tubes on the exhaust manifolds. Since the system is bypassed (but still operational if hooked up) through HPTuners it wouldn't show any abnormalities in when the computer is plugged in so the tech wouldn't see any issues that would make him peruse a deeper inspection.
    This is more out of my own curiosity since we do not have any vehicle inspections in any of the states surrounding me.
  18. Oct 7, 2021 at 6:40 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    The filter isn't the only reason for the pump failure, there are internal issues with the pump it's self. When mine failed the filter was 100% still intact.
    Toyota has been replacing the pumps covered under the TSB with a redesigned one.
    TacoFergie likes this.
  19. Oct 7, 2021 at 12:19 PM
    lawless
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    The guy at the last shop knew to look for the system on my '12 because he mentioned the aftermarket filter I installed. Not sure whether he just knew about my model year, noticed the filter, or was comparing to a schematic. There are likely less vigorous inspectors at other shops.
  20. Oct 7, 2021 at 12:59 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    It goes a step further. Your truck when connected via OBD is going to tell the computer system what emissions systems are on the vehicle then the tech knows what SHOULD be on the vehicle and what to check for. Like stated, even the UNI filter is technical grounds to fail inspection.
    Also FYI, its on the 12+ v6's not 11+ v6s like mentioned earlier.
    PzTank and Kolter45 like this.
